  4. Zigbee und CC26x2R1 Coordinator mag mich nicht ;-)
21 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
    Rene 1
    Ich brauche mal Hilfe bei der Verbindung von Zigbee und einem CC26x2R1 Coordinator er hat die neuste Koenkk Z Stack 3.x.0 Firmware (Stand 06.04.2021)
    Anschluss laut Shell:
    broker@io-broker-master:~$ ls -l /dev/ttyACM0
    crw-rw---- 1 root dialout 166, 0 Mai 15 19:56 /dev/ttyACM0
    broker@io-broker-master:~$ ls -l /dev/serial/by-id
    insgesamt 0
    lrwxrwxrwx 1 root root 13 Mai 15 19:56 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100LMG-if00 -> ../../ttyACM0
    lrwxrwxrwx 1 root root 13 Mai 15 19:56 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100LMG-if03 -> ../../ttyACM1
    Log sagt folgendes:
    zigbee.0	2021-05-15 20:00:23.337	error	(919) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herd
    zigbee.0	2021-05-15 20:00:23.336	error	(919) Failed to start Zigbee
    zigbee.0	2021-05-15 20:00:23.257	info	(919) Installed Version: iobroker.zigbee@1.5.5
    zigbee.0	2021-05-15 20:00:23.248	info	(919) Starting Zigbee npm ...
    zigbee.0	2021-05-15 20:00:23.248	info	(919) Try to reconnect. 1 attempts left
    zigbee.0	2021-05-15 20:00:13.247	error	(919) TypeError: Cannot read property 'error' of undefined at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/ma
    zigbee.0	2021-05-15 20:00:13.246	error	(919) Failed to start Zigbee
    zigbee.0	2021-05-15 20:00:11.558	info	(919) Installed Version: iobroker.zigbee@1.5.5
    zigbee.0	2021-05-15 20:00:11.453	info	(919) Starting Zigbee npm ...
    zigbee.0	2021-05-15 20:00:11.422	info	(919) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.0, js-controller: 3.2.16
    zigbee.0	2021-05-15 20:00:07.743	error	(902) Cannot read property 'getEntries' of null
    zigbee.0	2021-05-15 20:00:07.743	error	(902) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/de
    zigbee.0	2021-05-15 20:00:07.742	error	(902) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-05-15 20:00:07.742	error	(902) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Probiert habe ich es mit /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100LMG-if00 und /dev/ttyACM0
    IOBroker isf frisch installiert und ausser zigbee gibt es noch keine Adapter.
    Node Version ist v14.17.0
    Zigbee ist die Version 1.5.5
    Ich bin nun mit meinem Latein am ende.
    Hat wer eine Idee?
    • R Rene 1
      insgesamt 0
      Log sagt folgendes:
      Hat wer eine Idee?
      @rene-1
      sudo -u iobroker groups
      which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
      R 1 Antwort Letzte Antwort
        @rene-1
        Rene 1
        broker@io-broker-master:~$ sudo -u iobroker groups
        iobroker tty dialout audio video
        broker@io-broker-master:~$ node npm && nodejs -v && node -v && npm -v && apt policy nodejs
        internal/modules/cjs/loader.js:888
          throw err;
        Error: Cannot find module '/home/broker/npm'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:885:15)
            at Function.Module._load (internal/modules/cjs/loader.js:730:27)
            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
            at internal/main/run_main_module.js:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        • R Rene 1
            throw err;
            requireStack: []
          @rene-1
          Du kopierst nicht meine Vorgaben. bzw. hackst die nicht richtig rein.
            Rene 1
            Entschuldigung mein Fehler.
            Nun richtig
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.17.0
            v14.17.0
            6.14.13
            nodejs:
              Installiert:           14.17.0-1nodesource1
              Installationskandidat: 14.17.0-1nodesource1
              Versionstabelle:
             *** 14.17.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
                    500 http://deb.debian.org/debian buster/main amd64 Packages
                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
            • R Rene 1
              Nun richtig
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.17.0
              v14.17.0
              6.14.13
              nodejs:
                Versionstabelle:
              @rene-1
              sudo lsof /dev/ttyACM0
              sudo lsof /dev/ttyACM1
                @rene-1
                Rene 1
                broker@io-broker-master:~$ lsof /dev/ttyACM0
                broker@io-broker-master:~$ lsof /dev/ttyACM1
                • R Rene 1
                  @rene-1
                  Sorry, mit sudo vorweg.
                  Siehe oben.
                    @rene-1
                    Siehe oben.
