  4. Upgrade zigbee immer error
    6.7k
zigbee
44 Beiträge 4 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • chucky666C chucky666
    @thomas-braun sagte in Upgrade zigbee immer error:
    npm cache clean --force
    root@iobroker:~# iobroker del zigbee
    Delete adapter "zigbee"
    npm uninstall iobroker.zigbee --error --prefix "/opt/iobroker" (System call)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/avrgirl-arduino/package.json'
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.20.1","npm":"6.14.10"})
    npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
    npm ERR! notsup Required: {"node":"~0.10.0"}
    npm ERR! notsup Actual:   {"npm":"6.14.10","node":"12.20.1"}
    npm ERR!     /home/iobroker/.npm/_logs/2021-01-22T14_27_41_981Z-debug.log
    Error deleting adapter zigbee from disk: Error: host.iobroker: Cannot uninstall iobroker.zigbee: 1
    You might have to delete it yourself!
    root@iobroker:~# cd /opt/iobroker
    root@iobroker:/opt/iobroker# npm cache clean --force
    npm WARN using --force I sure hope you know what you are doing.
    #41
    @chucky666 sagte in Upgrade zigbee immer error:
    root@iobroker
    Ist schon mal Obermurks.
    Und eigentlich verschwende ich auch keine Zeit an so verfummelte Systeme.
    Als user anmelden und per sudo das System administrieren. Ist das vielleicht auch noch Docker/Container-Gefummel?
    chucky666C 1 Antwort Letzte Antwort
      root@iobroker
      chucky666C Online
      chucky666C Online
      chucky666
      #42
      erstmal danke für deine Hilfe , macht es sinn iobroker zu löschen und per Backitup wiederherzustellen ?
      das system läuft auf einen Proxmox server , ich hatte damals alles nach Anleitung gemacht
        #43
        @chucky666
        Bei der Kombi root und Proxmox bin ich raus.
        • UncleSamU UncleSam
          Wenn in den nächsten Stunden nicht noch jemand mit einer guten Lösung kommt, würde ich vorschlagen: Backup machen, ioBroker Verzeichnis löschen, ioBroker neu installieren und Backup restoren
          chucky666C Online
          chucky666C Online
          chucky666
          #44
          @unclesam
          Ich habe es jetzt so gemacht und siehe da jetzt klappt alles .
          Hat zwar etwas gedauert aber egal
          Dankeschön für eure Hilfe und Geduld
