  2. English
  3. ioBroker general
  4. Zigbee Adapter installation failures
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
zigbee adapter cc2531
3 Beiträge 2 Kommentatoren 920 Aufrufe 2 Beobachtet
  • robbertnlR Offline
    robbertnlR Offline
    robbertnl
    schrieb am zuletzt editiert von robbertnl
    Hello,
    I'm trying to use a newly purchased Zigbee CC2531 USB stick with pre-loaded Koenkk firmware. I installed ioBroker with the following commands on a newly installed Raspbian image on a Pi 3 (also tried a Pi 4, same misery). I sed the following command to install everything
    curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
    sudo apt install -y nodejs
    sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
    sudo reboot
    curl -sLf https://iobroker.net/install.sh | bash -
    sudo reboot
    The installation of ioBroker gives a few errors, but I've read that this is normal?!? Anyway, it starts and works properly from here. Now when I try to add Zigbee Adapter (version 1.3.1) it gives a lot of errors when "more" is toggle.
    The installation errors I get are related to SerialPort, but I can't seem to find a solution:
    $ ./iobroker add zigbee  --host raspberrypi
    NPM version: 6.14.8
    npm install iobroker.zigbee@1.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~
    ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^
    In file included from ../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.20.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    host.raspberrypi install adapter zigbee
    upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_rb280.png img/tuya_rb280.png image/png
    upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_color.png img/philips_hue_gu10_color.png image/png
    upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_router.png img/lumi_router.png image/png
    upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_recessed_spot_light.png img/ikea_recessed_spot_light.png image/png
    upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27.png img/ikea_bulb_E27.png image/png
    upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
    upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
    upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
    upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
    upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
    upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
    upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/NAS-AB02B0.png img/NAS-AB02B0.png image/png
    upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Moes_Wall_Thermostat.png img/Moes_Wall_Thermostat.png image/png
    upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
    upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HY08WE.png img/HY08WE.png image/png
    upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
    upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
    upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
    upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
    upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
    upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
    upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
    upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
    upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
    upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
    upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
    upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
    upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
    upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
    upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
    upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
    upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    host.raspberrypi object system.adapter.zigbee created/updated
    host.raspberrypi create instance zigbee
    host.raspberrypi object zigbee.0.info.groups created
    host.raspberrypi object zigbee.0.info.pairingMessage created
    host.raspberrypi object zigbee.0.info.pairingCountdown created
    host.raspberrypi object zigbee.0.info.pairingMode created
    host.raspberrypi object zigbee.0.info.connection created
    host.raspberrypi object zigbee.0.info created
    host.raspberrypi object system.adapter.zigbee.0.sigKill created
    host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
    host.raspberrypi object system.adapter.zigbee.0.outputCount created
    host.raspberrypi object system.adapter.zigbee.0.inputCount created
    host.raspberrypi object system.adapter.zigbee.0.uptime created
    host.raspberrypi object system.adapter.zigbee.0.memRss created
    host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
    host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
    host.raspberrypi object system.adapter.zigbee.0.cputime created
    host.raspberrypi object system.adapter.zigbee.0.cpu created
    host.raspberrypi object system.adapter.zigbee.0.compactMode created
    host.raspberrypi object system.adapter.zigbee.0.connected created
    host.raspberrypi object system.adapter.zigbee.0.alive created
    host.raspberrypi Set default value of zigbee.0.info.groups:
    host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
    host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
    host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
    host.raspberrypi Set default value of zigbee.0.info.connection: false
    host.raspberrypi object system.adapter.zigbee.0 created
    process exited with code 0
    So I found some commands to install version 1.4.0. But that didn't help either:
    cd /opt/iobroker
    sudo -u iobroker npm i iobroker.zigbee@1.4.0
    iobroker upload all
    > @serialport/bindings@9.0.2 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=12.20.0 runtime=node arch=arm libc= platform=linux)
    make: Entering directory '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
      CXX(target) Release/obj.target/bindings/src/serialport.o
      CXX(target) Release/obj.target/bindings/src/serialport_unix.o
      CXX(target) Release/obj.target/bindings/src/poller.o
      CXX(target) Release/obj.target/bindings/src/serialport_linux.o
      SOLINK_MODULE(target) Release/obj.target/bindings.node
      COPY Release/bindings.node
    make: Leaving directory '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
    > serialport@9.0.2 postinstall /opt/iobroker/node_modules/zigbee-herdsman/node_modules/serialport
    > node thank-you.js
    Thank you for using serialport!
    If you rely on this package, please consider supporting our open collective:
    > https://opencollective.com/serialport/donate
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.2.1 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.2.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.2.1 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    + iobroker.zigbee@1.4.0
    added 1621 packages from 775 contributors in 223.771s
    59 packages are looking for funding
      run `npm fund` for details
    Strangely enough the adapter is added and an instance is created. But if I add the serial port (found using ls -l /dev/serial/by-id) in the config the instance is always yellow. The logs show me:
    2020-12-23 17:56:59.641 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-12-23 17:57:02.112 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 5711
    2020-12-23 17:57:05.513 - info: zigbee.0 (5711) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.1.6
    2020-12-23 17:57:05.574 - info: zigbee.0 (5711) Starting Zigbee npm ...
    2020-12-23 17:57:05.849 - info: zigbee.0 (5711) Installed Version: undefined
    2020-12-23 17:57:15.517 - error: zigbee.0 (5711) Failed to start Zigbee
    2020-12-23 17:57:15.519 - error: zigbee.0 (5711) Error: SREQ '--> SYS - osalNvWrite - {"id":143,"len":1,"offset":0,"value":{"type":"Buffer","data":[1]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)')
    at Znp. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:291:27)
    at Generator.next ()
    at fulfilled (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58)
    2020-12-23 17:57:25.524 - info: zigbee.0 (5711) Try to reconnect. 1 attempts left
    2020-12-23 17:57:25.529 - info: zigbee.0 (5711) Starting Zigbee npm ...
    2020-12-23 17:57:25.566 - info: zigbee.0 (5711) Installed Version: undefined
    2020-12-23 17:57:25.890 - error: zigbee.0 (5711) Failed to start Zigbee
    2020-12-23 17:57:25.892 - error: zigbee.0 (5711) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    at Znp. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
    at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
    at new Promise ()
    at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
    at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
    at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    I'm using node and nodejs version 12.20, npm version 6.14.8 and js-controller 3.1.6.
    Hope someone can help.
    Thanks,
    Robbert
    • robbertnlR robbertnl
      Hello,
      sudo reboot
      sudo reboot
      NPM version: 6.14.8
      cd /opt/iobroker
      iobroker upload all
      > node thank-you.js
      at new Promise ()
      Thanks,
      Robbert
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @Robbert-Brackel
      The "errors" you encountered during installations are warnings, not errors. They are part of the serial-ort library. As far as i read them, i would say that they are safety warnings about possible buffer overflows.
      These are not the cause for the error upon adapter start.
      The message
      hints at an error with a component. In this case, since you have not yet added device i would suspect that the firmware on the stick is not ok, and refresh the stick with the proper firmware.
      A.
      robbertnlR 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @Robbert-Brackel
        The message
        A.
        robbertnlR Offline
        robbertnlR Offline
        robbertnl
        @Asgothian
        Thanks that worked! I was told that the stick was flashed and tested correctly, so after a reflash all now works brilliantly.
