  4. Datentypen bei mehreren Adaptern nicht mehr korrekt
    6.6k
10 Beiträge 4 Kommentatoren 1.1k Aufrufe 4 Beobachtet
    Matzinger
    seit einigen Wochen sind plötzlich bei vielen Adaptern lt. log die Datentypen nicht mehr korrekt:
    wolf.0	2021-08-02 09:56:43.890	info	(1616) State value to set for "wolf.0.hg1.197" has to be type "state" but received type "number"
    javascript.0	2021-08-02 09:56:41.691	warn	(1719) at processImmediate (internal/timers.js:456:21)
    javascript.0	2021-08-02 09:56:41.691	warn	(1719) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    javascript.0	2021-08-02 09:56:41.690	warn	(1719) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:502:29)
    javascript.0	2021-08-02 09:56:41.690	warn	(1719) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1075:38)
    javascript.0	2021-08-02 09:56:41.689	warn	(1719) at Object.<anonymous> (script.js.common.LoxBettboden:18:5)
    javascript.0	2021-08-02 09:56:41.689	warn	(1719) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
    javascript.0	2021-08-02 09:56:41.687	warn	(1719) You are assigning a string to the state "deconz.0.Lights.6.xy" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an erro
    javascript.0	2021-08-02 09:56:41.678	warn	(1719) at processImmediate (internal/timers.js:456:21)
    javascript.0	2021-08-02 09:56:41.678	warn	(1719) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    javascript.0	2021-08-02 09:56:41.677	warn	(1719) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:502:29)
    javascript.0	2021-08-02 09:56:41.677	warn	(1719) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1075:38)
    javascript.0	2021-08-02 09:56:41.677	warn	(1719) at Object.<anonymous> (script.js.common.LoxBettboden:18:5)
    javascript.0	2021-08-02 09:56:41.676	warn	(1719) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
    javascript.0	2021-08-02 09:56:41.674	warn	(1719) You are assigning a string to the state "deconz.0.Lights.6.xy" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an erro
    javascript.0	2021-08-02 09:56:41.672	warn	(1719) at processImmediate (internal/timers.js:456:21)
    javascript.0	2021-08-02 09:56:41.671	warn	(1719) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    javascript.0	2021-08-02 09:56:41.671	warn	(1719) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:502:29)
    javascript.0	2021-08-02 09:56:41.671	warn	(1719) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1075:38)
    javascript.0	2021-08-02 09:56:41.671	warn	(1719) at Object.<anonymous> (script.js.common.LoxBettboden:18:5)
    javascript.0	2021-08-02 09:56:41.670	warn	(1719) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
    javascript.0	2021-08-02 09:56:41.669	warn	(1719) You are assigning a string to the state "deconz.0.Lights.6.xy" which expects a object. Please fix your code to use a object or change the state type to string. This warning might become an erro
    wolf.0	2021-08-02 09:56:40.863	info	(1616) State value to set for "wolf.0.cwl.162" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:56:39.402	info	(1616) State value to set for "wolf.0.cwl.161" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:56:32.038	info	(1616) State value to set for "wolf.0.cwl.157" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:56:31.885	info	(1616) State value to set for "wolf.0.cwl.156" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:56:11.439	info	(1616) State value to set for "wolf.0.hg1.7" has to be type "state" but received type "number"
    wolf.0	2021-08-02 09:56:10.978	info	(1616) State value to set for "wolf.0.hg1.4" has to be type "state" but received type "number"
    wolf.0	2021-08-02 09:56:10.838	info	(1616) State value to set for "wolf.0.hg1.3" has to be type "state" but received type "number"
    unifi.0	2021-08-02 09:56:05.231	info	(3114) Update done
    unifi.0	2021-08-02 09:56:05.002	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:f0:15:30.system-stats.uptime" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.945	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:f0:15:30.sys_stats.loadavg_1" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.888	info	(3114) State value to set for "unifi.0.default.devices.80:2a:a8:d6:e2:1d.system-stats.uptime" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.883	info	(3114) State value to set for "unifi.0.default.devices.80:2a:a8:d6:e2:1d.system-stats.cpu" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.877	info	(3114) State value to set for "unifi.0.default.devices.80:2a:a8:d6:e2:1d.sys_stats.loadavg_5" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.830	info	(3114) State value to set for "unifi.0.default.devices.80:2a:a8:d6:e2:1d.sys_stats.loadavg_1" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.717	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:80:44:5a.system-stats.uptime" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.712	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:80:44:5a.system-stats.mem" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.707	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:80:44:5a.system-stats.cpu" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.697	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:80:44:5a.sys_stats.loadavg_5" has to be type "number" but received type "string"
    unifi.0	2021-08-02 09:56:04.692	info	(3114) State value to set for "unifi.0.default.devices.78:8a:20:80:44:5a.sys_stats.loadavg_1" has to be type "number" but received type "string"
    wolf.0	2021-08-02 09:55:23.221	info	(1616) State value to set for "wolf.0.cwl.162" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:55:23.069	info	(1616) State value to set for "wolf.0.cwl.161" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:55:22.437	info	(1616) State value to set for "wolf.0.cwl.157" has to be type "state" but received type "string"
    wolf.0	2021-08-02 09:55:22.283	info	(1616) State value to set for "wolf.0.cwl.156" has to be type "state" but received type "string"
    Geändert habe ich eigentlich nichts, schon gar nicht bei allen Adaptern, die liefen davor seit Monaten ohne Probleme.
