  4. Probleme nach Update des KNX Adapters auf 1.0.45
5 Beiträge 3 Kommentatoren 457 Aufrufe 2 Beobachtet
    petkoh
    schrieb am zuletzt editiert von petkoh
    ich habe Probleme nach dem Update des KNX-Adapters auf 1.0.45: Die Werte der Objekte werden nicht mehr geupdated.
    Hier ein Auszug aus der Log-Datei über eine Minute:
    2021-05-17 21:13:00.987 - info: knx.0 (12858) starting. Version 1.0.45 in /opt/iobroker/node_modules/iobroker.knx, node: v12.20.1, js-controller: 3.2.16
    2021-05-17 21:13:03.002 - info: knx.0 (12858) knx license is OK.
    2021-05-17 21:13:03.030 - info: knx.0 (12858) Connecting to knx GW: 192.168.2.10:3671 with phy. Adr: 1.0.2
    2021-05-17 21:13:03.106 - info: knx.0 (12858) Debuglevel: 2 3
    2021-05-17 21:13:03.145 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:03.189 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:41347
    2021-05-17 21:13:03.214 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f a1 83 08 01 00 00 00 00 a1 83 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:03.282 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:03.285 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:03.295 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:03.301 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:03.310 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:03.342 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:03.349 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:05.301 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:05.309 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:05.316 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:43251
    2021-05-17 21:13:05.321 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f a8 f3 08 01 00 00 00 00 a8 f3 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:05.329 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:05.332 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:05.339 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:05.343 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:05.347 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:05.355 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:05.360 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:07.345 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:07.351 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:07.355 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:37941
    2021-05-17 21:13:07.359 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f 94 35 08 01 00 00 00 00 94 35 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:07.380 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:07.384 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:07.390 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:07.393 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:07.396 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:07.402 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:07.404 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:09.394 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:09.416 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:09.452 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:53682
    2021-05-17 21:13:09.490 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f d1 b2 08 01 00 00 00 00 d1 b2 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:09.498 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:09.501 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:09.508 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:09.511 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:09.515 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:09.521 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:09.524 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:11.511 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:11.517 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:11.521 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:43469
    2021-05-17 21:13:11.525 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f a9 cd 08 01 00 00 00 00 a9 cd 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:11.531 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:11.533 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:11.540 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:11.542 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:11.545 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:11.552 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:11.554 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:13.542 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:13.550 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:13.556 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:48203
    2021-05-17 21:13:13.560 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f bc 4b 08 01 00 00 00 00 bc 4b 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:13.565 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:13.567 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:13.573 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:13.575 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:13.579 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:13.584 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:13.587 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:15.576 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:15.581 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:15.585 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:48277
    2021-05-17 21:13:15.589 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f bc 95 08 01 00 00 00 00 bc 95 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:15.594 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:15.596 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:15.602 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:15.605 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:15.607 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:15.613 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:15.615 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:17.605 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:17.611 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:17.620 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:59307
    2021-05-17 21:13:17.636 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f e7 ab 08 01 00 00 00 00 e7 ab 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:17.667 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:17.673 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:17.684 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:17.696 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:17.700 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:17.741 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:17.775 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:19.697 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:19.701 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:19.706 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:52020
    2021-05-17 21:13:19.710 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f cb 34 08 01 00 00 00 00 cb 34 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:19.715 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:19.717 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:19.723 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:19.725 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:19.728 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:19.734 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:19.736 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:21.726 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:21.734 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:21.742 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:51668
    2021-05-17 21:13:21.748 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f c9 d4 08 01 00 00 00 00 c9 d4 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:21.756 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:21.759 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:21.768 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:21.771 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:21.775 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:21.784 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:21.787 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:23.771 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:23.776 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:23.780 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:41442
    2021-05-17 21:13:23.784 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f a1 e2 08 01 00 00 00 00 a1 e2 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:23.827 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:23.830 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:23.836 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:23.838 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:23.841 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:23.847 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:23.849 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:25.840 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:25.858 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:25.864 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:36791
    2021-05-17 21:13:25.873 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f 8f b7 08 01 00 00 00 00 8f b7 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:25.881 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:25.885 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:25.895 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:25.898 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:25.904 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:25.914 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:25.917 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:27.902 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:27.919 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:27.937 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:52639
    2021-05-17 21:13:27.943 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f cd 9f 08 01 00 00 00 00 cd 9f 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:27.953 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:27.956 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:27.961 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:27.964 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:27.967 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:27.972 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:27.975 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:29.964 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:29.969 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:29.973 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:53932
    2021-05-17 21:13:29.977 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f d2 ac 08 01 00 00 00 00 d2 ac 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:29.982 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:29.984 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:29.990 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:29.992 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:29.995 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:30.001 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:30.003 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:31.993 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:31.998 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:32.002 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:48587
    2021-05-17 21:13:32.006 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f bd cb 08 01 00 00 00 00 bd cb 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:32.017 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:32.023 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:32.055 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:32.057 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:32.060 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:32.066 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:32.068 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:34.058 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:34.070 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:34.195 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:42366
