  4. IoBroker CPU Load 100%
    6.7k
41 Beiträge 6 Kommentatoren 6.4k Aufrufe 3 Beobachtet
    Benda
    Weiß leider nicht wie ich einen spoiler mache
    dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.4.83-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:11:54 GMT 2020
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] On node 0 totalpages: 1012736
    [    0.000000]   DMA zone: 2304 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
    [    0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
    [    0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:66:E3:7F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8a99dabf-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
    [    0.000000] Memory: 3655604K/4050944K available (10240K kernel code, 739K rwdata, 2816K rodata, 2048K init, 854K bss, 133196K reserved, 262144K cma-reserved, 3264512K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 31115 entries in 61 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] random: get_random_bytes called from start_kernel+0x344/0x518 with crng_init=0
    [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [    0.000022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [    0.000098] bcm2835: system timer (irq = 17)
    [    0.000744] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000760] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000776] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [    0.000789] Switching to timer-based delay loop, resolution 18ns
    [    0.001023] Console: colour dummy device 80x30
    [    0.001057] printk: console [tty1] enabled
    [    0.001107] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [    0.001128] pid_max: default: 32768 minimum: 301
    [    0.001276] LSM: Security Framework initializing
    [    0.001467] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001490] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002826] Disabling memory control group subsystem
    [    0.002947] CPU: Testing write buffer coherency: ok
    [    0.003452] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.004363] Setting up static identity map for 0x200000 - 0x20003c
    [    0.004569] rcu: Hierarchical SRCU implementation.
    [    0.005245] smp: Bringing up secondary CPUs ...
    [    0.006424] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.007744] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.009001] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.009159] smp: Brought up 1 node, 4 CPUs
    [    0.009176] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.009188] CPU: All CPU(s) started in HYP mode.
    [    0.009200] CPU: Virtualization extensions available.
    [    0.010014] devtmpfs: initialized
    [    0.023934] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [    0.024192] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.024220] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.031026] pinctrl core: initialized pinctrl subsystem
    [    0.032004] NET: Registered protocol family 16
    [    0.035906] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.036488] audit: initializing netlink subsys (disabled)
    [    0.036749] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
    [    0.037881] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.037896] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.038216] Serial: AMBA PL011 UART driver
    [    0.041744] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.060821] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-08 14:31, variant start
    [    0.070836] raspberrypi-firmware soc:firmware: Firmware hash is 194a85abd768c7334bbadc3f1911c10a7d18ed14
    [    0.125951] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [    0.129812] vgaarb: loaded
    [    0.130276] SCSI subsystem initialized
    [    0.130510] usbcore: registered new interface driver usbfs
    [    0.130578] usbcore: registered new interface driver hub
    [    0.130699] usbcore: registered new device driver usb
    [    0.131065] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
    [    0.132879] clocksource: Switched to clocksource arch_sys_counter
    [    0.891229] VFS: Disk quotas dquot_6.6.0
    [    0.891328] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.891505] FS-Cache: Loaded
    [    0.891694] CacheFiles: Loaded
    [    0.901948] thermal_sys: Registered thermal governor 'step_wise'
    [    0.902324] NET: Registered protocol family 2
    [    0.903315] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    0.903346] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.903408] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.903479] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.903626] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.903659] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.903910] NET: Registered protocol family 1
    [    0.904633] RPC: Registered named UNIX socket transport module.
    [    0.904646] RPC: Registered udp transport module.
    [    0.904659] RPC: Registered tcp transport module.
