  4. [gelöst]JavaScript startet nicht mehr nach Update
    2.0k
javascript adapter
11 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • heinhanH Offline
    heinhanH Offline
    heinhan
    schrieb am zuletzt editiert von heinhan
    Hallo, wie oben beschrieben läuft der Adapter nicht mehr. Hier die LOG:
    host.raspberrypi
    2021-08-12 15:13:12.842	info	Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi
    2021-08-12 15:13:12.842	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2021-08-12 15:13:12.841	error	Caught by controller[0]: }
    host.raspberrypi
    2021-08-12 15:13:12.841	error	Caught by controller[0]: ]
    host.raspberrypi
    2021-08-12 15:13:12.841	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.raspberrypi
    2021-08-12 15:13:12.841	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    host.raspberrypi
    2021-08-12 15:13:12.841	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
    host.raspberrypi
    2021-08-12 15:13:12.841	error	Caught by controller[0]: requireStack: [
    host.raspberrypi
    2021-08-12 15:13:12.840	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi
    2021-08-12 15:13:12.840	error	Caught by controller[0]: {
    host.raspberrypi
    2021-08-12 15:13:12.840	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi
    2021-08-12 15:13:12.840	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi
    2021-08-12 15:13:12.840	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi
    2021-08-12 15:13:12.840	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi
    2021-08-12 15:13:12.839	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi
    2021-08-12 15:13:12.839	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi
    2021-08-12 15:13:12.839	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.raspberrypi
    2021-08-12 15:13:12.839	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi
    2021-08-12 15:13:12.839	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi
    2021-08-12 15:13:12.839	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi
    2021-08-12 15:13:12.838	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi
    2021-08-12 15:13:12.838	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi
    2021-08-12 15:13:12.838	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi
    2021-08-12 15:13:12.838	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
    host.raspberrypi
    2021-08-12 15:13:12.838	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi
    2021-08-12 15:13:12.838	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi
    2021-08-12 15:13:12.837	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi
    2021-08-12 15:13:12.837	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi
    2021-08-12 15:13:12.837	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi
    2021-08-12 15:13:12.837	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi
    2021-08-12 15:13:12.837	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
    host.raspberrypi
    2021-08-12 15:13:12.836	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi
    2021-08-12 15:13:12.836	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi
    2021-08-12 15:13:12.836	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.raspberrypi
    2021-08-12 15:13:12.836	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.raspberrypi
    2021-08-12 15:13:12.836	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.raspberrypi
    2021-08-12 15:13:12.836	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    host.raspberrypi
    2021-08-12 15:13:12.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
    host.raspberrypi
    2021-08-12 15:13:12.835	error	Caught by controller[0]: Require stack:
    host.raspberrypi
    2021-08-12 15:13:12.835	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.raspberrypi
    2021-08-12 15:13:12.835	error	Caught by controller[0]: ^
    host.raspberrypi
    2021-08-12 15:13:12.835	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2021-08-12 15:13:12.834	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    host.raspberrypi
    2021-08-12 15:13:12.358	info	instance system.adapter.javascript.0 started with pid 29669
    Hier meine Daten:
    Ist passiert nach dem Update auf Node.js 12.22.5
    Neustart Raspi/ioBroker ohne erfolg.
    lobomauL Thomas BraunT 2 Antworten Letzte Antwort
    • heinhanH heinhan
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      Hier meine Daten:
      lobomauL Offline
      lobomauL Offline
      lobomau
      @heinhan welche Anleitung für das Update wurde genommen?
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • heinhanH heinhan
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        Hier meine Daten:
        @heinhan
        nodeJS als Basis dann aber sauber?
        which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
        heinhanH 1 Antwort Letzte Antwort
          @heinhan
          heinhanH Offline
          heinhanH Offline
          heinhan
          @thomas-braun sagte in JavaScript startet nicht mehr nach Update:
          Hier das Ergebnis:
          Die Instanz lässt sich nicht starten:
          • heinhanH heinhan
            Hier das Ergebnis:
            @heinhan
            Bitte Konsolentext nie als Screenshot, immer als Text in </> CodeTags einbetten.
            javascript-Adapter mal rebuildet?