    Ich finde den Fehler einfach nicht. Vor allem sehr nervig, weil ich teilweise nun meine Zigbee Lampen nicht mehr steuern kann.
    Weiss jemand, woher das kommt und wie man das wieder beheben kann?
    Danke vorab!
    Matthias
    AsgothianA OliverIOO 2 Antworten Letzte Antwort
    • M Matzinger
      Danke vorab!
      Matthias
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @matzinger sagte in Datentypen bei mehreren Adaptern nicht mehr korrekt:
      eigentlich nichts gibt es nicht.
      Du musst etwas geändert haben. Welche Adapter hast du in den letzten Wochen aktualisiert ?
      A.
      Nachtrag: Du schreibst "seit einigen Wochen". Wichtig ist was Du aktualisiert hast als diese Meldungen angefangen haben.
      • M Matzinger
        Danke vorab!
        Matthias
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @matzinger
        du hast den iobroker controler aktualisiert.
        In einer der letzten Versionen sind zusätzliche Überprüfungen eingebaut worden, wie Adapter mit den datenpunkten umzugehen haben.
        https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable
        der optimale weg dies zu melden ist, den adapter auf github zu suchen, zu prüfen ob da bereits ein fehler dazu angemeldet wurde und wenn nicht einen eintragen.
        Beispiel hier:
        https://github.com/ioBroker/ioBroker.wolf/issues/44
        Aktuell sind das nur Warnungen und dürfte auf die Funktionsfähigkeit des Adapters keinen Einfluss haben.
        Wenn das allerdings nicht behoben wird, dann wird in einer der späteren Versionen von iobroker der jeweilige Adapter nicht mehr funktionieren.
        Meine Adapter und Widgets
        Links im Profil
        • AsgothianA Asgothian
          A.
          Matzinger
          @asgothian ja also regelmäßig aktualisieren tue ich natürlich.
          Wann die Meldungen angefangen haben, weiss ich leider nicht genau
          • OliverIOO OliverIO
            @matzinger
            Beispiel hier:
            Matzinger
            @oliverio also hat es evtl. gar nichts mit meiner Installation zu tun, sondern mit IObroker generell?
            Das beruhigt mich erstmal. Ich schaue mir die github Seiten der Adapter mal an.
            Danke!
            • M Matzinger
              Danke!
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              Danke!
              sehe gerade, das ein Teil der Meldungen vom javascript-adapter kommt.
              Du solltest mal dein Skript LoxBettboden in Zeile 18 überprüfen.
              dort schreibst du
              in den datenpunkt wolf.0.hg1.197 eine Nummer obwohl es ein state sein sollte
              in den datenpunkt deconz.0.Lights.6.xy schreibst du einen string/text und es sollte ein objekt sein.
              was du genau reinscheiben musst, musst du in die doku des jeweiligen adapters nachschlagen.
              Links im Profil
              AlCalzoneA M 2 Antworten Letzte Antwort
                Danke!
                dort schreibst du
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @oliverio sagte in Datentypen bei mehreren Adaptern nicht mehr korrekt:
                Das ist dennoch ein Bug im Adapter. Einen Type "state" gibt es nicht. Eine Zahl reinzuschreiben, ist vermutlich richtig.
                  Danke!
                  dort schreibst du
                  Matzinger
                  @oliverio also beim Datenpunkt vom Wolf Adapter habe ich kein Script laufen.
                  Beim Deconz (xy) Datenpunkt schon. Genau da komme ich nicht weiter. Er will einen Wert vom Typ "object" haben. Bisher war ein String immer okay, habe am Script nichts verändert.
                  Also wie bekomme ich einen "object" Wert übergeben? Oder ist das ein bug im Adapter?
                  Matthias
                  OliverIOO AlCalzoneA 2 Antworten Letzte Antwort
                  • M Matzinger
                    Matthias
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    Matthias
                    da musst du die Leute vom adapter fragen.
                    ich nutze die beiden adapter nicht.
                    Links im Profil
                    • M Matzinger
                      Matthias
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      Was schreibst du denn genau in den Datenpunkt?