    [    0.904672] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.904693] PCI: CLS 0 bytes, default 64
    [    0.906601] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.908819] Initialise system trusted keyrings
    [    0.909047] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    0.920053] FS-Cache: Netfs 'nfs' registered for caching
    [    0.920782] NFS: Registering the id_resolver key type
    [    0.920844] Key type id_resolver registered
    [    0.920858] Key type id_legacy registered
    [    0.920880] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.921971] Key type asymmetric registered
    [    0.921985] Asymmetric key parser 'x509' registered
    [    0.922175] bounce: pool size: 64 pages
    [    0.922223] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [    0.922470] io scheduler mq-deadline registered
    [    0.922485] io scheduler kyber registered
    [    0.926509] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.926532] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [    0.926604] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
    [    0.926675] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [    0.985024] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
    [    0.985345] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    0.985365] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.985385] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
    [    0.985443] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    0.985713] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    0.988969] PCI: bus0: Fast back to back transfers disabled
    [    0.989200] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    0.989348] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    0.989781] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    0.993051] PCI: bus1: Fast back to back transfers disabled
    [    0.993111] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    0.993134] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    0.993217] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.993241] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    0.993556] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    0.993810] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
    [    0.994219] pcieport 0000:00:00.0: AER: enabled with IRQ 55
    [    0.994557] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    1.001497] iproc-rng200 fe104000.rng: hwrng registered
    [    1.001843] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    1.002508] vc-sm: Videocore shared memory driver
    [    1.003128] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    1.015397] brd: module loaded
    [    1.027879] loop: module loaded
    [    1.029271] Loading iSCSI transport class v2.0-870.
    [    1.031268] libphy: Fixed MDIO Bus: probed
    [    1.031883] bcmgenet fd580000.ethernet: failed to get enet clock
    [    1.031903] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [    1.031926] bcmgenet fd580000.ethernet: failed to get enet-wol clock
    [    1.031947] bcmgenet fd580000.ethernet: failed to get enet-eee clock
    [    1.031975] bcmgenet: Skipping UMAC reset
    [    1.042959] libphy: bcmgenet MII bus: probed
    [    1.133071] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [    1.134204] usbcore: registered new interface driver r8152
    [    1.134270] usbcore: registered new interface driver lan78xx
    [    1.134328] usbcore: registered new interface driver smsc95xx
    [    1.134819] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.134854] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    1.138171] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
    [    1.139491] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [    1.139509] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.139525] usb usb1: Product: xHCI Host Controller
    [    1.139540] usb usb1: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
    [    1.139555] usb usb1: SerialNumber: 0000:01:00.0
    [    1.140173] hub 1-0:1.0: USB hub found
    [    1.140269] hub 1-0:1.0: 1 port detected
    [    1.140797] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    1.140823] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    1.140847] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    1.141335] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
    [    1.141352] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.141368] usb usb2: Product: xHCI Host Controller
    [    1.141383] usb usb2: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
    [    1.141397] usb usb2: SerialNumber: 0000:01:00.0
    [    1.142006] hub 2-0:1.0: USB hub found
    [    1.142105] hub 2-0:1.0: 4 ports detected
    [    1.143552] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.143842] dwc_otg: FIQ enabled
    [    1.143855] dwc_otg: NAK holdoff enabled
    [    1.143867] dwc_otg: FIQ split-transaction FSM enabled
    [    1.143895] Module dwc_common_port init
    [    1.144350] usbcore: registered new interface driver uas
    [    1.144455] usbcore: registered new interface driver usb-storage
    [    1.144649] mousedev: PS/2 mouse device common for all mice
    [    1.146505] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    1.149929] sdhci: Secure Digital Host Controller Interface driver
    [    1.149942] sdhci: Copyright(c) Pierre Ossman
    [    1.150577] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    1.151182] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.155160] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.155470] hidraw: raw HID events driver (C) Jiri Kosina
    [    1.155651] usbcore: registered new interface driver usbhid
    [    1.155663] usbhid: USB HID core driver
    [    1.156703] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [    1.158645] [vc_sm_connected_init]: start
    [    1.167475] [vc_sm_connected_init]: end - returning 0
    [    1.169726] Initializing XFRM netlink socket
    [    1.169765] NET: Registered protocol family 17
    [    1.169890] Key type dns_resolver registered
    [    1.170295] Registering SWP/SWPB emulation handler
    [    1.170607] registered taskstats version 1
    [    1.170625] Loading compiled-in X.509 certificates
    [    1.171173] Key type ._fscrypt registered
    [    1.171187] Key type .fscrypt registered
    [    1.182076] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    1.182148] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
    [    1.188360] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    1.189332] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    1.189348] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    1.237393] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.239062] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.240792] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.244787] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.246473] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.253313] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [    1.256374] of_cfs_init
    [    1.256493] of_cfs_init: OK
    [    1.257579] Waiting for root device PARTUUID=8a99dabf-02...
