  4. Error: EACCES / ENOTDIR - wie beheben?
    6.7k
eaccesenotdirmkdir
3 Beiträge 2 Kommentatoren 250 Aufrufe 2 Beobachtet
  • ? Offline
    Systemdata Pi4
    Hardwaresystem: NUC/Pi3/etc.
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Node-Version: 12.19.0
    Nodejs-Version: 12.19.0
    NPM-Version: 6.14.8
    backitup Version: 1.7
    javascript Version: 4.10
    Hallo Gemeinde,
    Ich hab leider keine Ahnung wie ich das beheben kann bzw. warum ich dieses Problem überhaupt habe. Starte ich z.b. manuell bei backitup eine Sicherung bekomme ich folgende Fehlermeldung:
         Gestartet...
         [DEBUG] [mount] start with                   {"mountType":"CIFS","type":"storage","source":"dropbox","mount":"//192.168.1.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/backup/iobroker/","dirMinimal":"sharename/backupDir","user":"rpibackup","pass":"****"}
         [DEBUG] [mount] - mount successfully completed
         [DEBUG] [mount] - done
         [DEBUG] [iobroker] start with          {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"manuell","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"dropbox","mount":"//192.168.1.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/backup/iobroker/","dirMinimal":"sharename/backupDir","user":"rpibackup","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dropbox":{"enabled":true,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/iot raspi backup","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"dropbox","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"dropbox","mount":"192.168.1.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/backup/iobroker/","dirMinimal":"sharename/backupDir","user":"rpibackup","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/iot raspi backup","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"dropbox","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"dropbox","mount":"192.168.1.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/backup/iobroker/","dirMinimal":"sharename/backupDir","user":"rpibackup","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/iot raspi backup","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"dropbox","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"dropbox","mount":"192.168.1.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/backup/iobroker/","dirMinimal":"sharename/backupDir","user":"rpibackup","pass":"****"},"dropbox":{"enabled":true,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/iot raspi backup","dirMinimal":"/backupDir/minimal"},"googledrive":{"enabled":false,"type":"storage","source":"dropbox","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"philo686","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
         [DEBUG] [iobroker] - host.iopi4 4941 states saved
         [ERROR] [iobroker] - (node:10141) UnhandledPromiseRejectionWarning: Error: ENOTDIR: not a directory, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup'
    at Object.mkdirSync (fs.js:921:3)
    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:296:32
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
         [ERROR] [iobroker] - (node:10141) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
         (node:10141) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Eine Ähnliche Fehlermeldung bekam ich heute vom Javascript Adapter nach dem ich diesen neu gestartet habe (unten nur ein Auszug aus dem Log von einem Skript):
         javascript.0	2020-11-06 21:39:05.520	info	(20819) Created script file on disk                /mnt/iobroker-share/skripte/common/Wassersensor_Poolpumpe_Turnraum.js
         javascript.0	2020-11-06 21:39:05.520	error	(20819) Cannot write file /mnt/iobroker-share/skripte/common/Waschmaschine.js: Error: EACCES: permission denied, mkdir '/mnt/iobroker-share/skripte/common'
    Weiters hab ich einem Forumeintrag gelesen, dass evbentl. folgende Info hilfreich sein könnte:
         Runlevel 5   2020-11-06 22:40
         pi
         /usr/bin/nodejs
         v12.19.0
         /usr/bin/node
         v12.19.0
         /usr/bin/npm
         6.14.8
         nodejs:
         Installiert:           12.19.0-1nodesourc
         Installationskandidat: 12.19.0-1nodesource1
         Versionstabelle:
         *** 12.19.0-1nodesource1 500
        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
        100 /var/lib/dpkg/status
        10.21.0~dfsg-1~deb10u1+rpi1 500
    Hat jemand damit Erfahrung oder Tipps wie ich das beheben kann?
      Systemdata Pi4
      NPM-Version: 6.14.8
      Hallo Gemeinde,
           Gestartet...
           pi
           /usr/bin/nodejs
           v12.19.0
           /usr/bin/node
           v12.19.0
           /usr/bin/npm
           6.14.8
           nodejs:
           Versionstabelle:
      @philo686 Was mountest du denn da wie wohin und woher?
      ? 1 Antwort Letzte Antwort
        @Thomas-Braun ich muss gestehen ich weiß nicht woher der Befehl stammt - gehöre zu den Anfängern.... Eine Vermutung habe ich, die wäre, dass ich bei Lovelace im YAML Code für die Themes irrtümlich einen Code mit mnt für einen bestimmten Ordner eingab. Mittlerweile ist dieser aber wieder entfernt.
        Ich denke die beiden Probleme sind unabhängig voneinander.
        Das Problem bei den Skripten hab ich erst kürzlich. Und ich habe an den Blockly Skripten auch nichts geändert. Wenn die Fehlermeldungen keine weitere Auswirkung haben, dann ignoriere ich diese einfach.
        Die Sache mit Backitup habe ich seit der letzten Wiederherstellung, also Juli. Die wäre mir wichtig zu beheben, da ich keine Backups mehr machen kann.
