  3. Entwicklung
  4. Admin 5 UI Anpassung
    5.4k
1 Beiträge 1 Kommentatoren 292 Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    weggetor
    Hi folks,
    gibt es irgendwo einen Link zu einem HowTo wie man die Admin-Oberfläche Admin5-fähig macht ? Wird für meinen Adapter unter Admin 5.2.1 schon richtig angezeigt, aber vielleicht muss ich da noch was extra machen ?
    Der aktuelle code für index_m.html:
    <html>
    <head>
        <!-- Load ioBroker scripts and styles-->
        <link rel="stylesheet" type="text/css" href="../../css/adapter.css" />
        <link rel="stylesheet" type="text/css" href="../../lib/css/materialize.css">
        <script type="text/javascript" src="../../lib/js/jquery-3.2.1.min.js"></script>
        <script type="text/javascript" src="../../socket.io/socket.io.js"></script>
        <script type="text/javascript" src="../../js/translate.js"></script>
        <script type="text/javascript" src="../../lib/js/materialize.js"></script>
        <script type="text/javascript" src="../../js/adapter-settings.js"></script>
        <!-- Load our own files -->
        <link rel="stylesheet" type="text/css" href="style.css" />
        <script type="text/javascript" src="words.js"></script>
        <script type="text/javascript">
            // This will be called by the admin adapter when the settings page loads
            function load(settings, onChange) {
                // example: select elements with id=key and class=value and insert value
                if (!settings) return;
                $('.value').each(function () {
                    var $key = $(this);
                    var id = $key.attr('id');
                    if ($key.attr('type') === 'checkbox') {
                        // do not call onChange direct, because onChange could expect some arguments
                        $key.prop('checked', settings[id])
                            .on('change', () => onChange())
                    } else {
                        $key.val(settings[id])
                            .on('keyup', () => onChange())
                onChange(false);
                // reinitialize all the Materialize labels on the page if you are dynamically adding inputs:
                if (M) M.updateTextFields();
            // This will be called by the admin adapter when the user presses the save button
            function save(callback) {
                // example: select elements with class=value and build settings object
                var obj = {};
                    var $this = $(this);
                    if ($this.attr('type') === 'checkbox') {
                        obj[$this.attr('id')] = $this.prop('checked');
                    } else if ($this.attr('type') === 'number') {
                        obj[$this.attr('id')] = parseFloat($this.val());
                    } else {
                        obj[$this.attr('id')] = $this.val();
                callback(obj);
        </script>
    </head>
    <body>
        <div class="m adapter-container">
            <div class="row">
                <div class="col s12 m4 l2">
                    <img src="airconwithme.png" class="logo">
                </div>
            </div>
            <!-- Put your content here -->
            <!-- For example columns with settings: -->
            <div class="row">
                <div class="col s4 input-field">
                    <input type="text" class="value" id="ipaddress" />
                    <label for="ipaddress" class="translate">IP Address</label>
                    <span class="translate">IP Address of the Mitsubishi WLAN adapter</span>
                </div>
                    <input type="text" class="value" id="username" />
                    <label for="username" class="translate">Username</label>
                    <span class="translate">Username for login on adapter website (default:admin)</span>
                </div>
                    <input type="password" class="value" id="password" />
                    <label for="password" class="translate">Password</label>
                    <span class="translate">Password for login on adapter website (default:admin)</span>
                </div>
            </div>
        </div>
    </body>
    </html>