    [    1.296888] random: fast init done
    [    1.360179] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [    1.361170] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
    [    1.364299] mmc1: new high speed SDIO card at address 0001
    [    1.364823]  mmcblk0: p1 p2
    [    1.383269] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.383343] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.388883] devtmpfs: mounted
    [    1.397640] Freeing unused kernel memory: 2048K
    [    1.423189] Run /sbin/init as init process
    [    1.502943] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    1.685553] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    1.685572] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.685587] usb 1-1: Product: USB2.0 Hub
    [    1.687777] hub 1-1:1.0: USB hub found
    [    1.688082] hub 1-1:1.0: 4 ports detected
    [    1.849704] systemd[1]: System time before build time, advancing clock.
    [    1.945691] NET: Registered protocol family 10
    [    1.947041] Segment Routing with IPv6
    [    1.990547] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    1.991307] systemd[1]: Detected architecture arm.
    [    2.053709] systemd[1]: Set hostname to <SchnubbBerry>.
    [    2.832336] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.844899] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.844991] systemd[1]: Reached target Swap.
    [    2.845486] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.847599] systemd[1]: Created slice User and Session Slice.
    [    2.848396] systemd[1]: Listening on Syslog Socket.
    [    2.848970] systemd[1]: Listening on udev Kernel Socket.
    [    2.849580] systemd[1]: Listening on udev Control Socket.
    [    2.851751] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    2.852811] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    3.031686] i2c /dev entries driver
    [    3.478318] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.568965] systemd-journald[120]: Received request to flush runtime journal from PID 1
    [    4.182303] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [    4.182824] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [    4.183648] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [    4.184081] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [    4.239955] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.242009] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    4.242033] [vc_sm_connected_init]: start
    [    4.254339] [vc_sm_connected_init]: installed successfully
    [    4.257588] mc: Linux media interface: v0.10
    [    4.285019] videodev: Linux video capture interface: v2.00
    [    4.327191] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.353489] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.366973] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.376832] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.380222] bcm2835_audio bcm2835_audio: card created with 8 channels
    [    4.391476] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.397562] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    4.397630] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    4.402772] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [    4.407054] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [    4.408202] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [    4.408459] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    4.408507] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    4.408919] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [    4.408944] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [    4.408965] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [    4.408986] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [    4.409005] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [    4.412812] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [    4.421642] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    4.421749] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    4.434444] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.698810] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    4.790544] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [    4.824886] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    4.901082] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    4.915884] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    4.916643] usbcore: registered new interface driver brcmfmac
    [    4.942624] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [    5.026116] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [    5.026239] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    5.027704] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    5.027719] [drm] No driver support for vblank timestamp query.
