  4. Node-Red
  5. Garagentor offen Warnung
    6.5k
3 Beiträge 2 Kommentatoren 811 Aufrufe 2 Beobachtet
    Macallan
    ich steuere über Node-Red und HomeKit mit einem Shelly1 mein Garagentor. Nun möchte ich gerne eine Warnung implementieren wenn das Tor über einen längeren Zeitraum offen ist. Die Info zum Status habe ich im mqtt.0 - aber noch nicht wirklich viel Plan wie ich das in Node-Red implementieren könnte. Über ein paar Tipps wäre ich dankbar.
    • M Macallan
      Stefan3107
      schrieb am zuletzt editiert von Stefan3107
      Hallo, ich mach das über Pushover mit meiner Kühlschrank bzw. Tiefkühlertemperatur so.
      [{"id":"a503cee2.c476","type":"tab","label":"Pushover","disabled":false,"info":""},{"id":"e33e0d5f.f5755","type":"link in","z":"a503cee2.c476","name":"Temp_TK","links":["55824d78.468444"],"x":75,"y":280,"wires":[["9ba77b8b.f8cff8"]]},{"id":"30fc2573.19829a","type":"link in","z":"a503cee2.c476","name":"Temp_KS","links":["6ae753b9.4baa8c"],"x":75,"y":360,"wires":[["8e23ca17.403138"]]},{"id":"4fd8da2c.372ae4","type":"trigger","z":"a503cee2.c476","op1":"0","op2":"1","op1type":"str","op2type":"str","duration":"45","extend":false,"units":"min","reset":"0","bytopic":"all","name":"","x":400,"y":280,"wires":[["1ee3d99a.7dd3f6"]]},{"id":"fb291308.207e9","type":"comment","z":"a503cee2.c476","name":"Kühlgeräte Überwachung","info":"Wenn Tiefkühler länger als 45 min über -12° liegt, \nwird über Auslöser ein push Alarm ausgelöst.\nEbenso wenn Kühlschrank über 10° liegt.","x":600,"y":140,"wires":[]},{"id":"9d013a54.445128","type":"trigger","z":"a503cee2.c476","op1":"0","op2":"1","op1type":"str","op2type":"str","duration":"20","extend":false,"units":"min","reset":"0","bytopic":"all","name":"","x":400,"y":360,"wires":[["1ee3d99a.7dd3f6"]]},{"id":"92a35de9.83eba","type":"pushover","z":"a503cee2.c476","name":"Türe offen","device":"xxx","title":"Haus xxxx","priority":"1","sound":"siren","url":"","url_title":"xxxxxxxxxxxxxxxxxxxxx","html":false,"x":1210,"y":320,"wires":[]},{"id":"1ee3d99a.7dd3f6","type":"switch","z":"a503cee2.c476","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":320,"wires":[["408eb69f.191ee8"]]},{"id":"9ba77b8b.f8cff8","type":"function","z":"a503cee2.c476","name":"Temp > -12°","func":"if (msg.payload >-12){\n var Temp = 1;\n msg.payload = Temp;\n}\n\nelse {\n msg.payload = 0; \n}\n\nreturn msg;","outputs":1,"noerr":0,"x":210,"y":280,"wires":[["4fd8da2c.372ae4"]]},{"id":"8e23ca17.403138","type":"function","z":"a503cee2.c476","name":"Temp > 10°","func":"if (msg.payload >10){\n var Temp = 1;\n msg.payload = Temp;\n}\n\nelse {\n msg.payload = 0; \n}\n\nreturn msg;","outputs":1,"noerr":0,"x":210,"y":360,"wires":[["9d013a54.445128"]]},{"id":"5c94c21.962563c","type":"change","z":"a503cee2.c476","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Kühlschrank Türe offen","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":320,"wires":[["92a35de9.83eba"]]},{"id":"408eb69f.191ee8","type":"msg-resend","z":"a503cee2.c476","interval":"3","intervalUnit":"secs","maximum":"3","bytopic":false,"clone":false,"firstDelayed":false,"addCounters":false,"highRate":false,"outputCountField":"","outputMaxField":"","name":"3 Impulse / 3sec","x":760,"y":320,"wires":[["5c94c21.962563c"]]}]
      • S Stefan3107
        Macallan
        @Stefan3107 Ah das hilft mir die Methodik besser zu verstehen. Vielen Dank.
