  4. bri, is not modifiable ?
    6.7k
britrådfriikea
7 Beiträge 3 Kommentatoren 990 Aufrufe 3 Beobachtet
    Michaelnorge
    Mein Log ist voll mit solchen Einträgen:
    deconz.0	2020-10-14 17:01:17.896	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 17:01:17.891	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:47:14.208	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:47:14.200	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:37:31.339	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:37:31.337	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:36:07.789	warn	(1622) {"address":"/lights/32/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:36:07.788	warn	(1622) {"address":"/lights/35/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:36:07.751	warn	(1622) {"address":"/lights/34/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:36:07.749	warn	(1622) {"address":"/lights/33/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:36:07.746	warn	(1622) {"address":"/lights/31/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:18:30.821	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    deconz.0	2020-10-14 16:18:30.817	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
    Ich hatte dazu auch schon mal was im Forum gefunden (wo genau weiss ich nicht mehr) aber kann es nicht mehr wieder finden.
    Es handelt sich um Trådfri-Lampen von IKEA.
    Allerdings ändere ich den Wert "bri" überhaupt nicht, sondern nur "level" und (falls verfügbar) den "ct"-Wert.
    Kann man diese Warnings irgendwie abstellen?
    Grüße
    Michael
    • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
    • M Michaelnorge
      Grüße
      Michael
      Jey CeeJ Offline
      Jey CeeJ Offline
      Jey Cee
      @Michaelnorge setzt bri (level ist das gleiche nur in %) bevor du deine Lampe eingeschalten hast.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • Jey CeeJ Jey Cee
        Michaelnorge
        @Jey-Cee Okay, aber abschaltbar ist das zur Zeit nicht, oder?
        • M Michaelnorge
          Jey CeeJ Offline
          Jey CeeJ Offline
          Jey Cee
          @Michaelnorge nein warum auch, das ist eine Fehlermeldung von deConz. Bri setzen bevor Lampe an ist hat keinen Wert weil es nicht übernommen wird.
          M AlCalzoneA 2 Antworten Letzte Antwort
          • Jey CeeJ Jey Cee
            Michaelnorge
            @Jey-Cee Ok, danke Dir!
            • Jey CeeJ Jey Cee
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @Jey-Cee Interessanterweise sorgt eine Änderung der Helligkeit bei Nutzung des Gateways (also per tradfri-Adapter) dafür, dass die Lampe an (>0) bzw. aus (=0) geschaltet wird. Macht IMO auch Sinn.
              • AlCalzoneA AlCalzone
                Jey CeeJ Offline
                Jey CeeJ Offline
                Jey Cee
                @AlCalzone jetzt wo du es sagst, das sollte beim deConz Adapter auch so sein. Hatte ich extra eingebaut weil deConz das nicht macht. Da muss ich mal danach schauen.
