  4. Zigbee Problem nach Neustart
    6.7k
errorproblemzigbee 3.0zigbeeadapter
3 Beiträge 3 Kommentatoren 561 Aufrufe 2 Beobachtet
    ma
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Beelink U55
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu 20.04.1 LTS
    Node-Version: 12.19.0
    Nodejs-Version: 12.19.0
    NPM-Version: 6.14.8
    Installationsart: Skript
    Image genutzt: Nein
    Zigbee Adapter Version 1.2.1
    Zigbee Coordinator CC2538+CC2592 PA
    Ort/Name der Imagedatei: -
    2020-11-08 10:53:00.375 - error: zigbee.0 (2737) Failed to start Zigbee
    2020-11-08 10:53:00.377 - error: zigbee.0 (2737) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:89:31)
    at Generator.throw ()
    at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
    2020-11-08 10:53:10.650 - error: zigbee.0 (2737) Failed to start Zigbee
    2020-11-08 10:53:10.651 - error: zigbee.0 (2737) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    at Znp. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
    at Generator.next ()
    at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
    at new Promise ()
    at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
    at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
    at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
    at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
    Die oben stehenden Fehlermeldungen bekomme ich nach dem Neustart meines iobroker Host.
    Scheinbar kann die Verbindung zum CC2538+CC2592 PA nicht aufgebaut werden ?
    Ich kann das Problem lösen indem ich den Adapter manuell Neustarte, danach funktioniert alles wieder problemlos.
    Komisch ist das das Problem nur nach einem Neustart auftritt ansonsten habe ich keine Probleme mit dem CC2538+CC2592 PA oder Adapter.
    Hat vlt. jemand ähnliche Probleme oder sogar eine Lösung ?
    Grundsätzlich kein großes Problem da es nur nach Neustart Probleme gibt aber trotzdem würde ich gerne verstehen woran das liegt.
    ostseereiterO AsgothianA 2 Antworten Letzte Antwort
    • M ma
      Festplattenart: SSD
      NPM-Version: 6.14.8
      Image genutzt: Nein
      at new Promise ()
      ostseereiterO Offline
      ostseereiter
      @ma Das ist nach einen Neustart so manchmaal muss man auch den Stick abziehen
      Gruß OSR
      Plattform
      Linux x64 CPUs2 AMD G-T56N Processor 1646 MHz 8GB RAM
      • M ma
        Festplattenart: SSD
        NPM-Version: 6.14.8
        Image genutzt: Nein
        at new Promise ()
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @ma Wenn das Problem auftritt solltest du schauen ob noch ein Prozess die serielle Schnittstelle blockiert hat. Das ist (laut Meldung die Ursache dafür das der Adapter nicht gestartet werden kann.
        A.
