  4. [gelöst] Common Error Skript Fehler?
8 Beiträge 3 Kommentatoren 620 Aufrufe 2 Beobachtet
  • padrinoP Offline
    padrinoP Offline
    padrino
    schrieb am zuletzt editiert von padrino
    Musste, weil ein Skript amok lief 😌 die JS Instanz neu starten...
    Nun wirft sie immer den Fehler aus?
    Kann mir jemand helfen, worum es gehen könnte?
    2021-05-04 23:27:12.204 - info: javascript.0 (26331) Start javascript script.js.common.error-skript
    2021-05-04 23:27:12.225 - error: javascript.0 (26331) script.js.common.error-skript compile failed:
    at script.js.common.error-skript:1
    2021-05-04 23:27:12.226 - error: javascript.0 (26331) function (err) {
    2021-05-04 23:27:12.227 - error: javascript.0 (26331) ^
    2021-05-04 23:27:12.228 - error: javascript.0 (26331) SyntaxError: Unexpected token (
    2021-05-04 23:27:12.229 - error: javascript.0 (26331) at new Script (vm.js:83:7)
    2021-05-04 23:27:12.230 - error: javascript.0 (26331) at Object.createScript (vm.js:277:10)
    2021-05-04 23:27:12.231 - error: javascript.0 (26331) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
    2021-05-04 23:27:12.231 - error: javascript.0 (26331) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
    2021-05-04 23:27:12.232 - error: javascript.0 (26331) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17)
    2021-05-04 23:27:12.233 - error: javascript.0 (26331) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
    2021-05-04 23:27:12.233 - error: javascript.0 (26331) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
    2021-05-04 23:27:12.234 - error: javascript.0 (26331) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2021-05-04 23:27:12.235 - error: javascript.0 (26331) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2021-05-04 23:27:12.236 - error: javascript.0 (26331) at process._tickCallback (internal/process/next_tick.js:68:7)
    F paul53P 2 Antworten Letzte Antwort
    • padrinoP padrino
      F Online
      F Online
      fastfoot
      @padrino die Funktion hat keinen Namen
      iobroker läuft unter Docker auf Windows (WSL2)
      padrinoP 1 Antwort Letzte Antwort
      • F fastfoot
        padrinoP Offline
        padrinoP Offline
        padrino
        @fastfoot
        Welche meinst Du?
        Also,
        a) nutze ich nur "funktionslose" Blockly Skripte
        und
        b) ist "error-skript" nicht von mir, müsste also etwas vom System sein.
        F 1 Antwort Letzte Antwort
        • padrinoP padrino
          @padrino
          Error in Zeile 1 lässt vermuten, dass ein Skript unter der Gruppe "global" aktiv ist, was es nicht sollte (im Expertenmodus deaktivieren).
            @padrino
            padrinoP Offline
            padrinoP Offline
            padrino
            Nö, "Global" ist (wie's sich gehört ;)) leer.
            • padrinoP padrino
              @padrino
              Dann poste mal den Javascript-Code von "common.error-skript" in Code tags.
              • padrinoP padrino
                @fastfoot
                Welche meinst Du?
                Also,
                und
                F Online
                F Online
                fastfoot
                @padrino sagte in Common Error Skript Fehler?:
                liegt lt LOG in common, vlt kannst du es ja dort finden. Sonst wüsste ich nicht was zu tun ist
                • F fastfoot
                  padrinoP Offline
                  padrinoP Offline
                  padrino
                  Danke Euch 2, da lag wirklich was in common. 🤦‍♂️
                  Keine Ahnung, wo das her ist.
                  Mein Hirn wird immer mehr ein Sieb. :(
