  4. BLE Adapter Update Problem?
    6.7k
ble adapterbluetooth low energy
4 Beiträge 2 Kommentatoren 289 Aufrufe 1 Beobachtet
    M-A-X
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Qnap NAS
    Arbeitsspeicher: 2GB
    Festplattenart: virtuelle HDD
    Betriebssystem: Debian
    Node-Version: 12.19.0
    Nodejs-Version: 12.19.0
    NPM-Version: 6.14.8
    Installationsart: Skript
    Kaum ein "Problem" gelöst, kommt das nächste? Oder ist das normal?.
    Ich hab den BLE Adapter von 0.11.8 auf 0.12.0 geupdatet (über den Info Tab). Der dortige Log zeigt:
    npm install iobroker.ble@0.12.0 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/BluetoothHciSocket.cpp:8:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:761:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:578:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
    upload [7] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
    Update "system.adapter.ble.0"
    upload [6] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
    upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
    upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
    upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.map build/index.map application/json
    upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
    upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
    upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
    Adapter "ble" updated
    process exited with code 0
    Die langen Zeilen 2&3 sehen für mich nach einem Fehler aus. Der Adapter läuft aber (erstmal?).
    Muss ich mir Sorgen machen?
    Danke im Voraus
    Max
    • M M-A-X
      NPM-Version: 6.14.8
      Danke im Voraus
      Max
      @M-A-X
      Nein, alles i. O.
        @M-A-X
        Nein, alles i. O.
        M-A-X
        @Thomas-Braun Top, danke :) diese Warnings haben mich verunsichert zusammen mit den endlos langen Zeilen :)
        • M M-A-X
          @M-A-X
          Warning = Hinweis
          Error = Fehler
          Warnings sind erstmal nicht wild.
