  4. Modbus Poll funktioniert nicht
    6.8k
29 Beiträge 4 Kommentatoren 3.7k Aufrufe 1 Beobachtet
  • C captainchaos666
    @wendy2702
    Little Endian:
    modbus.2	2021-02-10 16:57:39.811	info	(3700) Disconnected from slave 192.168.178.202
    modbus.2	2021-02-10 16:57:39.810	debug	(3700) Closing client on purpose.
    modbus.2	2021-02-10 16:57:38.908	debug	(3700) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 16:57:38.907	debug	(3700) Poll device 1
    modbus.2	2021-02-10 16:57:38.809	debug	(3700) Cleaning up request fifo.
    modbus.2	2021-02-10 16:57:38.808	debug	(3700) Clearing timeout of the current request.
    modbus.2	2021-02-10 16:57:38.807	debug	(3700) Socket closed with error
    modbus.2	2021-02-10 16:57:37.844	debug	(3700) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 16:57:37.843	debug	(3700) Poll device 1
    modbus.2	2021-02-10 16:57:37.842	info	(3700) Connected to slave 192.168.178.202
    modbus.2	2021-02-10 16:56:37.838	info	(3700) Disconnected from slave 192.168.178.202
    modbus.2	2021-02-10 16:56:37.837	debug	(3700) Closing client on purpose.
    modbus.2	2021-02-10 16:56:37.747	debug	(3700) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 16:56:37.746	debug	(3700) Poll device 1
    modbus.2	2021-02-10 16:56:36.837	debug	(3700) Cleaning up request fifo.
    modbus.2	2021-02-10 16:56:36.836	debug	(3700) Clearing timeout of the current request.
    modbus.2	2021-02-10 16:56:36.835	debug	(3700) Socket closed with error
    modbus.2	2021-02-10 16:56:36.683	debug	(3700) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 16:56:36.681	debug	(3700) Poll device 1
    modbus.2	2021-02-10 16:56:36.680	info	(3700) Connected to slave 192.168.178.202
    Big Endian:
    modbus.2	2021-02-10 17:02:47.841	info	(3899) Disconnected from slave 192.168.178.202
    modbus.2	2021-02-10 17:02:47.840	debug	(3899) Closing client on purpose.
    modbus.2	2021-02-10 17:02:47.651	debug	(3899) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 17:02:47.650	debug	(3899) Poll device 1
    modbus.2	2021-02-10 17:02:46.839	debug	(3899) Cleaning up request fifo.
    modbus.2	2021-02-10 17:02:46.838	debug	(3899) Clearing timeout of the current request.
    modbus.2	2021-02-10 17:02:46.837	debug	(3899) Socket closed with error
    modbus.2	2021-02-10 17:02:46.590	debug	(3899) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 17:02:46.590	debug	(3899) Poll device 1
    modbus.2	2021-02-10 17:02:46.588	info	(3899) Connected to slave 192.168.178.202
    modbus.2	2021-02-10 17:01:46.585	info	(3899) Disconnected from slave 192.168.178.202
    modbus.2	2021-02-10 17:01:46.584	debug	(3899) Closing client on purpose.
    modbus.2	2021-02-10 17:01:46.569	debug	(3899) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 17:01:46.568	debug	(3899) Poll device 1
    modbus.2	2021-02-10 17:01:45.582	debug	(3899) Cleaning up request fifo.
    modbus.2	2021-02-10 17:01:45.582	debug	(3899) Clearing timeout of the current request.
    modbus.2	2021-02-10 17:01:45.581	debug	(3899) Socket closed with error
    modbus.2	2021-02-10 17:01:45.473	debug	(3899) Poll inputRegs DevID(1) address 5007 - 1 bytes
    modbus.2	2021-02-10 17:01:45.472	debug	(3899) Poll device 1
    modbus.2	2021-02-10 17:01:45.470	info	(3899) Connected to slave 192.168.178.202
    wendy2702W Online
    wendy2702W Online
    wendy2702
    @captainchaos666 Big Endian scheint mir richtig zu sein. Da wohl noch durch 10 geteilt werden muss.
    Mal 3002 32bit unsigned zum testen dazu bitte. Auch wieder beides Testen.
