  4. iobroker weboberfläche ist nicht mehr erreichbar
    6.6k
23 Beiträge 5 Kommentatoren 3.8k Aufrufe 5 Beobachtet
  • S shaky202
    @thomas-braun Hab ich gemacht, was bewirkt der Befehl?
    pi@raspberrypi:~ $ ls /dev/mmcblk0*
    /dev/mmcblk0  /dev/mmcblk0p1  /dev/mmcblk0p2
    pi@raspberrypi:~ $ mount | sort | grep ^/dev
    /dev/mmcblk0p1 on /media/pi/boot type vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
    /dev/mmcblk0p2 on /media/pi/rootfs type ext4 (rw,nosuid,nodev,relatime,uhelper=udisks2)
    /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
    /dev/sda2 on / type ext4 (rw,noatime)
    @shaky202 sagte in iobroker weboberfläche ist nicht mehr erreichbar:
    /media/pi/rootfs
    Wenn du Glück hast findest du deine Daten vom ioBroker noch unterhalb des Pfades.
    • S shaky202
      @thomas-braun hier ist der Log vom iobroker
      2021-03-06 01:11:00.757  - info: host.raspberrypi received SIGTERM
      2021-03-06 01:11:00.820  - info: host.raspberrypi terminated
      2021-03-06 01:11:57.360  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-03-06 01:11:57.366  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-03-06 01:11:57.366  - info: host.raspberrypi hostname: raspberrypi, node: v12.20.2
      2021-03-06 01:11:57.367  - info: host.raspberrypi ip addresses: 192.168.178.155 2a02:908:1084:4ba0:532b:5b95:d3d7:da fe80::46be:d5a0:77f5:87a4
      2021-03-06 01:11:57.477  - error: host.raspberrypi Cannot read system.config: null (OK when migrating or restoring)
      2021-03-06 01:11:57.573  - info: host.raspberrypi connected to Objects and States
      2021-03-06 01:11:57.621  - info: host.raspberrypi added notifications configuration of host
      2021-03-06 01:11:57.659  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 01:11:57.660  - error: host.raspberrypi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2021-03-06 01:11:57.724  - info: host.raspberrypi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-03-06 01:11:57.731  - error: host.raspberrypi Cannot find view "system" for search "host"
      2021-03-06 01:11:57.742  - error: host.raspberrypi Cannot find view "system" for search "state"
      2021-03-06 01:11:57.743  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 01:11:57.744  - error: host.raspberrypi Could not collect system.host.raspberrypi states to check for obsolete states: Error: Cannot find view "system"
      2021-03-06 01:11:57.746  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
      2021-03-06 01:23:32.823  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-03-06 01:23:32.829  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-03-06 01:23:32.830  - info: host.raspberrypi hostname: raspberrypi, node: v12.20.2
      2021-03-06 01:23:32.831  - info: host.raspberrypi ip addresses:
      2021-03-06 01:23:32.962  - error: host.raspberrypi Cannot read system.config: null (OK when migrating or restoring)
      2021-03-06 01:23:32.972  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
      2021-03-06 01:23:33.074  - info: host.raspberrypi connected to Objects and States
      2021-03-06 01:23:33.124  - info: host.raspberrypi added notifications configuration of host
      2021-03-06 01:23:33.166  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 01:23:33.167  - error: host.raspberrypi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2021-03-06 01:23:33.191  - info: host.raspberrypi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-03-06 01:23:33.199  - error: host.raspberrypi Cannot find view "system" for search "host"
      2021-03-06 01:23:33.211  - error: host.raspberrypi Cannot find view "system" for search "state"
      2021-03-06 01:23:33.211  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 01:23:33.213  - error: host.raspberrypi Could not collect system.host.raspberrypi states to check for obsolete states: Error: Cannot find view "system"
      2021-03-06 01:23:33.214  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
      2021-03-06 09:28:29.865  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-03-06 09:28:29.874  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-03-06 09:28:29.875  - info: host.raspberrypi hostname: raspberrypi, node: v12.20.2
      2021-03-06 09:28:29.876  - info: host.raspberrypi ip addresses:
      2021-03-06 09:28:30.007  - error: host.raspberrypi Cannot read system.config: null (OK when migrating or restoring)
      2021-03-06 09:28:30.017  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
      2021-03-06 09:28:30.122  - info: host.raspberrypi connected to Objects and States
