  4. iCal Adapter Fehler: Error: Unknown RRULE property 'RRULE'
    6.7k
icalrruleerror
7 Beiträge 2 Kommentatoren 930 Aufrufe 2 Beobachtet
    pxstd
    schrieb am zuletzt editiert von pxstd
    ich habe eben den iCal Adapter Version 1.7.4 installiert.
    Nach dem Versuch der Einrichtung meines Nextcloud Kalenders erhalte ich im Log:
    ical.0	2020-11-04 13:15:36.345	info	(84855) Terminated (NO_ERROR): Without reason
    ical.0	2020-11-04 13:15:36.344	info	(84855) terminating
    ical.0	2020-11-04 13:15:36.326	error	at Object.parseLines (/opt/iobroker/node_modules/node-ical/ical.js:499:18)
    ical.0	2020-11-04 13:15:36.326	error	at Object.handleObject (/opt/iobroker/node_modules/node-ical/ical.js:452:39)
    ical.0	2020-11-04 13:15:36.326	error	at Object.END (/opt/iobroker/node_modules/node-ical/ical.js:415:30)
    ical.0	2020-11-04 13:15:36.326	error	at Function.RRule.fromString (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/rrule.ts:127:28)
    ical.0	2020-11-04 13:15:36.326	error	at Function.parseString (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:7:41)
    ical.0	2020-11-04 13:15:36.326	error	at Array.map (<anonymous>)
    ical.0	2020-11-04 13:15:36.326	error	at parseLine (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:42:14)
    ical.0	2020-11-04 13:15:36.326	error	at parseRrule (/opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:56:9)
    ical.0	2020-11-04 13:15:36.326	error	at Array.forEach (<anonymous>)
    ical.0	2020-11-04 13:15:36.326	error	at /opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:98:15
    ical.0	2020-11-04 13:15:36.326	error	(84855) Error: Unknown RRULE property 'RRULE'
    ical.0	2020-11-04 13:15:36.326	error	(84855) uncaught exception: Unknown RRULE property 'RRULE'
    Schema der Eintragung:
    URL: https://<domain>/nextcloud/remote.php/dav/calendars/<user>/<kalender>/?export
    Benutzer: <user>
    SSL Fehler ignorieren
    Ideen?
    • P pxstd
      Benutzer: <user>
      Ideen?
      @pxstd
      Node-Version?
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      P 1 Antwort Letzte Antwort
        @pxstd
        Node-Version?
        pxstd
        @Thomas-Braun
        Mhhh
        strange. Nodejs ist installiert, aber scheinbar nicht korrekt verlinkt.
        #:~# dpkg -l |grep nodejs
        ii  nodejs                               10.23.0-deb-1nodesource1          amd64        Node.js event-based server-side javascript engine
        #:~# which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/node
        v10.23.0
        /usr/bin/npm
        6.14.8
        nodejs:
          Installiert:           10.23.0-deb-1nodesource1
          Installationskandidat: 10.23.0-deb-1nodesource1
          Versionstabelle:
         *** 10.23.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x focal/main amd64 Packages
                100 /var/lib/dpkg/status
             10.19.0~dfsg-3ubuntu1 500
                500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        • P pxstd
          @Thomas-Braun
          Mhhh
          /usr/bin/node
          v10.23.0
          /usr/bin/npm
          6.14.8
          nodejs:
            Versionstabelle:
          @pxstd
          Richtig, bei ubuntu sollte man die linken.
          Wie das geht steht hier:
          Ich würde auch gleich mal auf node12 gehen.
            @pxstd
            pxstd
            @Thomas-Braun
            Update Erledigt, leider...
            # which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.19.0
            /usr/bin/node
            v12.19.0
            /usr/bin/npm
            6.14.8
            nodejs:
              Installiert:           12.19.0-deb-1nodesource1
              Installationskandidat: 12.19.0-deb-1nodesource1
              Versionstabelle:
             *** 12.19.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x focal/main amd64 Packages
            ... bleibt der Fehler bestehen :/
            ical.0	2020-11-04 13:41:30.229	info	(1779) Terminated (NO_ERROR): Without reason
            ical.0	2020-11-04 13:41:30.228	info	(1779) terminating
            ical.0	2020-11-04 13:41:30.212	error	(1779) Error: Unknown RRULE property 'RRULE' at /opt/iobroker/node_modules/rrule/dist/es5/webpack:/rrule/src/parsestring.ts:98:15 at Array.forEach (<anonymous>) at parseRrule (/opt/iobroke
            ical.0	2020-11-04 13:41:30.211	error	(1779) uncaught exception: Unknown RRULE property 'RRULE'
            ical.0	2020-11-04 13:41:28.259	info	(1779) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.0, js-controller: 3.1.6
            • P pxstd
              @Thomas-Braun
              /usr/bin/nodejs
              v12.19.0
              /usr/bin/node
              v12.19.0
              /usr/bin/npm
              6.14.8
              nodejs:
                Versionstabelle:
              pxstd
              Anyone? :/
              • P pxstd
                Anyone? :/
                @pxstd
                Die Fehlermeldung ist nicht komplett, da fehlt in der dritten Zeile der Rest.
                Ich glaube, das sollte sich einer der devs mal anschaun. Mach ein Issue auf:
                https://github.com/iobroker-community-adapters/ioBroker.ical/issues