    [    5.027747] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
    [    5.030723] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [    5.190527] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    5.201012] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
    [    7.089039] uart-pl011 fe201000.serial: no DMA platform data
    [    7.142807] 8021q: 802.1Q VLAN Support v1.8
    [    7.314644] random: crng init done
    [    7.314683] random: 7 urandom warning(s) missed due to ratelimiting
    [    7.544116] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [    7.766505] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [    8.163787] bcmgenet: Skipping UMAC reset
    [    8.165811] bcmgenet fd580000.ethernet: configuring instance for external RGMII
    [    8.166008] bcmgenet fd580000.ethernet eth0: Link is Down
    [   10.551305] broken atomic modeset userspace detected, disabling atomic
    [   11.208680] broken atomic modeset userspace detected, disabling atomic
    [   12.222199] broken atomic modeset userspace detected, disabling atomic
    [   12.823219] broken atomic modeset userspace detected, disabling atomic
    [   13.353025] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   13.353055] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   13.436001] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   13.880097] broken atomic modeset userspace detected, disabling atomic
    [   14.487402] broken atomic modeset userspace detected, disabling atomic
    [   14.637272] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [   15.522362] broken atomic modeset userspace detected, disabling atomic
    [   16.123687] broken atomic modeset userspace detected, disabling atomic
    [   17.177949] broken atomic modeset userspace detected, disabling atomic
    [   17.786990] broken atomic modeset userspace detected, disabling atomic
    [   18.862706] broken atomic modeset userspace detected, disabling atomic
    [   19.457815] broken atomic modeset userspace detected, disabling atomic
    [   20.477649] broken atomic modeset userspace detected, disabling atomic
    [   21.083302] broken atomic modeset userspace detected, disabling atomic
    [   22.135613] broken atomic modeset userspace detected, disabling atomic
    [   22.744534] broken atomic modeset userspace detected, disabling atomic
    [   23.750723] broken atomic modeset userspace detected, disabling atomic
    [   24.355163] broken atomic modeset userspace detected, disabling atomic
    [   25.488983] broken atomic modeset userspace detected, disabling atomic
    [   26.213096] broken atomic modeset userspace detected, disabling atomic
    • B Benda
      dmesg
      @jan-benda sagte in IoBroker CPU Load 100%:
      Vielleicht sieht @Thomas-Braun nochmal drüber, aber das sieht IMHO (was nix heißt) gut aus
      Wobei ich nicht weiß was das hier ist:
      Wieso sieht man bei dir nie den Prompt und den Befehl?
        @homoran @Jan-Benda
        Das sieht soweit i. O. aus, allerdings verweist
        auf 'irgendwas', was auf X zugreifen will. Läuft da VNC oder sowas?
        who -r
        liefert? Ein Display hängt ja nicht am Pi dran. Dann kann man auch X ausknipsen.
        B 1 Antwort Letzte Antwort
          @homoran @Jan-Benda
          who -r
          Benda
          @thomas-braun said in IoBroker CPU Load 100%:
          who -r
          pi@SchnubbBerry:~ $ who -r
                   Runlevel 5   2021-01-18 12:08
          Ein Display hängt nicht dran.
          • B Benda
            who -r
            @jan-benda
            Dann stell da RunLevel 3 ein. Geht am besten per
            raspi-config
            Irgendwo in den Boot Optionen kann man auswählen, dass man in das CLI with LogIn required (oder so ähnlich) booten will.
              @jan-benda
              raspi-config
              @thomas-braun sagte in IoBroker CPU Load 100%:
              und wenn du schon in raspi-config drin bist, schalte dir den SSH Zugang für puTTY frei
                @homoran @Jan-Benda
                Und die Zeitzone auf Europe/Berlin. Wird ja auch gerne übersehen.
                  @homoran @Jan-Benda
                  Benda
                  puTTY verwende ich nicht, greife nur über den mac auf den raspberry zu.
                  Timezone war schon korrekt
                  Die Bootoption habe ich auf Console Autologin gestellt.
                  Als Auslöser für das Problem vermute ich mittlerweile mein Bewegungsmelder Javascript,
                  da meine Hue Lampen beim ausschalten automatisch wieder einschalten -.-
                  Mit dem Deaktivieren des javascript adapters sollte das Script aber doch eigentlich umgangen werden?
                  in top sehe ich nach wie vor die schwankende Anzahl an iobroker / node prozessen
                  • B Benda
                    Console Autologin
                    Würde ich nicht machen. Dann ist da immer eine shell offen, die per sudo alles darf. Besser auf 'LogIn Required' stellen. Von deinem Mac gehst du vermutlich ja eh per ssh und Passwort auf die Kiste.