    C 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      captainchaos666
      @wendy2702
      ost.RaspSchaltschrank	2021-02-10 17:45:25.031	info	Restart adapter system.adapter.modbus.2 because enabled
      host.RaspSchaltschrank	2021-02-10 17:45:25.031	error	instance system.adapter.modbus.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.RaspSchaltschrank	2021-02-10 17:45:25.030	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:272:9)
      host.RaspSchaltschrank	2021-02-10 17:45:25.030	error	Caught by controller[0]: at addChunk (_stream_readable.js:297:12)
      host.RaspSchaltschrank	2021-02-10 17:45:25.029	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
      host.RaspSchaltschrank	2021-02-10 17:45:25.029	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
      host.RaspSchaltschrank	2021-02-10 17:45:25.028	error	Caught by controller[0]: at Socket.onSocketData (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/transports/modbus-client-tcp.js:97:26)
      host.RaspSchaltschrank	2021-02-10 17:45:25.028	error	Caught by controller[0]: at Object.emit (/opt/iobroker/node_modules/stampit-event-bus/src/stampit-event-bus.js:20:38)
      host.RaspSchaltschrank	2021-02-10 17:45:25.028	error	Caught by controller[0]: at Object.onData (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/modbus-client-core.js:126:13)
      host.RaspSchaltschrank	2021-02-10 17:45:25.027	error	Caught by controller[0]: at onResponse (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/handler/client/ReadInputRegisters.js:30:44)
      host.RaspSchaltschrank	2021-02-10 17:45:25.027	error	Caught by controller[0]: at Buffer.readUInt16BE (internal/buffer.js:328:5)
      host.RaspSchaltschrank	2021-02-10 17:45:25.026	error	Caught by controller[0]: at boundsError (internal/buffer.js:82:9)
      host.RaspSchaltschrank	2021-02-10 17:45:25.026	error	Caught by controller[0]: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:45:24.845	error	(5720) Client in error state.
      modbus.2	2021-02-10 17:45:24.843	error	(5720) Socket Error
      modbus.2	2021-02-10 17:45:24.815	warn	(5720) Terminated (UNCAUGHT_EXCEPTION): Without reason
      modbus.2	2021-02-10 17:45:24.814	debug	(5720) Plugin sentry destroyed
      modbus.2	2021-02-10 17:45:24.811	info	(5720) terminating
      modbus.2	2021-02-10 17:45:24.808	debug	(5720) Closing client on purpose.
      modbus.2	2021-02-10 17:45:24.763	error	(5720) Exception-Code: ERR_OUT_OF_RANGE: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:45:24.762	error	(5720) RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2 at boundsError (internal/buffer.js:82:9) at Buffer.readUInt16BE (internal/buff
      modbus.2	2021-02-10 17:45:24.761	error	(5720) uncaught exception: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:45:24.722	debug	(5720) Poll inputRegs DevID(1) address 3002 - 2 bytes
      modbus.2	2021-02-10 17:45:24.721	debug	(5720) Initialization of scale factors done!
      modbus.2	2021-02-10 17:45:24.718	debug	(5720) Poll device 1
      modbus.2	2021-02-10 17:45:24.715	info	(5720) Connected to slave 192.168.178.202
      modbus.2	2021-02-10 17:45:24.079	info	(5720) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.20.1, js-controller: 3.2.13
      modbus.2	2021-02-10 17:45:23.630	debug	(5720) Plugin sentry Initialize Plugin (enabled=true)
      host.RaspSchaltschrank	2021-02-10 17:45:21.353	info	instance system.adapter.modbus.2 started with pid 5720
      host.RaspSchaltschrank	2021-02-10 17:44:51.320	info	Restart adapter system.adapter.modbus.2 because enabled
      host.RaspSchaltschrank	2021-02-10 17:44:51.319	error	instance system.adapter.modbus.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.RaspSchaltschrank	2021-02-10 17:44:51.319	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:272:9)
      host.RaspSchaltschrank	2021-02-10 17:44:51.318	error	Caught by controller[0]: at addChunk (_stream_readable.js:297:12)
      host.RaspSchaltschrank	2021-02-10 17:44:51.318	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
      host.RaspSchaltschrank	2021-02-10 17:44:51.318	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
      host.RaspSchaltschrank	2021-02-10 17:44:51.317	error	Caught by controller[0]: at Socket.onSocketData (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/transports/modbus-client-tcp.js:97:26)
      host.RaspSchaltschrank	2021-02-10 17:44:51.317	error	Caught by controller[0]: at Object.emit (/opt/iobroker/node_modules/stampit-event-bus/src/stampit-event-bus.js:20:38)
      host.RaspSchaltschrank	2021-02-10 17:44:51.317	error	Caught by controller[0]: at Object.onData (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/modbus-client-core.js:126:13)
      host.RaspSchaltschrank	2021-02-10 17:44:51.316	error	Caught by controller[0]: at onResponse (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/handler/client/ReadInputRegisters.js:30:44)
      host.RaspSchaltschrank	2021-02-10 17:44:51.316	error	Caught by controller[0]: at Buffer.readUInt16BE (internal/buffer.js:328:5)
      host.RaspSchaltschrank	2021-02-10 17:44:51.315	error	Caught by controller[0]: at boundsError (internal/buffer.js:82:9)
      host.RaspSchaltschrank	2021-02-10 17:44:51.315	error	Caught by controller[0]: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:44:51.151	error	(5678) Client in error state.
