  4. ioBroker startet nicht mehr
25 Beiträge 3 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • Q Offline
    Q Offline
    quorle
    Habe heute mal auf den neuen Admin 5.0.4 upgedatet. Jedoch konnte ich mich dann nicht mehr einloggen. Also zurück zu der stable 4er version.
    Nun startet der Broker nicht mehr. Habe mal folgendes ausgeführt:
    npm i iobroker.admin --production
    Dabei am dann das in der LOG:
    1445 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    1446 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    1447 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    1447 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    1447 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    1447 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
    1448 warn optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    1449 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    1450 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
    1450 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
    1450 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
    1450 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: x64
    1451 verbose stack Error: iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
    1451 verbose stack Exit status 1
    1451 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
    1451 verbose stack     at EventEmitter.emit (events.js:314:20)
    1451 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    1451 verbose stack     at ChildProcess.emit (events.js:314:20)
    1451 verbose stack     at maybeClose (internal/child_process.js:1022:16)
    1451 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    1452 verbose pkgid iobroker.js-controller@3.2.16
    1453 verbose cwd /opt/iobroker
    1454 verbose Linux 4.19.0-8-amd64
    1455 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller"
    1456 verbose node v12.22.1
    1457 verbose npm  v6.14.12
    1458 error code ELIFECYCLE
    1459 error errno 1
    1460 error iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
    1460 error Exit status 1
    1461 error Failed at the iobroker.js-controller@3.2.16 install script.
    1461 error This is probably not a problem with npm. There is likely additional logging output above.
    1462 verbose exit [ 1, true ]
    Die letzten Zeilen ( denke die sagen alles?
    Kann jemand helfen?
    • Q quorle
      1459 error errno 1
      Kann jemand helfen?
      wendy2702W Online
      wendy2702W Online
      wendy2702
      @quorle sagte in ioBroker startet nicht mehr:
      Und bestimmt vorher
      cd /opt/iobroker
      Gemacht ?
      Q 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        Und bestimmt vorher
        cd /opt/iobroker
        Gemacht ?
        Q Offline
        Q Offline
        quorle
        @wendy2702
        Ja klar. wie in der Anleitung beschrieben
        npm -V:
        6.14.12
        node -v:
        12.22.1
        ps -A | grep iobroker zeigt nichts an
        ps -aux |grep io
        root        12  0.0  0.0      0     0 ?        S    22:00   0:00 [migration/0]
        root        16  0.0  0.0      0     0 ?        S    22:00   0:00 [migration/1]
        root        21  0.0  0.0      0     0 ?        S    22:00   0:00 [migration/2]
        root        26  0.0  0.0      0     0 ?        S    22:00   0:00 [migration/3]
        message+   340  0.0  0.0   8988  3708 ?        Ss   22:00   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
        quirin     576  0.0  0.0   6088   888 pts/0    S+   22:14   0:00 grep io
        • Q quorle
          @wendy2702
          npm -V:
          6.14.12
          node -v:
          12.22.1
          ps -aux |grep io
          wendy2702W Online
          wendy2702W Online
          wendy2702
          @quorle
          iobroker status
          iobroker list instances
          iobroker -v
          Gibt es von der NPM installation ein Logfile?
          Was ist das für ein System?
          Von wo kommt das logfile?
          Q 2 Antworten Letzte Antwort
            @quorle
            iobroker status
            iobroker -v
            Q Offline
            Q Offline
            quorle
            @wendy2702
            quirin@IoBroker:/opt/iobroker$ iobroker status
            quirin@IoBroker:/opt/iobroker$ iobroker list instances
            quirin@IoBroker:/opt/iobroker$ iobroker -v
            System läuft auf ein Debian unter Proxmox VM
            Logfile ist von NPM mit obigen Befehl
            • Q quorle
              @wendy2702
              wendy2702W Online
              wendy2702W Online
              wendy2702
              @quorle sieht sehr leer aus.
              Kommt was bei
              iobroker start
                @quorle
                iobroker status
                iobroker -v
                Q Offline
                Q Offline
                quorle
                @wendy2702
                Wenn ich den Befehl:
                npm i iobroker.js-controller --production
                eingebe, dann kommt folgendes in der Ausgabe:
                quirin@IoBroker:/opt/iobroker$ npm i iobroker.js-controller --production
                npm ERR! code ENOSPC
                npm ERR! syscall mkdir
                npm ERR! path /opt/iobroker/node_modules
                npm ERR! errno -28
                npm ERR! nospc ENOSPC: no space left on device, mkdir '/opt/iobroker/node_modules'
                npm ERR! nospc There appears to be insufficient space on your system to finish.
                npm ERR! nospc Clear up some disk space and try again.
