  4. viele WARN seit Systemwechsel
    6.4k
7 Beiträge 3 Kommentatoren 664 Aufrufe 3 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Platform: linux
    os: linux
    Architecture: x64
    CPUs: 2
    Speed: 3547 MHz
    Model: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
    RAM: 6 GB
    System uptime: 1 T. 12:37:13
    Node.js: v14.17.1
    NPM: 6.14.13
    Disk size: 9.8 GiB
    Disk free: 3.7 GiB
    adapters count: 421
    Uptime: 1 T. 08:42:02
    Active instances: 54
    Hallo
    Seit dem Umzug von Synology Docker auf Proxmox (ioB als VM) hab ich viele Warn-Meldungen im Log.
    Unter anderem zB
    web.0	2021-07-07 22:08:25.904	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "182"
    web.0	2021-07-07 22:08:22.179	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "177"
    web.0	2021-07-07 22:08:12.292	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "165"
    web.0	2021-07-07 22:08:12.230	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "165"
    javascript.0	2021-07-07 22:08:08.070	warn	(10263) Read-only state "javascript.0.FensterUeberwachung.OverviewTable" has been written without ack-flag with value "<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><
    web.0	2021-07-07 22:08:06.122	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "161"
    web.0	2021-07-07 22:08:02.183	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "155"
    javascript.0	2021-07-07 22:08:00.214	warn	(10263) at processTimers (internal/timers.js:500:7)
    javascript.0	2021-07-07 22:08:00.214	warn	(10263) at listOnTimeout (internal/timers.js:557:17)
    javascript.0	2021-07-07 22:08:00.214	warn	(10263) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:510:7)
    javascript.0	2021-07-07 22:08:00.214	warn	(10263) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:552:11
    javascript.0	2021-07-07 22:08:00.214	warn	(10263) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2021-07-07 22:08:00.214	warn	(10263) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1301:34)
    javascript.0	2021-07-07 22:08:00.213	warn	(10263) at Object.<anonymous> (script.js.Fritz.Fritz-Onlinezeit:7:27)
    javascript.0	2021-07-07 22:08:00.213	warn	(10263) getState "tr-064.0.states.externalIP" not found (3)
    web.0	2021-07-07 22:07:54.301	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "150"
    web.0	2021-07-07 22:07:51.195	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "144"
    web.0	2021-07-07 22:07:41.282	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "137"
    web.0	2021-07-07 22:07:38.186	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "132"
    web.0	2021-07-07 22:07:31.664	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "127"
    web.0	2021-07-07 22:07:28.193	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "121"
    web.0	2021-07-07 22:07:20.365	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "116"
    web.0	2021-07-07 22:07:17.180	warn	(19967) Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "110"
    Ich hab ein Backup (mit Backitup erstellt) zurückgespielt.
    Es läuft eigentlich alles, bis auf diese Menge Warn-Meldungen.
    Log wird täglich ca. 50 MB groß 😖
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      Platform: linux
      os: linux
      Architecture: x64
      CPUs: 2
      Speed: 3547 MHz
      RAM: 6 GB
      Node.js: v14.17.1
      NPM: 6.14.13
      Disk size: 9.8 GiB
      Disk free: 3.7 GiB
      adapters count: 421
      Hallo
      Unter anderem zB
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      schrieb am zuletzt editiert von Feuersturm
      @negalein Hi, du nutzt wohl den js-controller 3.3.x der noch im beta Stadium ist (https://forum.iobroker.net/topic/44624/js-controller-3-3-jetzt-im-beta)
      Die Warnungen müssen durch Anpassung in den entsprechenden Adaptern / Skripten gelöst werden. Schau am besten einmal nach, ob es bei den entsprechenden Adaptern auf GitHub schon passende issues gibt.
      Wenn es entsprechende issues gibt kannst du auch temporär das log Level auf error hochsetzen, bis die Adapter aktualisiert wurden.
      • FeuersturmF Feuersturm
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @feuersturm sagte in viele WARN seit Systemwechsel:
        Ja, den 3.3.14
        Dann werd ich mal Git durchforsten.
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          Es dürfte an VIS liegen.
          Aber @apollon77 weiß auch gerade nicht weiter.
          Vielleicht hat noch jemand eine Idee?
            @negalein Ich würde hjetzt sagen ... zeig doch mal die Konfig des Vis Widgets was die mediaProgress anzeigt ... weil irgendwie muss das ja aus versehen schreiben
            • apollon77A apollon77
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @apollon77 sagte in viele WARN seit Systemwechsel:
              [{"tpl":"tplValueString","data":{"oid":"alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgressStr","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Buchenweg/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Buchenweg/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Buchenweg/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"","html_prepend":"","class":"mdui-blue-glow"},"style":{"left":"354px","top":"503px","color":"#ffffff","width":"78px","height":"37px","text-align":"left","font-style":"normal","font-size":"x-large","z-index":"58","font-weight":"bold","font-family":"RobotoCondensed-Light","text-shadow":"rgba(0, 0, 0, 0.9) 3px 3px 4px"},"widgetSet":"basic"}]
              • NegaleinN Offline
                NegaleinN Offline
                Negalein
                @apollon77
                fast 2 Monate war Ruhe.
                Heute wieder selbes Problem.
                web.0 2021-08-24 22:01:47.187	warn	Read-only state "alexa2.0.Echo-Devices.G090U5099045059V.Player.mediaProgress" has been written without ack-flag with value "210"