      modbus.2	2021-02-10 17:44:51.150	error	(5678) Socket Error
      modbus.2	2021-02-10 17:44:51.121	warn	(5678) Terminated (UNCAUGHT_EXCEPTION): Without reason
      modbus.2	2021-02-10 17:44:51.120	debug	(5678) Plugin sentry destroyed
      modbus.2	2021-02-10 17:44:51.118	info	(5678) terminating
      modbus.2	2021-02-10 17:44:51.115	debug	(5678) Closing client on purpose.
      modbus.2	2021-02-10 17:44:51.063	error	(5678) Exception-Code: ERR_OUT_OF_RANGE: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:44:51.061	error	(5678) RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2 at boundsError (internal/buffer.js:82:9) at Buffer.readUInt16BE (internal/buff
      modbus.2	2021-02-10 17:44:51.060	error	(5678) uncaught exception: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:44:51.017	debug	(5678) Poll inputRegs DevID(1) address 3002 - 2 bytes
      modbus.2	2021-02-10 17:44:51.016	debug	(5678) Initialization of scale factors done!
      modbus.2	2021-02-10 17:44:51.012	debug	(5678) Poll device 1
      modbus.2	2021-02-10 17:44:51.005	info	(5678) Connected to slave 192.168.178.202
      modbus.2	2021-02-10 17:44:50.365	info	(5678) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.20.1, js-controller: 3.2.13
      modbus.2	2021-02-10 17:44:49.960	debug	(5678) Plugin sentry Initialize Plugin (enabled=true)
      host.RaspSchaltschrank	2021-02-10 17:44:47.714	info	instance system.adapter.modbus.2 started with pid 5678
      host.RaspSchaltschrank	2021-02-10 17:48:46.607	info	Restart adapter system.adapter.modbus.2 because enabled
      host.RaspSchaltschrank	2021-02-10 17:48:46.606	error	instance system.adapter.modbus.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.RaspSchaltschrank	2021-02-10 17:48:46.606	error	Caught by controller[0]: at readableAddChunk (_stream_readable.js:272:9)
      host.RaspSchaltschrank	2021-02-10 17:48:46.605	error	Caught by controller[0]: at addChunk (_stream_readable.js:297:12)
      host.RaspSchaltschrank	2021-02-10 17:48:46.605	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
      host.RaspSchaltschrank	2021-02-10 17:48:46.605	error	Caught by controller[0]: at Socket.emit (events.js:314:20)
      host.RaspSchaltschrank	2021-02-10 17:48:46.604	error	Caught by controller[0]: at Socket.onSocketData (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/transports/modbus-client-tcp.js:97:26)
      host.RaspSchaltschrank	2021-02-10 17:48:46.604	error	Caught by controller[0]: at Object.emit (/opt/iobroker/node_modules/stampit-event-bus/src/stampit-event-bus.js:20:38)
      host.RaspSchaltschrank	2021-02-10 17:48:46.603	error	Caught by controller[0]: at Object.onData (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/modbus-client-core.js:126:13)
      host.RaspSchaltschrank	2021-02-10 17:48:46.603	error	Caught by controller[0]: at onResponse (/opt/iobroker/node_modules/iobroker.modbus/lib/jsmodbus/handler/client/ReadInputRegisters.js:30:44)
      host.RaspSchaltschrank	2021-02-10 17:48:46.602	error	Caught by controller[0]: at Buffer.readUInt16BE (internal/buffer.js:328:5)
      host.RaspSchaltschrank	2021-02-10 17:48:46.602	error	Caught by controller[0]: at boundsError (internal/buffer.js:82:9)
      host.RaspSchaltschrank	2021-02-10 17:48:46.601	error	Caught by controller[0]: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:48:46.418	error	(5929) Client in error state.