            Alternativ deinstalliert und wieder drauf?
            iobroker rebuild javascript
            iobroker del javascript
            iobroker install javascript
            heinhanH K 2 Antworten Letzte Antwort
              @heinhan
              heinhanH Offline
              heinhanH Offline
              heinhan
              Hier die LOG´s
              pi@raspberrypi:~ $ iobroker rebuild javascript
              npm rebuild --loglevel error (System call1) in "/opt/iobroker/node_modules/iobroker.javascript"
              Rebuild javascript done
              pi@raspberrypi:~ $ iobroker del javascript
              Delete adapter "javascript"
              host.raspberrypi Counted 1 instances of javascript
              host.raspberrypi Counted 1 meta of javascript
              host.raspberrypi Counted 1 adapter for javascript
              host.raspberrypi Counted 2 channels of javascript
              host.raspberrypi Counted 386 states of javascript
              host.raspberrypi Counted 16 states of system.adapter.javascript
              host.raspberrypi Counted 294 states (io.javascript.*) from states
              host.raspberrypi Counted 17 states (system.adapter.javascript.*) from states
              host.raspberrypi Counted 2 objects of javascript
              host.raspberrypi file javascript.admin deleted
              host.raspberrypi object javascript deleted
              host.raspberrypi object javascript.admin deleted
              host.raspberrypi Deleting 409 object(s).
              host.raspberrypi: Only 400 objects left to be deleted.
              host.raspberrypi: Only 200 objects left to be deleted.
              host.raspberrypi Deleting 311 state(s).
              host.raspberrypi: Only 200 states left to be deleted.
              npm uninstall iobroker.javascript --loglevel error --prefix "/opt/iobroker" (System call)
              node-aead-crypto not needed on this system, since all ciphers are natively supported
              node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v72-linux-glibc-arm.tar.gz
              Package pixman-1 was not found in the pkg-config search path.
              Perhaps you should add the directory containing `pixman-1.pc'
              to the PKG_CONFIG_PATH environment variable
              No package 'pixman-1' found
              gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
              gyp ERR! configure error
              gyp ERR! stack Error: `gyp` failed with exit code: 1
              gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
              gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
              gyp ERR! System Linux 5.10.43-v7l+
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
              gyp ERR! cwd /opt/iobroker/node_modules/canvas
              gyp ERR! node -v v12.22.5
              gyp ERR! node-gyp -v v5.1.0
              gyp ERR! not ok
              node-pre-gyp ERR! build error
              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
              node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
              node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
              node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
              node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
              node-pre-gyp ERR! System Linux 5.10.43-v7l+
              node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
              node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
              node-pre-gyp ERR! node -v v12.22.5
              node-pre-gyp ERR! node-pre-gyp -v v1.0.5
              node-pre-gyp ERR! not ok
              Nach der erneuten Installierung läuft der Adapter/Instanz wieder. Leider fehlen mir jetzt noch die Einträge der zusätzlichen NPM-Module. Leider wurden die nicht mit dem Java-Backup mit eingespielt. Hast Du eine Idee ob die noch irgendwo in einer Datei vorhanden sind?
              Thomas BraunT paul53P 2 Antworten Letzte Antwort
              • heinhanH heinhan
                Hier die LOG´s
                gyp ERR! not ok
                @heinhan sagte in JavaScript startet nicht mehr nach Update:
                Nein, weiß ich nicht.
                Bezüglich:
                würde ich mal
                iobroker stop
                iobroker fix
                iobroker start
                aufrufen. Das könnte die Meldung evtl. beheben.
                • heinhanH heinhan
                  Hier die LOG´s
                  gyp ERR! not ok
                  @heinhan sagte: NPM-Module... irgendwo in einer Datei vorhanden sind?
                  Im Objekt "system.adapter.javascript.0", Eigenschaft native.libraries.
                    @heinhan
                    kaybau
                    @thomas-braun ,
                    Hallo Thomas,
                    bei mir hat es nach einem Stromausfall ebenfalls die JS Instanz mit ähnlichen Fehlern zum Erliegen gebracht.
                    Mit den Befehlen
                    gehen aber nicht die scripte verloren, oder?
                    • K kaybau
                      @thomas-braun ,
                      Hallo Thomas,
                      Mit den Befehlen
                      @kaybau
                      Nein. Und außerdem hast du ja ein Backup.
                      K 1 Antwort Letzte Antwort
                        @kaybau
                        kaybau
                        Danke. läuft wieder ;)
                        ich muss unbedingt eine USV davor schalten.