                  Kommt was bei
                  iobroker start
                  Q Offline
                  Q Offline
                  quorle
                  @wendy2702 sagte in ioBroker startet nicht mehr:
                  Kommt was bei
                  iobroker start
                  Leider nicht
                  • Q quorle
                    @wendy2702
                    npm ERR! errno -28
                    wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    code ENOSPC
                    Kein Platz mehr.
                    df -h
                      code ENOSPC
                      Kein Platz mehr.
                      df -h
                      Q Offline
                      Q Offline
                      quorle
                      df -h
                      quirin@IoBroker:/opt/iobroker$ df -h
                      Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                      udev            2,4G       0  2,4G    0% /dev
                      tmpfs           484M    6,5M  478M    2% /run
                      /dev/sda1        28G     27G     0  100% /
                      tmpfs           2,4G       0  2,4G    0% /dev/shm
                      tmpfs           5,0M       0  5,0M    0% /run/lock
                      tmpfs           2,4G       0  2,4G    0% /sys/fs/cgroup
                      tmpfs           484M       0  484M    0% /run/user/1000
                      Bevor ich das Admin-Update gemacht habe, waren aber noch ca. die Hälfte der Platte frei
                      • Q quorle
                        df -h
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        @quorle Tja,
                        Da kann ich nichts zu sagen. Habe den Upgrade auch gemacht und es hat nicht die SD Karte in meinem PI voll geschrieben.
                        Da müsste man jetzt mal suchen welches DIR genau die Platte voll macht.
                        Thomas BraunT Q 2 Antworten Letzte Antwort
                          @quorle Tja,
                          @wendy2702
                          Mach ich immer mit
                          ncdu
                          Ist halt die Frage ob man das jetzt noch auf die rappelvolle Platte bekommt.
                            @quorle Tja,
                            Q Offline
                            Q Offline
                            quorle
                            @wendy2702
                            Wenn ich mit dem MidnightCommander mir alles ansehe, steht unten nur 5% der Platte benutzt
                            • Q quorle
                              @wendy2702
                              wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              MidnightCommander
                              Für den ist es auch noch zu früh.... haben erst 22:33
                              Spass beiseite.
                              Hast du backups auf der Platte die weg können um etwas Platz zu schaffen ?
                                MidnightCommander
                                Spass beiseite.
                                Q Offline
                                Q Offline
                                quorle
                                schrieb am zuletzt editiert von quorle
                                @wendy2702
                                Hab mal die Backups des ioB gelöscht. Hab die ja noch wo anders ;)
                                Jetzt hätte ich 266Mb frei
                                • Q quorle
                                  @wendy2702
                                  wendy2702W Online
                                  wendy2702W Online
                                  wendy2702
                                  @quorle dann mal
                                  ncdu
                                  Und suchen
                                  Wenn nicht vorhanden mal installieren
                                    @quorle dann mal
                                    ncdu
                                    Und suchen
                                    Q Offline
                                    Q Offline
                                    quorle
                                    @wendy2702
                                    Hab ich installiert
                                    • Q quorle
                                      @wendy2702
                                      Hab ich installiert
                                      wendy2702W Online
                                      wendy2702W Online
                                      wendy2702
                                      @quorle dann aufrufen und suchen.
                                      Besser vorher noch aus den Home Directory des Users raus.
                                        Q Offline
                                        Q Offline
                                        quorle
                                        @wendy2702
                                        Denke ich habe ihn vorerst gefunden:
                                        quirin@IoBroker:/$ ncdu
                                        ncdu 1.13 ~ Use the arrow keys to navigate, press ? for help
                                        --- /opt/iobroker/log ----------------------------------------------------------
                                           16,5 GiB [##########]  iobroker.2021-04-19.log
                                            4,0 KiB [          ]  iobroker-audit.json
                                            4,0 KiB [          ]  restart.log
                                        @   0,0   B [          ]  iobroker.current.log
                                        • Q quorle
                                          @wendy2702
                                          wendy2702W Online
                                          wendy2702W Online
                                          wendy2702
                                          @quorle Ja.
                                          Sieht schwer danach aus.