      modbus.2	2021-02-10 17:48:46.417	error	(5929) Socket Error
      modbus.2	2021-02-10 17:48:46.388	warn	(5929) Terminated (UNCAUGHT_EXCEPTION): Without reason
      modbus.2	2021-02-10 17:48:46.387	debug	(5929) Plugin sentry destroyed
      modbus.2	2021-02-10 17:48:46.385	info	(5929) terminating
      modbus.2	2021-02-10 17:48:46.382	debug	(5929) Closing client on purpose.
      modbus.2	2021-02-10 17:48:46.345	error	(5929) Exception-Code: ERR_OUT_OF_RANGE: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:48:46.344	error	(5929) RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2 at boundsError (internal/buffer.js:82:9) at Buffer.readUInt16BE (internal/buff
      modbus.2	2021-02-10 17:48:46.343	error	(5929) uncaught exception: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 2
      modbus.2	2021-02-10 17:48:46.306	debug	(5929) Poll inputRegs DevID(1) address 3002 - 2 bytes
      modbus.2	2021-02-10 17:48:46.305	debug	(5929) Initialization of scale factors done!
      modbus.2	2021-02-10 17:48:46.302	debug	(5929) Poll device 1
      modbus.2	2021-02-10 17:48:46.300	info	(5929) Connected to slave 192.168.178.202
      modbus.2	2021-02-10 17:48:45.655	info	(5929) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.20.1, js-controller: 3.2.13
      modbus.2	2021-02-10 17:48:45.254	debug	(5929) Plugin sentry Initialize Plugin (enabled=true)
      host.RaspSchaltschrank	2021-02-10 17:48:42.978	info	instance system.adapter.modbus.2 started with pid 5929
      • C captainchaos666
        @wendy2702
        wendy2702W Online
        wendy2702W Online
        wendy2702
        @captainchaos666 Oh. Sorry.
        Da habe ich eine "1" verschluckt.
        Sollte 13002 heissen.
          captainchaos666
          @wendy2702
          modbus.2	2021-02-10 19:55:48.976	info	(10919) Disconnected from slave 192.168.178.202
          modbus.2	2021-02-10 19:55:48.975	debug	(10919) Closing client on purpose.
          modbus.2	2021-02-10 19:55:48.920	debug	(10919) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 19:55:48.918	debug	(10919) Poll device 1
          modbus.2	2021-02-10 19:55:47.973	debug	(10919) Cleaning up request fifo.
          modbus.2	2021-02-10 19:55:47.972	debug	(10919) Clearing timeout of the current request.
          modbus.2	2021-02-10 19:55:47.971	debug	(10919) Socket closed with error
          modbus.2	2021-02-10 19:55:47.863	debug	(10919) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 19:55:47.862	debug	(10919) Poll device 1
          modbus.2	2021-02-10 19:55:47.861	info	(10919) Connected to slave 192.168.178.202
          modbus.2	2021-02-10 19:54:47.858	info	(10919) Disconnected from slave 192.168.178.202
          modbus.2	2021-02-10 19:54:47.857	debug	(10919) Closing client on purpose.
          modbus.2	2021-02-10 19:54:46.855	debug	(10919) Cleaning up request fifo.
          modbus.2	2021-02-10 19:54:46.854	debug	(10919) Clearing timeout of the current request.
          modbus.2	2021-02-10 19:54:46.853	debug	(10919) Socket closed with error
          modbus.2	2021-02-10 19:54:46.843	debug	(10919) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 19:54:46.842	debug	(10919) Poll device 1
          modbus.2	2021-02-10 19:54:46.841	info	(10919) Connected to slave 192.168.178.202
          modbus.2	2021-02-10 20:00:50.242	info	(11046) Disconnected from slave 192.168.178.202
          modbus.2	2021-02-10 20:00:50.240	debug	(11046) Closing client on purpose.
          modbus.2	2021-02-10 20:00:50.134	debug	(11046) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 20:00:50.132	debug	(11046) Poll device 1
          modbus.2	2021-02-10 20:00:49.239	debug	(11046) Cleaning up request fifo.
          modbus.2	2021-02-10 20:00:49.239	debug	(11046) Clearing timeout of the current request.
