  4. setObject in Js-Adapter
    6.4k
3 Beiträge 3 Kommentatoren 336 Aufrufe 2 Beobachtet
  • CreamyCewie22C Offline
    CreamyCewie22
    Ich Versuche im Js-Adapter das Modul "setObject" hinzuzufügen.
    Nach dem Neustart des Adapters ist alles grün, im iobroker-Log sehe ich jedoch folgenden Fehler:
    javascript.0 2021-07-11 20:17:32.440 error (9706) Cannot install npm packet: setObject
    javascript.0 2021-07-11 20:17:32.439 error (9706) Cannot install setObject: 1
    javascript.0 2021-07-11 20:17:32.428 error npm ERR! /home/iobroker/.npm/_logs/2021-07-11T18_17_32_416Z-debug.log
    javascript.0 2021-07-11 20:17:32.428 error (9706) npm ERR! A complete log of this run can be found in:
    javascript.0 2021-07-11 20:17:32.426 error (9706)
    javascript.0 2021-07-11 20:17:32.415 error npm ERR! 404 tarball, folder, http url, or git url.
    javascript.0 2021-07-11 20:17:32.415 error npm ERR! 404 Note that you can also install from a
    javascript.0 2021-07-11 20:17:32.415 error npm ERR! 404 1. name can no longer contain capital letters
    javascript.0 2021-07-11 20:17:32.415 error npm ERR! 404 Your package name is not valid, because
    javascript.0 2021-07-11 20:17:32.415 error npm ERR! 404 'setObject@latest' is not in the npm registry.
    javascript.0 2021-07-11 20:17:32.415 error (9706) ERR! 404 Not Found - GET https://registry.npmjs.org/setObject - Not found
    javascript.0 2021-07-11 20:17:32.412 error (9706) npm
    javascript.0 2021-07-11 20:17:32.403 error (9706) ERR! code E404
    javascript.0 2021-07-11 20:17:32.401 error (9706) npm
    javascript.0 2021-07-11 20:17:30.459 info (9706) npm install setObject --production (System call)
    Inhalt der Log-Datei:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli '/usr/bin/node',
    1 verbose cli '/usr/bin/npm',
    1 verbose cli 'install',
    1 verbose cli 'setObject',
    1 verbose cli '--production'
    1 verbose cli ]
    2 info using npm@6.14.12
    3 info using node@v12.22.1
    4 verbose npm-session f96373c813c83a9e
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 404 https://registry.npmjs.org/setObject 209ms
    8 http fetch GET 404 https://registry.npmjs.org/setObject 42ms
    9 silly fetchPackageMetaData error for setObject@latest 404 Not Found - GET htt$
    10 timing stage:rollbackFailedOptional Completed in 3ms
    11 timing stage:runTopLevelLifecycles Completed in 647ms
    12 verbose stack at processTicksAndRejections (internal/process/task_queues$
    13 verbose statusCode 404
    14 verbose pkgid setObject@latest
    15 verbose cwd /opt/iobroker/node_modules/iobroker.javascript
    16 verbose Linux 5.10.17-v7l+
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "setObject" "--product$
    18 verbose node v12.22.1
    19 verbose npm v6.14.12
    20 error code E404
    21 error 404 Not Found - GET https://registry.npmjs.org/setObject - Not found
    22 error 404
    23 error 404 'setObject@latest' is not in the npm registry.
    24 error 404 Your package name is not valid, because
    25 error 404 1. name can no longer contain capital letters
    26 error 404 Note that you can also install from a
    27 error 404 tarball, folder, http url, or git url.
    28 verbose exit [ 1, true ]
    Wo könnte hier das Problem liegen?
    LG Creamy
    AsgothianA paul53P 2 Antworten Letzte Antwort
    • CreamyCewie22C CreamyCewie22
      1 verbose cli [
      1 verbose cli ]
      20 error code E404
      22 error 404
      LG Creamy
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @creamycewie22 sagte in setObject in Js-Adapter:
      Steht da doch.
      • Der Paketname darf keine Gross/Kleinschreibung beinhalten.
      • Es gibt kein Paket namens setobject in der npm Registry.
      A.
        1 verbose cli [
        1 verbose cli ]
        20 error code E404
        22 error 404
        LG Creamy
        @creamycewie22 sagte: das Modul "setObject" hinzuzufügen.
        setObject() ist kein Modul, sondern eine Funktion des Javascript-Adapters, die mit einem Haken in der Konfiguration freigegeben werden muss, wenn man sie verwenden will. Allerdings sollte man bei Verwendung von setObject() genau wissen, was man tut.
