  5. [solved] Skriptprobleme
    5.2k
2 Beiträge 1 Kommentatoren 101 Aufrufe 1 Beobachtet
    Dragon
    schrieb am zuletzt editiert von Dragon
    Ich habe folgendes Skript bei mir laufen.
    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="WDi:](4ssESe^3dhZ!v+" x="-362" y="-1093">
      <field name="OID">ecovacs-deebot.0.status.device</field>
      <statement name="STATEMENT">
        <block type="controls_if" id="b8cu1SYU=7P59x=1X3wr">
          <value name="IF0">
            <block type="logic_operation" id="diTiOl0L,0mYVTYX`tYs" inline="false">
              <field name="OP">OR</field>
              <value name="A">
                <block type="logic_compare" id="t3dvYjb$qy{/[#{`^Yt]">
                  <field name="OP">EQ</field>
                  <value name="A">
                    <block type="on_source" id="K5{Bw|+~JI@dZVshKcJM">
                    </block>
                  </value>
                  <value name="B">
                    <block type="text" id=":Fhy{kn*Tb5A%jxa{?RP">
                      <field name="TEXT">charging</field>
                    </block>
                  </value>
                </block>
              </value>
              <value name="B">
                <block type="logic_operation" id="+Kp@CxZ?v,-@*;%]2gAn" inline="false">
                  <value name="A">
                    <block type="logic_compare" id="-3?vUug`x)uL51pY;N)d">
                      <value name="A">
                        <block type="on_source" id="#;AY`6%ymMRV10RmP8/e">
                        </block>
                      </value>
                      <value name="B">
                        <block type="text" id="|452hZs/obp6T,RT)}5G">
                          <field name="TEXT">paused</field>
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                    <block type="logic_compare" id="CUwEh~AF;a*bCJCKqj^8">
                      <value name="A">
                        <block type="on_source" id="qo[Ir%qHojI4~Ebc/$v@">
                        </block>
                      </value>
                      <value name="B">
                        <block type="text" id=".6PxdSYl3[_kM(+.sUN,">
                          <field name="TEXT">stopped</field>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
          <statement name="DO0">
            <block type="control" id="#sT[H;rx5RLs!#6GYZT6">
              <field name="OID">javascript.0.EigeneDatenpunkte.ohne_Kamera</field>
              <value name="VALUE">
                <block type="logic_boolean" id="Zbdw-]:5fA]tBi]9St|(">
                </block>
              </value>
            </block>
          </statement>
          <statement name="ELSE">
            <block type="control" id="wsaM2?W`N.~[L#1Du(%(">
                <block type="logic_boolean" id="0S8OUWW%jX9w]}aq|Ps9">
                </block>
              </value>
            </block>
          </statement>
        </block>
      </statement>
    </block>
    Als Trigger verwendet er den Device Status des Ecovacs Adapters. Was ich nicht verstehe ist: Er erkennt wenn sich der Datenpunkt ändert, er erkennt wenn es keiner der drei vorgegbenen Werte ist und setzt den Datenpunkt auf true. False soll er setzen wenn der device status entweder charging, stopped oder paused ist. Dieses tut er aber nicht. Ich bin wirklich verzweifelt weil ich nicht weiß warum...
    • D Dragon
            <value name="IF0">
                <value name="A">
                    <value name="A">
                      </block>
                    </value>
                    <value name="B">
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                    <value name="A">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
                  </block>
                </value>
              </block>
            </statement>
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
      </block>
      Dragon
      Wie es immer so ist.... Ich habe jetzt drei Tage lang verzweifelt das Problem gesucht. Habe jetzt den anderen Trigger Baustein genommen und es funktioniert... Verrückt, aber hauptsache es läuft jetzt....
