  4. [gelöst] Skripte laufen nicht mehr script.js. compile failed
    5.8k
15 Beiträge 5 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • C Offline
    chaser
    schrieb am zuletzt editiert von chaser
    Hallo Zusammen,
    bis jetzt mit den Hilfedokumenten immer perfekt zurecht gekommen. Jedoch habe ich leider aktuell folgenden Fehler mit den Skripten und komm nicht weiter. „compile failed: at script.js….“
    Log:
    javascript.0	2021-02-01 11:18:15.839	error	(26306) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2021-02-01 11:18:15.838	error	(26306) at runMicrotasks (<anonymous>)
    javascript.0	2021-02-01 11:18:15.838	error	(26306) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2021-02-01 11:18:15.837	error	(26306) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2021-02-01 11:18:15.836	error	(26306) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
    javascript.0	2021-02-01 11:18:15.836	error	(26306) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
    javascript.0	2021-02-01 11:18:15.835	error	(26306) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
    javascript.0	2021-02-01 11:18:15.834	error	(26306) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
    javascript.0	2021-02-01 11:18:15.834	error	(26306) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
    javascript.0	2021-02-01 11:18:15.833	error	(26306) at Object.createScript (vm.js:261:10)
    javascript.0	2021-02-01 11:18:15.832	error	(26306) at new Script (vm.js:88:7)
    javascript.0	2021-02-01 11:18:15.832	error	(26306) SyntaxError: Unexpected number
    javascript.0	2021-02-01 11:18:15.831	error	(26306) ^^
    javascript.0	2021-02-01 11:18:15.830	error	(26306) myDevices.hs100.0 = {};
    javascript.0	2021-02-01 11:18:15.829	error	at script.js.GeräteAuto.Ambilight2:6
    javascript.0	2021-02-01 11:18:15.829	error	(26306) script.js.GeräteAuto.Ambilight2 compile failed:
    Fehler tritt bei allen Skripten gleich auf.
    System:
    Rock64 4GB
    node -v v12.20.1
    npm -v 6.14.10
    js-controller: 3.1.6
    Was habe ich bisher gemacht:
    sudo apt-get update && sudo apt-get upgrade
    sudo reboot
    npm rebuild --> keine Abhilfe
    reinstall-skript von https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten --> keine Abhilfe
    Reset aller Module in node-modules --> keine Abhilfe
    iobroker fix --> keine Abhilfe
    sudo -H -u iobroker npm install iobroker.js-controller --> keine Abhilfe
    iobroker natürlich immer gestoppt und anschließend wieder gestartet.
    Iobroker Neuinstallation mit Backup --> gleicher Fehler
    Hat jemand eine Idee an was das liegt?
    Beste Grüße
    • C chaser
      Hallo Zusammen,
      Log:
      System:
      Rock64 4GB
      node -v v12.20.1
      npm -v 6.14.10
      sudo reboot
      Beste Grüße
      @chaser sagte in Skripte laufen nicht mehr script.js. compile failed::
      Beides richtig durchgeführt?
      Auch wenn ich da erst einmal keine Ursache drin sehe, so müssen npm Befehle aber zwingend im Installationsverzeichnis ausgeführt werden
      Was sthet denn da in Zeile 6?
      C liv-in-skyL 2 Antworten Letzte Antwort
      • C chaser
        Hallo Zusammen,
        Log:
        System:
        Rock64 4GB
        node -v v12.20.1
        npm -v 6.14.10
        sudo reboot
        Beste Grüße
        @chaser sagte: myDevices.hs100.0 = {};
        Schalte im Javascript-Editor auf "Experten-Modus" und stoppe oder lösche das Skript im Ordner "global".
        C P 2 Antworten Letzte Antwort
          chaser
          genau habe sie in /opt/iobroker durchgeführt ist richtig oder?
          Von dem Skript?
          Zeile 6: } else if ((obj.state ? obj.state.val : "") == false) {
          Gesamtskript:
          on({id: 'lgtv.0.states.on', change: "ne"}, function (obj) {
            var value = obj.state.val;
            if ((obj.state ? obj.state.val : "") == true) {
              setState("linkeddevices.0.Ambilight.state"/*Ambilight*/, true);
              setState("linkeddevices.0.Ambilight.state"/*Ambilight*/, false);
          //JTNDeG1.........
            chaser
            im global gibt es die betreffenden Skripte nicht nur von linkeddevice die auch funktionieren.
            Habe auch ein Skript komplett neu angelegt zeigt den selben Fehler auf
            • C chaser
              @chaser sagte: nur von linkeddevice die auch funktionieren.
              Sicher, dass die funktionieren? Schau mal rein, ob dort die angemeckerte Zeile enthalten ist.
              C 1 Antwort Letzte Antwort
                chaser
                Ja habe gerade ein Licht an und aus geschlatet. Funktioniert und auch keine Errors im Log
                • C chaser
                  @chaser sagte: Funktioniert und auch keine Errors im Log
                  Nach Stoppen des Scripts "linkeddevices.0"?
                    chaser
                    @paul53 said in Skripte laufen nicht mehr script.js. compile failed::
                    Danke, Du hast recht. Das Stoppen der Instanz "Linkddevice" bringt nichts. Aber wenn man das linkeddevice skript unter "global" stoppt kommt keine Fehlermeldung mehr.
                    Da aber meine Geräte über Linkeddevice gekoppelt sind funktionieren an sich die Skripte nicht. Würde auch gerne die Funktion von Linkeddevice verwenden. Hast Du eine Idee woran das liegt?
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      @homoran ist das nicht ein ähnliches thema wie gestern - wurde dort nicht auch ein script von linkdevices (unter global) erwähnt - ich nutze den adapter nicht aber da sollte man mal beim adapter nachfragen
                      https://forum.iobroker.net/post/571247
                      • liv-in-skyL liv-in-sky
                        @liv-in-sky sagte in Skripte laufen nicht mehr script.js. compile failed::
                        Ich denke, dem ist @paul53 auch auf der Fährte.
                        Da lasse ich ihn mal machen - der weiß das besser als ich
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          @homoran besser als wir beide :-/
                          • C chaser
                            @chaser sagte: Würde auch gerne die Funktion von Linkeddevice verwenden.
                            Linkeddevices funktioniert auch ohne dieses Script. Das Script ist optional und funktioniert nur, wenn man einen gültigen Variablenbezeichner in die Konfiguration einträgt.
                              chaser
                              Danke Dir vielmals. Stimmt geht auch mit der Deaktivierung des Skripts. Setzte das jetzt auf gelöst. Wenn ich euch beim Fehlerbeheben oder Testen helfen kann lasst es mich wissen.
                                Prince3k
                                Danke, genau das war mein Fehler. Im Global lief ein Script.
