  4. Installation jeglicher Adapter failed
    6.8k
iobroker absturz
6 Beiträge 4 Kommentatoren 650 Aufrufe 3 Beobachtet
    PierrePetite
    schrieb am zuletzt editiert von PierrePetite
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3B+
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte
    Betriebssystem: RaspiOS
    Hey, seit 3 Tagen stürzt der Pi bei der Installation von jedem Adapter ab. Vorhin versucht de Landroid-Adapter zu installieren:
    $ ./iobroker add worx  --host raspberrypi
    NPM version: 6.14.6npm install iobroker.worx@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/linux/BluetoothSerialPort.cc: At global scope:../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void void InitAll(Handle<Object> exports) {              ^~~~~~../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
    ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’ void InitAll(Handle<Object> exports) {              ^~~~~~              rand_r../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token void InitAll(Handle<Object> exports) {                           ^../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope void InitAll(Handle<Object> exports) {                             ^~~~~~~In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope NODE_MODULE(BluetoothSerialPort, InitAll)                                  ^~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
    make: *** [BluetoothSerialPort.target.mk:115: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
    gyp
    ERR! build error
    gyp
     ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp
     ERR! System Linux 4.19.118-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    Jemand eine Idee?
    da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
    • P PierrePetite
      gyp
      ERR! build error
      gyp
      gyp
      Jemand eine Idee?
      da_WoodyD Offline
      da_WoodyD Offline
      da_Woody
      @PierrePetite nuja, ubuntu, wahrscheinlich level 5, 1GB ram, bisschen wenig platz.
      gruß vom Woody
      • P PierrePetite
        gyp
        ERR! build error
        gyp
        gyp
        Jemand eine Idee?
        @PierrePetite sagte in Installation jeglicher Adapter failed:
        /usr/local/bin/node
        NodeJS falsch installiert.
        Schau hier wie man das wieder gerade fummelt:
        Den Pi könntest du auch mal aktualisieren, RaspberryOS (ich vermute Ubuntu ist eine Falschangabe) läuft mittlerweile mit einem Kernel 5.4.
          PierrePetite
          Ja, Ubuntu war tatsächlich eine Falschangabe. Es ist RaspiOS.
          Problem ist behoben.
          sudo apt update
          sudo apt upgrade
          Hat es gelöst. Danke euch! Hoffentlich ist es nun auch vorbei, dass der Gute jeden zweiten Tag abstürzt und rebootet werden muss.
          Danke!
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
          • P PierrePetite
            sudo apt update
            sudo apt upgrade
            Danke!
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            sudo apt update
            sudo apt upgrade
            Hat es gelöst.
            aber nicht deine Falschinstallation in :
            /usr/local/............
            • P PierrePetite
              sudo apt update
              sudo apt upgrade
              Danke!
              @PierrePetite Das ist aber nur die halbe Miete.
              who -r
              sagt? Und wie gesagt muss die node-Installation auch korrigiert werden.
