  4. web Adapter lässt dich nicht updaten
    6.5k
web adapter update
46 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • L lumajo
    @thomas-braun aber der telegram adapter meldet auch Fehler beim update...eigentlich jetzt alle updates die so anstehen.
    Soll ich die package-lock.json löschen? weis ehrlich gar nicht was die macht...
    $ iobroker upgrade telegram@1.10.0
    Update telegram from @1.8.0 to @1.10.0
    NPM version: 6.14.14
    npm install iobroker.telegram@1.10.0 --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc: In function 'void after_doing_auth(uv_work_t*, int)':../authenticate_pam.cc:107:87: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~
    ../authenticate_pam.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)':../authenticate_pam.cc:147:83: error: no matching function for call to 'v8::Array::Get(v8::Local<v8::String>)' Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate: 'v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate: 'v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../authenticate_pam.cc:150:69: error: no matching function for call to 'v8::String::WriteUtf8(char [128], unsigned int)' serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: 'int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const' int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from 'char [128]' to 'v8::Isolate*'../authenticate_pam.cc:152:69: error: no matching function for call to 'v8::Array::Get(v8::Local<v8::String>)' res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate: 'v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate: 'v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)' V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../authenticate_pam.cc:155:66: error: no matching function for call to 'v8::String::WriteUtf8(char [128], unsigned int)' remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: 'int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const' int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from 'char [128]' to 'v8::Isolate*'../authenticate_pam.cc:160:58: error: no matching function for call to 'v8::String::WriteUtf8(char [128], unsigned int)' username->WriteUtf8(m->username, sizeof(m->username) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: 'int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const' int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from 'char [128]' to 'v8::Isolate*'../authenticate_pam.cc:161:58: error: no matching function for call to 'v8::String::WriteUtf8(char [128], unsigned int)' password->WriteUtf8(m->password, sizeof(m->password) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: 'int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const' int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from 'char [128]' to 'v8::Isolate*'../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field 'init' declared void void init(Handle<Object> exports) { ^~~~~~../authenticate_pam.cc:170:11: error: 'Handle' was not declared in this scope../authenticate_pam.cc:170:11: note: suggested alternative: 'rand_r' void init(Handle<Object> exports) { ^~~~~~ rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before '>' token void init(Handle<Object> exports) { ^../authenticate_pam.cc:170:26: error: 'exports' was not declared in this scope void init(Handle<Object> exports) { ^~~~~~~In file included from ../../nan/nan.h:56, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: 'init' was not declared in this scope NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:36: note: in definition of macro 'NODE_MODULE_X' (node::addon_register_func) (regfunc), \ ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~../authenticate_pam.cc:175:31: note: suggested alternative: 'int' NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:36: note: in definition of macro 'NODE_MODULE_X' (node::addon_register_func) (regfunc), \ ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
    gyp ERR! System Linux 5.10.52-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v14.17.5gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
    Update "system.adapter.telegram.0"
    upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
    upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
    upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
    upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
    upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
    upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
    Adapter "telegram" updated
    Process exited with code 0
    #41
    @lumajo sagte in web Adapter lässt dich nicht updaten:
    nein, nicht wirklich
    L 1 Antwort Letzte Antwort
      lumajo
      schrieb am zuletzt editiert von lumajo
      #42
      @homoran ja auch der Web adapter ist die neueste version habe es gerade gesehen. ok, dann belasse ich es mal dabei und wende mich dem nächsten Problem zu :-)
      Danke soweit
      • L lumajo
        #43
        @lumajo
        Schmeiß mal den terminal-Adapter aus dem System, wenn der drin sein sollte. Der sorgt gerne für diese Meldungen mit authenticate_pam.
        Brauchen tut den eigentlich keiner...
          @lumajo
          lumajo
          #44
          @thomas-braun den hab ich nicht, den brauche ich ja nicht, ich geh ja normal aufs Terminal..
          verstehen tu ich nicht warum bei einem Fresh Install ohne viel rumgefrickel diese Fehlermeldungen kommen. Ich bin da wohl ein bischen von Domoticz verwöhnt. ;-) aber soweit läuft es jetzt ich widme mich meinen Anderen baustellen, dem backup Adapter und der Alexa ;-)
          DANKE soweit hast mir gut geholfen
          HomoranH J 2 Antworten Letzte Antwort
          • L lumajo
            #45
            das sind z.B. Meldungen, dass es keine fertigen Pakete gibt und diese gebaut werden. Dabei werden auch optionale Dependencies übersprungen
            c hbin da wohl einbische nvon Domoticz verwöhnt.
            Vielleicht unterdrückt Domodings diese Meldungen einfach
            • L lumajo
              Jan1
              #46
              Ich lach mich schlapp, das hatte ich mal kurz vor IObroker angeschaut und war ganz schnell wieder weg ;)