                    Rene 1
                    broker@io-broker-master:~$ sudo lsof /dev/ttyACM0
                    [sudo] Passwort für broker:
                    COMMAND   PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
                    io.zigbee 919 iobroker   27uW  CHR  166,0      0t0 1779 /dev/ttyACM0
                    broker@io-broker-master:~$ sudo lsof /dev/ttyACM1
                    • R Rene 1
                      @rene-1
                      sudo kill -9 919
                      Und dann den zigbee-Adapter nochmal starten.
                        @rene-1
                        sudo kill -9 919
                        Rene 1
                        reboots hatte ich schon einige hinter mir aber auch nur den zu Killen brachte nun nichts
                        zigbee.0	2021-05-15 20:40:47.312	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                        zigbee.0	2021-05-15 20:40:47.312	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                        zigbee.0	2021-05-15 20:40:47.312	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                        zigbee.0	2021-05-15 20:40:47.312	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                        zigbee.0	2021-05-15 20:40:47.312	error	at new Promise (<anonymous>)
                        zigbee.0	2021-05-15 20:40:47.312	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                        zigbee.0	2021-05-15 20:40:47.312	error	at Generator.next (<anonymous>)
                        zigbee.0	2021-05-15 20:40:47.312	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                        zigbee.0	2021-05-15 20:40:47.312	error	(1160) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                        zigbee.0	2021-05-15 20:40:47.311	error	(1160) Failed to start Zigbee
                        zigbee.0	2021-05-15 20:40:47.228	info	(1160) Installed Version: iobroker.zigbee@1.5.5
                        zigbee.0	2021-05-15 20:40:47.223	info	(1160) Starting Zigbee npm ...
                        • R Rene 1
                          @rene-1 sagte in Zigbee und CC26x2R1 Coordinator mag mich nicht ;-):
                          Kein Ahnung dann.
                          Vielleicht mal die Instanz löschen und wieder neuanlegen.
                          Und mal die stable 1.4.4 probieren.
                          Edit:
                          cd /opt/iobroker
                          npm list
                          Ist das sauber? Ohne Meldungen am Ende?
                            Kein Ahnung dann.
                            Edit:
                            cd /opt/iobroker
                            npm list
                            Rene 1
                            Auch eine neue Installation mit stable 1.4.4 brachte keinen Erfolg.
                            Trotzdem Danke für deine Unterstützung
                            • R Rene 1
                              @rene-1 Schau mal nach npm list.
                              Siehe oben.
                                Rene 1
                                So nachdem ich gestern einiges getestet habe läuft es.
                                Die Lösung die bei mir geht ist alles bis auf die shepherd.db im Ordner
                                /opt/iobroker/iobroker-data/zigbee_0/
                                zu löschen.
                                Ich denke mal das eigentlichh die nvbackup.json das Problem verursacht hat.
                                Gruß und Danke für die Hilfe
                                René
                                • hg6806H Offline
                                  hg6806H Offline
                                  hg6806
                                  Moin!
                                  Gestern haben hatte ich das gleiche Problem.
                                  Ich hatte den Raspi4 neu gestartet, ab da wurde der Zigbee Adapter nur noch gelb angezeigt.
                                  CC2652. Keine Chance, Adapter mehrfach neu gestartet, Stick mehrfach abgezogen.
                                  Letztendlich hat es nur noch geholfen Instanz und Adapter komplett zu löschen, sowie alle Dateien in
                                  shepherd.db hatte ich vorher gesichert.
                                  Dann nach der Neuinstallation von Adapter und Instanz ging es dann.
                                  Auch nicht sofort übrigens.
                                  Danach die shepherd.db wieder drauf, und schon hatte ich wieder alles.
                                  Ist halt ein heftiger Workaround nur um mal den Pi neu zu starten.
                                  Aber Zigbee heißt bei mir ja sowie "Zick-be" :-)
                                    Rene 1
                                    Nach meinem kleinen eingriff läuft es ohne Probleme auch Restarts machen keine Probleme.
                                    Aber mit deiner Aussage „ZigBee heißt bei mir ja sowie "Zick-be" stimme ich dir zu 100% zu.
                                    hg6806H 2 Antworten Letzte Antwort
                                    • R Rene 1
                                      hg6806H Offline
                                      hg6806H Offline
                                      hg6806
                                      @rene-1
                                      Du meinst lediglich die nvbackup.json löschen?
                                      Hatte ich auch versucht, blieb aber erfolglos.
                                      • R Rene 1
                                        hg6806H Offline
                                        hg6806H Offline
                                        hg6806
                                        Bei mir wird viel Licht per Zick-be gesteuert. Und wenn dann wie in dem Fall gestern Abend der Adapter gelb bleibt, das Licht an und man ins Bett möchte echt extrem nervig!
                                        • hg6806H hg6806
                                          Rene 1
                                          @hg6806 Ja das kenne ich leider auch.
                                          Zum glück habe ich Shelly Backup :-)
                                          K 1 Antwort Letzte Antwort
