  4. Unbekannte Fehlermeldung "iobroker upgrade self"
    6.6k
7 Beiträge 2 Kommentatoren 419 Aufrufe 3 Beobachtet
  • ? Offline
    Moin Moin,
    Ist diese Fehlermeldung beachtenswert ?
    und wenn, was kann ich tun ?
    LG
    pi@RP4-ioBroker:/opt/iobroker $ iobroker upgrade self
    Update js-controller from @3.2.12 to @3.2.13
    NPM version: 6.14.10
    npm install iobroker.js-controller@3.2.13 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.83-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v12.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.83-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v12.20.1
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    Starting node restart.js
      Moin Moin,
      LG
      gyp ERR! not ok
      @blechsoldat
      sudo apt update
      sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
      Und dann würde ich das Gesamtpaket updaten. Da kam gestern ein wichtiges Kernelupdate für die Raspberry Pies rein.
      ? 1 Antwort Letzte Antwort
        @blechsoldat
        sudo apt update
        Danke schön.
        Im Moment gibt es keine Updates für meinen ioBroker.
        Ich werde das hier updaten wenn die Fehlermeldungen weg sind.
        Deine beiden "Befehle" sind ohne Fehler durchgelaufen.
        LG
          Danke schön.
          LG
          @blechsoldat
          Ich meine auch das OS.
          Mit
          sudo apt update
          sudo apt dist-upgrade
          sudo reboot
          müsste da noch einiges aktualisiert werden.
            @blechsoldat
            Mit
            sudo apt update
            sudo reboot
            Das wird (wurde) vorher gemacht.
            Allerdings ohne Reboot. Das nur wenn mich das System dazu auffordert.
            Nun, in diesem falle, habe ich es trotzdem gemacht.
            [vor deinem Vorschlag wurde das ausgeführt]
            sudo apt update
            sudo apt full-upgrade -y
            sudo reboot
              sudo apt update
              sudo reboot
              @blechsoldat sagte in Unbekannte Fehlermeldung "iobroker upgrade self":
              Die Aufforderung kommt im Falle eines Kernelupdates aber nicht.
              uname -a
              Müsste irgendwas mit Kernel 5.10 kommen.
                uname -a
                pi@RP4-ioBroker:~ $ uname -a
                Linux RP4-ioBroker 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
                passt.
