  4. Warning im Script?
Warning im Script?
5 Beiträge 2 Kommentatoren 418 Aufrufe 1 Beobachtet
  • hg6806H Offline
    hg6806H Offline
    hg6806
    schrieb am zuletzt editiert von hg6806
    habe hier immer ein Warning:
    21:13:33.999	warn	javascript.0 (1386) at Object.<anonymous> (script.js.common.Sonstiges.Pool-Solar_aktivieren:8:5)
    on({id: "mqtt.0.Wemos9-Pool.Pool-Solar-Temp.Pool-Solar-Temp"/*/Wemos9-Pool/Pool-Solar-Temp/Pool-Solar-Temp*/, change: "ne"}, async function (obj) {
      var value = obj.state.val;
      if (getState("mqtt.0.Wemos9-Pool.Pool-Solar-Temp.Pool-Solar-Temp").val > getState("mqtt.0.Wemos9-Pool.Pooltemperatur.Pooltemperatur").val + 1) {
        setState("mqtt.0.Wemos9-Pool.Poolpumpe2.GPIO.4"/*/Wemos9-Pool/Poolpumpe2/GPIO/4*/, 0);
      if (getState("mqtt.0.Wemos9-Pool.Pool-Solar-Temp.Pool-Solar-Temp").val < getState("mqtt.0.Wemos9-Pool.Pooltemperatur.Pooltemperatur").val + 0.2) {
        setState("mqtt.0.Wemos9-Pool.Poolpumpe2.GPIO.4"/*/Wemos9-Pool/Poolpumpe2/GPIO/4*/, 1);
    Woher kommt das?
    F 1 Antwort Letzte Antwort
    • hg6806H hg6806
      Woher kommt das?
      F Online
      F Online
      fastfoot
      @hg6806 Im LOG Tab findest du mehr Info dazu
      iobroker läuft unter Docker auf Windows (WSL2)
      hg6806H 1 Antwort Letzte Antwort
      • F fastfoot
        hg6806H Offline
        hg6806H Offline
        hg6806
        @fastfoot
        javascript.0
        2021-06-17 21:29:47.978	warn	at processImmediate (internal/timers.js:461:21)
        javascript.0
        2021-06-17 21:29:47.978	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5555:41)
        javascript.0
        2021-06-17 21:29:47.978	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:502:29)
        javascript.0
        2021-06-17 21:29:47.977	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1075:38)
        javascript.0
        2021-06-17 21:29:47.977	warn	at Object.<anonymous> (script.js.common.Sonstiges.Pool-Solar_aktivieren:8:5)
        javascript.0
        2021-06-17 21:29:47.977	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1427:20)
        javascript.0
        2021-06-17 21:29:47.975	warn	You are assigning a number to the state "mqtt.0.Wemos9-Pool.Poolpumpe2.GPIO.4" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions
        Das sind ala Warning zu Javascript
        • hg6806H hg6806
          @fastfoot
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          F Online
          F Online
          fastfoot
          schrieb am zuletzt editiert von fastfoot
          @hg6806 die Warnung besagt dass ein Text erwartet wird, keine Zahl. Probiere also Steuern mit "0" und "1" anstatt 0 und 1
          • F fastfoot
            hg6806H Offline
            hg6806H Offline
            hg6806
            @fastfoot
            Danke sieht gut aus.
