  4. [erledigt] Alexa Sprachausgabe hängt
    6.5k
10 Beiträge 5 Kommentatoren 1.3k Aufrufe 5 Beobachtet
  • Karel PuhliK Offline
    Karel Puhli
    schrieb am zuletzt editiert von Karel Puhli
    Mahlzeit!
    Mein Alexa Adapter macht folgende Probleme. Ich muss ihn regelmäßig neustarten, damit die Sprachausgabe funktioniert. Ansonsten bleibt der Echo einfach stumm.
    Im Log nach dem Neustart finde ich keine Fehler.
    alexa2.0	2021-04-19 12:52:52.063	info	(8758) Subscribing to states...
    alexa2.0	2021-04-19 12:52:34.173	info	(8758) Alexa-Push-Connection established. Disable Polling
    alexa2.0	2021-04-19 12:52:30.667	info	(8758) starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi	2021-04-19 12:52:28.459	info	instance system.adapter.alexa2.0 started with pid 8758
    host.raspberrypi	2021-04-19 12:52:25.986	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    alexa2.0	2021-04-19 12:52:25.343	info	(8736) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0	2021-04-19 12:52:25.341	info	(8736) terminating
    alexa2.0	2021-04-19 12:52:25.340	info	(8736) Alexa-Push-Connection Error: Error: WebSocket was closed before the connection was established
    alexa2.0	2021-04-19 12:52:25.336	info	(8736) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2021-04-19 12:52:25.337	info	stopInstance system.adapter.alexa2.0 send kill signal
    host.raspberrypi	2021-04-19 12:52:25.327	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
    alexa2.0	2021-04-19 12:52:25.179	info	(8736) Update cookie in adapter configuration ... restarting ...
    alexa2.0	2021-04-19 12:52:19.105	info	(8736) starting. Version 3.8.1 in /opt/iobroker/node_modules/iobroker.alexa2, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi	2021-04-19 12:52:16.612	info	instance system.adapter.alexa2.0 started with pid 8736
    host.raspberrypi	2021-04-19 12:52:14.028	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    alexa2.0	2021-04-19 12:52:13.383	info	(27346) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0	2021-04-19 12:52:13.381	info	(27346) terminating
    host.raspberrypi	2021-04-19 12:52:13.380	info	stopInstance system.adapter.alexa2.0 send kill signal
    alexa2.0	2021-04-19 12:52:13.379	info	(27346) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2021-04-19 12:52:13.363	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
    Vielen Dank für Eure Hilfe.
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry Pi 4 B
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Kart
    Betriebssystem: Raspberry Pi OS
    Node-Version: 1
    Nodejs-Version: 12.x.x
    NPM-Version: 6.x.x
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • Karel PuhliK Karel Puhli
      Mahlzeit!
      Node-Version: 1
      NPM-Version: 6.x.x
      Dr. BakteriusD Offline
      Dr. Bakterius
      @karel-puhli Schon die Forensuche kennen gelernt? Nein? Dann wird es Zeit! Da gab es in den letzten Tagen einige Beiträge zu diesem Thema ...
      ? 1 Antwort Letzte Antwort
        @dr-bakterius Oh wie ich solche Kommentare liebe 👎
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          @Dr-Bakterius hätte @Karel-Puhli mit einem einfachen Link unter die Arme greifen können.
          @Karel-Puhli
          hier findest du die Themen der letzten Tage zu diesem oder ähnlichem Alexa Problem!
          https://forum.iobroker.net/search?term=alexa&in=titles&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
          ° Fixer ---> iob fix
            Karel Puhli
            Danke Euch!
            @Dr-Bakterius : Inhaltlich haste recht!
            • NegaleinN Negalein
              @Karel-Puhli
              Dr. Bakterius
              @noah3112 sagte in [erledigt] Alexa Sprachausgabe hängt:
              Das fällt mir schon eine ganze Weile negativ auf. Immer wieder kommen innerhalb kurzer Zeit die selben Fragen. Das bläht nicht nur das Forum unnötig auf, sondern macht es anderen schwer relevante Antworten zu finden. Das ist unnötig! Und viele denken gar nicht daran, dass es andere mit den gleichen Problemen gibt - daher der Wink mit dem Zaunpfahl auf die Suchfunktion.
              @negalein sagte in [erledigt] Alexa Sprachausgabe hängt:
              Hätte ich, und ich helfe auch gerne. Doch so grundlegende, einfache Dinge sollte jeder selbst beherrschen der es schafft ins Internet zu kommen und sich hier zu registrieren.
              Natürlich passiert es auch, dass man nicht immer mit der Suchfunktion auch "sein" Problem findet - ist mir auch schon passiert - aber in diesem Fall braucht man nur die Thread-Betreffe der letzten paar Stunden überfliegen und findet mindestens drei die sich auf das Thema beziehen könnten. Wäre nicht schlecht solche Themen zusammen zu legen. (Hallo Moderator! 😀 )
              Karel PuhliK 1 Antwort Letzte Antwort
                Karel Puhli
                @dr-bakterius
                Ich kenne die Suchfunktion und nutze sie auch. In diesem Fall habe ich sie anscheinend nicht sauber genutzt.
                So, jetzt wieder zu den spannenden und sinnvolen Themen...!
                  @dr-bakterius
                  Dr. Bakterius
                  @karel-puhli Sorry wenn gerade du jetzt meinen kleinen Frust abbekommen hast. Nichts für ungut ... 🤝
                    Karel Puhli
                    @dr-bakterius Alles gut! 🤝
                    Christian WöhrleC 1 Antwort Letzte Antwort
                      Christian WöhrleC Offline
                      Christian Wöhrle
                      @karel-puhli 💗 💗
                      Ist das schön, dass ihr euch wieder lieb habt :-)