    2021-05-17 21:13:34.213 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f a5 7e 08 01 00 00 00 00 a5 7e 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:34.306 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:34.308 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:34.314 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:34.320 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:34.323 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:34.340 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:34.343 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:36.321 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:36.326 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:36.330 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:56980
    2021-05-17 21:13:36.333 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f de 94 08 01 00 00 00 00 de 94 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:36.338 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:36.341 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:36.347 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:36.349 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:36.352 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:36.358 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:36.360 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:38.350 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:38.354 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:38.358 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:44048
    2021-05-17 21:13:38.362 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f ac 10 08 01 00 00 00 00 ac 10 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:38.367 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:38.369 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:38.375 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:38.377 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:38.380 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:38.386 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:38.388 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:40.378 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:40.382 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:40.386 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:52741
    2021-05-17 21:13:40.390 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f ce 05 08 01 00 00 00 00 ce 05 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:40.395 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:40.397 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:40.403 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:40.405 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:40.408 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:40.414 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:40.416 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:42.406 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:42.411 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:42.414 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:44867
    2021-05-17 21:13:42.418 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f af 43 08 01 00 00 00 00 af 43 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:42.423 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:42.426 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:42.431 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:42.434 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:42.436 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:42.442 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:42.444 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:44.435 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:44.440 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:44.444 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:37145
    2021-05-17 21:13:44.448 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f 91 19 08 01 00 00 00 00 91 19 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:44.453 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:44.455 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:44.460 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:44.463 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:44.465 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:44.471 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:44.473 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:46.465 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:46.469 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:46.472 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:42110
    2021-05-17 21:13:46.476 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f a4 7e 08 01 00 00 00 00 a4 7e 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:46.567 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:46.569 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:46.575 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:46.577 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:46.579 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:46.586 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:46.588 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:48.577 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:48.581 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:48.585 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:52149
    2021-05-17 21:13:48.588 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f cb b5 08 01 00 00 00 00 cb b5 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:48.593 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:48.594 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:48.600 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:48.602 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:48.604 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:48.610 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:48.612 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:50.604 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:50.616 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:50.621 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:59873
    2021-05-17 21:13:50.635 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f e9 e1 08 01 00 00 00 00 e9 e1 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:50.641 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:50.643 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:50.650 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:50.652 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:50.654 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:50.660 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:50.662 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:52.653 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:52.657 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:52.660 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:50689
    2021-05-17 21:13:52.663 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f c6 01 08 01 00 00 00 00 c6 01 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:52.668 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:52.670 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:52.675 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:52.677 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:52.680 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:52.685 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:52.687 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:54.677 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:54.683 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:54.688 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:46003
    2021-05-17 21:13:54.692 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f b3 b3 08 01 00 00 00 00 b3 b3 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:54.698 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:54.700 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:54.707 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:54.710 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:54.714 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:54.720 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:54.723 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:56.710 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:56.722 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:56.727 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:32834
    2021-05-17 21:13:56.731 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f 80 42 08 01 00 00 00 00 80 42 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:56.736 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:56.738 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:56.745 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:56.748 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:56.751 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:56.758 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:56.761 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:58.749 - info: knx.0 (12858) Using UDP with local IP: 192.168.2.15
    2021-05-17 21:13:58.763 - info: knx.0 (12858) Event : UDP - listening
    2021-05-17 21:13:58.784 - info: knx.0 (12858) Connected - local UDP Server listening on 192.168.2.15:34520
    2021-05-17 21:13:58.789 - info: knx.0 (12858) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 02 0f 86 d8 08 01 00 00 00 00 86 d8 04 04 02 00 sent to 192.168.2.10:3671
    2021-05-17 21:13:58.806 - info: knx.0 (12858) STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECT_RESPONSE(4) to STATE_DISCONNECT_REQUEST(15).
    2021-05-17 21:13:58.808 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:58.821 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:58.838 - info: knx.0 (12858) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
    2021-05-17 21:13:58.857 - info: knx.0 (12858) Connection persists.....closing now
    2021-05-17 21:13:58.872 - info: knx.0 (12858) ... not able to close connection, because already closed
    2021-05-17 21:13:58.963 - info: knx.0 (12858) STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
    Ich hab als schnelle Lösung wieder auf 1.0.39 gedowngraded und alles läuft wieder einwandfrei. Nun ist mir im Log aufgefallen das dort folgende Zeile auftaucht:
    "adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!"
    Was bedeutet das? Deutet das auf den Fehler mit 1.0.45 hin?
    Viele Grüße
    Peter
    • P petkoh
      Viele Grüße
      Peter
      @petkoh
      github:	1.0.45
      latest:	1.0.45 for 55 days
      stable:	1.0.45 for 55 days
      Also einen generellen derartigen Fehler für eine Version die fast 2 Monate stable ist würde ich fast ausschließen.
      Das wird vermutlich ein eher individuelles Problem sein.
      nodeJS und 'der Rest vom Fest' auf Stand gebracht? ioBroker mal neugestartet?
      Auf der anderen Seite:
      https://github.com/ioBroker/ioBroker.knx/issues/155
        tiego
        Ich habe das selbe Problem bei einer Wago als IP Router.
        Die Version 1.0.39 läuft sauber und ohne Probleme auser der Warnung für das "deprecated"
        Bei einem Update auf eine Version > 1.0.39 werden die KNX Werte nicht mehr aktualisiert.
        Node.js v12.22.1
        NPM v6.14.12
        Admin v5.0.28
        Super wenn jemand eine Lösung hätte
        P 2 Antworten Letzte Antwort
        • T tiego
          Node.js v12.22.1
          NPM v6.14.12
          Admin v5.0.28
          petkoh
          @tiego
          @Thomas-Braun
          ich habe sonst alles auf Stand, iobroker auch neu gestartet.
          Es scheint tatsächlich mit derf Wago als IP Router zusammen zu hängen, da ich wie tiego eine Wago nutze.
          Wie könnten wir da weiter kommen?
          • T tiego
            Node.js v12.22.1
            NPM v6.14.12
            Admin v5.0.28
            petkoh
            @tiego
            Hallo Tiego,
            bist du mit dem Problem schon weitergekommen? Ich habe noch keine Lösung finden können.
            Viele Grüße
            Peter