      2021-03-06 09:28:30.176  - info: host.raspberrypi added notifications configuration of host
      2021-03-06 09:28:30.218  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 09:28:30.220  - error: host.raspberrypi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2021-03-06 09:28:30.287  - info: host.raspberrypi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-03-06 09:28:30.295  - error: host.raspberrypi Cannot find view "system" for search "host"
      2021-03-06 09:28:30.307  - error: host.raspberrypi Cannot find view "system" for search "state"
      2021-03-06 09:28:30.307  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 09:28:30.309  - error: host.raspberrypi Could not collect system.host.raspberrypi states to check for obsolete states: Error: Cannot find view "system"
      2021-03-06 09:28:30.310  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
      2021-03-06 11:06:28.943  - info: host.raspberrypi received SIGTERM
      2021-03-06 11:06:29.077  - info: host.raspberrypi terminated
      2021-03-06 11:06:40.437  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-03-06 11:06:40.445  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-03-06 11:06:40.446  - info: host.raspberrypi hostname: raspberrypi, node: v12.21.0
      2021-03-06 11:06:40.447  - info: host.raspberrypi ip addresses:
      2021-03-06 11:06:40.584  - error: host.raspberrypi Cannot read system.config: null (OK when migrating or restoring)
      2021-03-06 11:06:40.695  - info: host.raspberrypi connected to Objects and States
      2021-03-06 11:06:40.748  - info: host.raspberrypi added notifications configuration of host
      2021-03-06 11:06:40.791  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 11:06:40.792  - error: host.raspberrypi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2021-03-06 11:06:40.864  - info: host.raspberrypi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-03-06 11:06:40.873  - error: host.raspberrypi Cannot find view "system" for search "host"
      2021-03-06 11:06:40.887  - error: host.raspberrypi Cannot find view "system" for search "state"
      2021-03-06 11:06:40.888  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 11:06:40.890  - error: host.raspberrypi Could not collect system.host.raspberrypi states to check for obsolete states: Error: Cannot find view "system"
      2021-03-06 11:06:40.891  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
      2021-03-06 11:09:13.278  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
      2021-03-06 11:09:13.284  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-03-06 11:09:13.285  - info: host.raspberrypi hostname: raspberrypi, node: v12.21.0
      2021-03-06 11:09:13.286  - info: host.raspberrypi ip addresses:
      2021-03-06 11:09:13.414  - error: host.raspberrypi Cannot read system.config: null (OK when migrating or restoring)
      2021-03-06 11:09:13.530  - info: host.raspberrypi connected to Objects and States
      2021-03-06 11:09:13.583  - info: host.raspberrypi added notifications configuration of host
      2021-03-06 11:09:13.632  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 11:09:13.634  - error: host.raspberrypi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2021-03-06 11:09:13.713  - info: host.raspberrypi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-03-06 11:09:13.722  - error: host.raspberrypi Cannot find view "system" for search "host"
      2021-03-06 11:09:13.737  - error: host.raspberrypi Cannot find view "system" for search "state"
      2021-03-06 11:09:13.738  - error: host.raspberrypi Cannot find view "system" for search "instance"
      2021-03-06 11:09:13.740  - error: host.raspberrypi Could not collect system.host.raspberrypi states to check for obsolete states: Error: Cannot find view "system"
      2021-03-06 11:09:13.742  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
      naja das isz doch an sich eine eindeutige Meldung oder?! Und das objects.json scheint auch irgendwoe broken. Also ggf hier auch mal nach den .bak Files in /opt/iobroker/iobroker-data bzw in dem Backup Verzeichnis dort suchen.
      (kann es sein das Du die SD auf SSD kopiert hast als ioBroker noch lieff??
      • apollon77A apollon77
        shaky202
        @apollon77 Hi, um eine kurze Rückmeldung zu geben... Ich habe leider keine Lösung gefunden das System zu retten. Jedoch hab ich aus meinen Fehlern gelernt, alles neu Aufgesetzt und den Backitup-Adapter installiert der nun im eingestellten Intervall fleißig Backups auf der SSD hinterlegt.
        Danke trotzdem für eure Hilfe!