                      Console Autologin
                      Benda
                      Console Autologin
                      Würde ich nicht mache. Dann ist da immer eine shell offen, die per sudo alles darf. Besser auf 'LogIn Required' stellen. Von deinem Mac gehst du vermutlich ja eh per ssh und Passwort auf die Kiste.
                      okay, verstanden, war ein verständnisfehler, dachte der raspberry fährt sonst gar nicht erst hoch ohne login.
                      • B Benda
                        Console Autologin
                        Doch, und die Systemuser wie 'iobroker' wuseln auch los. Also kein Problem, das sich ein Standard-User nochmal ordentlich anmelden muss.
                          Benda
                          Ich habe eben festgestellt, dass sich die adapter automatisch wieder aktivieren,
                          also nach:
                          iobroker stop javascript.0
                          warte 1 min
                          iobroker list instances
                          listet den javascript adapter wieder als enabled...
                          paul53P HomoranH 2 Antworten Letzte Antwort
                          • B Benda
                            also nach:
                            warte 1 min
                            @jan-benda sagte: warte 1 min
                            Das kann zu kurz sein.
                              Benda
                              @paul53 wenn ich direkt checke taucht der adapter als disabled auf
                              • B Benda
                                also nach:
                                warte 1 min
                                War er denn jemals disabled?
                                oder ist ioBroker sooo beschäftigt, dass der stop Befehl nie ankommt
                                  Benda
                                  Nochmal zum nachvollziehen:
                                  pi@SchnubbBerry:~ $ iobroker list instances
                                    system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.alexa2.0                : alexa2                -  enabled
                                    system.adapter.deconz.0                : deconz                -  enabled
                                    system.adapter.discovery.0             : discovery             -  enabled
                                    system.adapter.ham.0                   : ham                   - disabled
                                    system.adapter.heos.0                  : heos                  - disabled
                                    system.adapter.hue.0                   : hue                   -  enabled, port: 443
                                    system.adapter.info.0                  : info                  -  enabled
                                    system.adapter.javascript.0            : javascript            -  enabled
                                    system.adapter.scenes.0                : scenes                -  enabled
                                    system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.wifilight.0             : wifilight             -  enabled
                                    system.adapter.yahka.0                 : yahka                 -  enabled
                                    system.adapter.yeelight-2.0            : yeelight-2            -  enabled
                                    system.adapter.yeelight-2.1            : yeelight-2            -  enabled
                                  + instance is alive
                                  pi@SchnubbBerry:~ $ iobroker stop javascript.0
                                  The adapter "javascript.0" was stopped.
                                    system.adapter.javascript.0            : javascript            - disabled
                                  + instance is alive
                                  + instance is alive
                                  pi@SchnubbBerry:~ $
                                  • B Benda
                                    + instance is alive
                                    + instance is alive
                                    + instance is alive
                                    pi@SchnubbBerry:~ $
                                    @jan-benda Da ist ja auch der admin nicht 'alive'.
                                      Benda
                                      Ich habs nun wieder ins admin geschafft, über:
                                      iobroker del javascript
                                      Merkwürdigerweise ist die javascript instanz trotzdem noch aktiv und die skripte waren auch am laufen..
                                      Schwer nachvollziehbar..
                                      B HomoranH 2 Antworten Letzte Antwort
                                      • B Benda
                                        Benda
                                        Als Referenz, hier ist mein Kandidat, der das ganze Schlamassel vermutlich verursacht hat:
                                        https://forum.iobroker.net/topic/41100/bewegungsmelder-skript-für-raum-mit-schaltbarem-licht
                                        • B Benda
                                          @benda sagte in IoBroker CPU Load 100%:
                                          hast du vielleicht zwei ioBroker Installationen parallel laufen?
                                          einmal original, und einmal irrtümlich in einem anderen Verzeichnis (z.B. home/pi???) installiert, weil du bei einem npm... Befehl nicht vorher nach /opt/iobroker gewechselt hattest?
