  4. [Frage] zu Log File Einträgen - sql history
8 Beiträge 4 Kommentatoren 1.1k Aufrufe
  • nieIPN Offline
    nieIPN Offline
    nieIP
    Hallo
    folgende Zeilen "WARNING" habe ich im Log File, wenn ich den sql Adapter neu starte.
    Ich verstehe, das etwas nicht gefunden wurde, aber was ??
    host.raspi-3	2017-01-22 00:17:14.592	warn	stopInstance system.adapter.dwd.0 not scheduled
    host.raspi-3	2017-01-22 00:17:14.591	info	stopInstance system.adapter.dwd.0
    host.raspi-3	2017-01-22 00:17:14.590	info	"system.adapter.dwd.0" disabled
    host.raspi-3	2017-01-22 00:17:14.590	info	object change system.adapter.dwd.0
    WARNING:	2017-01-22 00:17:09.222	error	cannot find logs with id = 80334195
    WARNING:	2017-01-22 00:17:08.869	error	cannot find logs with id = 80332676
    WARNING:	2017-01-22 00:17:08.781	error	cannot find logs with id = 80332596
    WARNING:	2017-01-22 00:17:08.766	error	cannot find logs with id = 80332586
    WARNING:	2017-01-22 00:17:08.071	error	cannot find logs with id = 80332462
    sql.0	2017-01-22 00:17:05.688	info	Connected to mysql
    sql.0	2017-01-22 00:17:05.670	info	enabled logging of hm-rpc.1.000313C9906EDE.1.ACTUAL_TEMPERATURE
    sql.0	2017-01-22 00:17:05.669	info	enabled logging of hm-rpc.1.000393C98D1E6A.1.SET_POINT_TEMPERATURE
    sql.0	2017-01-22 00:17:05.669	info	enabled logging of hm-rpc.1.0000D3C98C9B3A.1.STATE
    sql.0	2017-01-22 00:17:05.669	info	enabled logging of hm-rpc.1.0001D3C990BF8F.6.VOLTAGE
    sql.0	2017-01-22 00:17:05.668	info	enabled logging of hm-rega.0.25660
    • apollon77A Offline
      Diese Warnings kommen von Messages aus dem System.
      Kommt das IMMER wenn du sql neustartest?
      Nimmst Du Redis? Starte des Redis mal neu …
      • nieIPN Offline
        nieIPN Offline
        nieIP
        Hallo
        ja die Meldungen kommen immer.
        Keine Ahnung was "Redis" ist.
        raspi-3	2017-01-22 22:47:56.204	error	WARNING: cannot find logs with id = 80335670
        raspi-3	2017-01-22 22:47:55.845	error	WARNING: cannot find logs with id = 80335334
        raspi-3	2017-01-22 22:47:55.720	error	WARNING: cannot find logs with id = 80335323
        raspi-3	2017-01-22 22:47:55.714	error	WARNING: cannot find logs with id = 80335322
        raspi-3	2017-01-22 22:47:55.712	error	WARNING: cannot find logs with id = 80335321
        raspi-3	2017-01-22 22:47:55.709	error	WARNING: cannot find logs with id = 80335320
        raspi-3	2017-01-22 22:47:55.707	error	WARNING: cannot find logs with id = 80335319
        raspi-3	2017-01-22 22:47:54.832	error	WARNING: cannot find logs with id = 80334928
        sql.0	2017-01-22 22:47:53.910	info	sql.0 Connected to mysql
          Kann mir nicht erklären wo das herkommt …
          @Bluefox: Irgendeine Idee?
          • GoerschG Offline
            GoerschG Offline
            Goersch
            hier gleiches Problem - nach iobroker restart wieder OK
            Änderung, bevor die ganzen log-Ausgaben kommen:
            • zweite javascript instanz auf einem zweiten raspi angelegt (javascript.0 auf raspi1/javascript.1 auf raspi2)
            • ein script in die instanz javascript.1 verschoben
            • ping-Instanz auch dem raspi2 zugeordnet
            dann kommen relativ schnell viele Meldungen in der Form
            ` > 2017-04-06 17:40:01.955 - [32minfo[39m: javascript.0 Start javascript script.js.common.Heizung.Einstellungen
            2017-04-06 17:40:02.018 - [31merror[39m: javascript.0 script.js.common.Heizung.Einstellungen: Cannot use sync getState, use callback instead getState("javascript.0.Heizung.Einstellungen.Raum", function (err, state){});
            2017-04-06 17:40:02.032 - [31merror[39m: javascript.0 script.js.common.Heizung.Einstellungen: TypeError: Cannot read property 'val' of undefined
            at ladeRaumEinstellungen (script.js.common.Heizung.Einstellungen:151:32)
            at script.js.common.Heizung.Einstellungen:229:1 `
            bis dann diese Ausgaben anfangen
            ` > 2017-04-06 18:29:33.705 - [31merror[39m: admin.0 WARNING: cannot find log with id = 61173598
            2017-04-06 18:29:33.706 - [31merror[39m: admin.0 WARNING: cannot find log with id = 14111021
            2017-04-06 18:29:33.706 - [31merror[39m: admin.0 WARNING: cannot find log with id = 8734500
            2017-04-06 18:29:33.708 - [31merror[39m: admin.0 WARNING: cannot find log with id = 30731845
            2017-04-06 18:29:33.708 - [31merror[39m: admin.0 WARNING: cannot find log with id = 71745564 `
            • kmxakK Offline
              kmxakK Offline
              kmxak
              (achtung anfänger versucht zu helfen :mrgreen: )
              Also ich vermute hier einen Fehler im javascript.
              Und der SQL Adapter versucht einen Eintrag zu finden den es nicht gibt. Vermutlich durch einen Script fehler.
              Ich würde das Script common.Heizung.Einstellungen mal durchgehen ob da alles passt
              Gruß Alex
              • GoerschG Offline
                GoerschG Offline
                Goersch
                da passt alles - das Skript funktioniert fehlerfrei. Die Fehlermeldungen traten leider auch bei anderen Skripten auf. Nach dem restart vom iobroker war auch alles wieder ok.
                • GoerschG Offline
                  GoerschG Offline
                  Goersch
                  nun ähnlicher Fehler (zumindestens die ganzen callback Fehler werden ausgegeben - nicht nur beim Skript im Beispiel):
                  ` > 2017-04-07 14:21:32.800 - [32minfo[39m: javascript.0 Start javascript script.js.common.Allgemein.GMPS
                  2017-04-07 14:21:32.807 - [31merror[39m: javascript.0 script.js.common.Allgemein.GMPS: Cannot use sync getState, use callback instead getState("javascript.0.GMPS.Aufwachzeit", function (err, state){});
                  2017-04-07 14:21:32.810 - [31merror[39m: javascript.0 script.js.common.Allgemein.GMPS: TypeError: Cannot read property 'val' of undefined
                  at initWOL (script.js.common.Allgemein.GMPS:110:38)
                  at script.js.common.Allgemein.GMPS:107:1 `
                  Was habe ich geändert:
                  • in der Instanz javascript.0 den Parameter "Nicht auf alle Zustände beim Start abonieren" aktiviert
                  • danach hat sich die Instanz neugestartet und dann fing der Fehlermeldeschwal an
                  nach "iobroker restart" wieder alles ok
                  82.8k
