  4. Kein restore mit backitup [gelöst]
    6.4k
46 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    @christian-sandkaulen
    free -ht
    kann man besser lesen.
    ChrisNettC Offline
    ChrisNettC Offline
    ChrisNett
    #41
    @thomas-braun said in Kein restore mit backitup:
    free -ht
    pi@PI4:~ $ free -ht
    Mem:          3,7Gi       1,1Gi       2,1Gi        16Mi       585Mi       2,7Gi
    Swap:          99Mi          0B        99Mi
    Total:        3,8Gi       1,1Gi       2,2Gi
    motion io ist aus und der ioBroker läuft.
    ChrisNettC 1 Antwort Letzte Antwort
    • ChrisNettC ChrisNett
      free -ht
      pi@PI4:~ $ free -ht
      Swap:          99Mi          0B        99Mi
      ChrisNettC Offline
      ChrisNettC Offline
      ChrisNett
      #42
      er macht ein restore yes... lag es wirklich an MotionEye? soll das mal auf einen eigenen PI4?
      kann gerade keine code kopieren...
        ChrisNettC Offline
        ChrisNettC Offline
        ChrisNett
        #43
        [DEBUG] [iobroker] Start ioBroker Restore ...
        [DEBUG] [iobroker] iobroker controller daemon is not running
        [DEBUG] [iobroker] host.PI4 OK.
        [DEBUG] [iobroker] host.PI4 Clear all objects and states...
        [DEBUG] [iobroker] clean 8767 objects...
        [DEBUG] [iobroker] Server Objects 127.0.0.1:52796 Error from InMemDB: Error: Object is marked as non deletable
        [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
        [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
        [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
        [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
        [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
        [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
        [DEBUG] [iobroker] clean 7218 states...
        [DEBUG] [iobroker] host.PI4 done.
        [DEBUG] [iobroker] System successfully restored!
        [DEBUG] [iobroker] ioBroker Restore completed successfully
        [EXIT] 0 **** Restore completed successfully!! ****
        The log can be closed ...
        also doch einen pi für motion eye? wisst ihr warum nach einem neustart (Stromausfall die vis weg sein kann?)
          #44
          @christian-sandkaulen sagte in Kein restore mit backitup:
          Nach einem Stromausfall (abrupten Stromentzug) kann alles mögliche weg sein, auch die vis.
            ChrisNettC Offline
            ChrisNettC Offline
            ChrisNett
            #45
            danke, euch allen.
              #46
              soll das heißen, dass du einen Stromausfall hattest.
              da kann irgendetwas oder alles im Dateisystem hin sein.
              Das kann auch der Grund für das Schneckentempo sein