          modbus.2	2021-02-10 20:00:49.238	debug	(11046) Socket closed with error
          modbus.2	2021-02-10 20:00:49.073	debug	(11046) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 20:00:49.072	debug	(11046) Poll device 1
          modbus.2	2021-02-10 20:00:49.071	info	(11046) Connected to slave 192.168.178.202
          modbus.2	2021-02-10 20:00:12.149	debug	(11046) sendTo "listUart" to system.adapter.admin.0 from system.adapter.modbus.2
          modbus.2	2021-02-10 20:00:12.148	info	(11046) List of port: [{"path":"/dev/ttyS0"}]
          modbus.2	2021-02-10 20:00:12.147	info	(11046) Check /dev/ttyS0 : true
          modbus.2	2021-02-10 20:00:12.142	info	(11046) Verify [{"path":"/dev/ttyS0"}]
          modbus.2	2021-02-10 19:59:49.066	info	(11046) Disconnected from slave 192.168.178.202
          modbus.2	2021-02-10 19:59:49.065	debug	(11046) Closing client on purpose.
          modbus.2	2021-02-10 19:59:48.527	debug	(11046) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 19:59:48.526	debug	(11046) Poll device 1
          modbus.2	2021-02-10 19:59:48.062	debug	(11046) Cleaning up request fifo.
          modbus.2	2021-02-10 19:59:48.061	debug	(11046) Clearing timeout of the current request.
          modbus.2	2021-02-10 19:59:48.060	debug	(11046) Socket closed with error
          modbus.2	2021-02-10 19:59:47.445	debug	(11046) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 19:59:47.444	debug	(11046) Initialization of scale factors done!
          modbus.2	2021-02-10 19:59:47.441	debug	(11046) Poll device 1
          modbus.2	2021-02-10 19:59:47.438	info	(11046) Connected to slave 192.168.178.202
          Und so wie es sein sollte, bzw war:
          modbus.2	2021-02-10 20:07:13.480	info	(11164) Disconnected from slave 192.168.178.202
          modbus.2	2021-02-10 20:07:13.479	debug	(11164) Closing client on purpose.
          modbus.2	2021-02-10 20:07:12.478	debug	(11164) Cleaning up request fifo.
          modbus.2	2021-02-10 20:07:12.477	debug	(11164) Clearing timeout of the current request.
          modbus.2	2021-02-10 20:07:12.476	debug	(11164) Socket closed with error
          modbus.2	2021-02-10 20:07:12.464	debug	(11164) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 20:07:12.463	debug	(11164) Poll device 1
          modbus.2	2021-02-10 20:07:12.462	info	(11164) Connected to slave 192.168.178.202
          modbus.2	2021-02-10 20:06:12.459	info	(11164) Disconnected from slave 192.168.178.202
          modbus.2	2021-02-10 20:06:12.458	debug	(11164) Closing client on purpose.
          modbus.2	2021-02-10 20:06:12.421	debug	(11164) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 20:06:12.420	debug	(11164) Poll device 1
          modbus.2	2021-02-10 20:06:11.456	debug	(11164) Cleaning up request fifo.
          modbus.2	2021-02-10 20:06:11.455	debug	(11164) Clearing timeout of the current request.
          modbus.2	2021-02-10 20:06:11.454	debug	(11164) Socket closed with error
          modbus.2	2021-02-10 20:06:11.360	debug	(11164) Poll inputRegs DevID(1) address 13002 - 2 bytes
          modbus.2	2021-02-10 20:06:11.360	debug	(11164) Poll device 1
          modbus.2	2021-02-10 20:06:11.357	info	(11164) Connected to slave 192.168.178.202
          • C captainchaos666
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            wendy2702
            @captainchaos666 Und wenn du jetzt mal beide Werte einträgst?
            Info aus dem Fhem Forum: Hier wird glaube ich mit einem Polldelay von 199 gearbeitet. Ich denke das sind auch millisekunden.
              captainchaos666
              @wendy2702 sagte in Modbus Poll funktioniert nicht:
              das bringt mir ja nichts, es werden einmalig die Daten gelesen und dann die Verbindung abgebaut bis zur Reconnect-Zeit. Damit ich mal mit Polldelay arbeiten könnte wäre schon ein Traum. Wenn die Verbindung stehen bleibt dann kann ich anfangen mit dem Polldelay zu arbeiten
              • C captainchaos666
                wendy2702W Online
                wendy2702W Online
                wendy2702
                @captainchaos666 Wenn ich mir das Script von FHEM anschaue machen die so einen Poll zwischen den einzelnen Abfragen 🤔
                  captainchaos666
                  aber dazu müsst doch die Verbindung aufrecht erhalten bleiben, sonst noch jemand eine Idee
                  • C captainchaos666
                    Matis
                    @captainchaos666 Hast du ne Lösung gefunden? Habe ein ähnliches Problem und komme nicht weiter. Danke.
