  4. Installationsproblem / Fehler mihome-vacuum Installation
    6.7k
mihome-vacuuminstallationsfehlerinstallationsprobleme
4 Beiträge 2 Kommentatoren 649 Aufrufe 2 Beobachtet
  • patsmoP Offline
    patsmoP Offline
    patsmo
    ich habe immer die identische Fehlermeldung bei meiner Installation vom mihome-vacuum Adapter:
    $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master" mihome-vacuum
    install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master
    NPM version: 6.14.8npm install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
    gyp ERR! System Linux 5.4.72-v7l+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v14.15.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1048:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)node-pre-gyp ERR! System Linux 5.4.72-v7l+node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v14.15.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm
    ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-11-09T15_35_06_007Z-debug.log
    ERROR: host.raspberrypi Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/master: 1
    Mein System:
    Raspberry Pi 4 - 2 GB
    ioBroker neueste Version
    npm neueste Version
    Node.js neues Version
    Köntn ihr mir hier unter die Arme greifen?
    Danke und Grüße,
    Patrick
    • patsmoP patsmo
      gyp
      npm
      npm
      Mein System:
      npm neueste Version
      Danke und Grüße,
      Patrick
      @patsmo pixman und canvas nachinstallieren
      patsmoP 1 Antwort Letzte Antwort
        patsmoP Offline
        patsmoP Offline
        patsmo
        @Thomas-Braun kannst du mir die genauen Befehle zusenden?
        • patsmoP patsmo
          @patsmo
          sudo apt update
          sudo apt install libpixman-1-0 libpixman-1-dev
          sudo apt dist-upgrade
          sudo reboot
          Dein node ist aber auch falsch installiert. Das zuerst gerade rücken.
          Lies hier:
