  4. Fehler: host.raspberrypi Cannot install iobroker.i2
    6.6k
i2cadapter
81 Beiträge 5 Kommentatoren 6.3k Aufrufe 4 Beobachtet
    @homoran Bin neu hier. hoffe ihr könnt mir helfen. Easee Wallbox AP
    Habe 2 Rasperrypi1 Slave und Rasperrypi2 Master
    	install easee
    $ ./iobroker install easee
    NPM version: 6.14.11
    npm install iobroker.easee@0.1.2 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.easee@0.1.2.
    npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-03-27T15_33_21_982Z-debug.log
    ERROR: host.raspberrypi2 Cannot install iobroker.easee@0.1.2: 1
    "knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit": Connection is closed.
    2021-03-27 16:13:10.689 - warn: knx.0 (1835) Could not check object existence of state knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit: Cannot check object existence of "knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit": Connection is closed.
    2021-03-27 16:13:10.690 - warn: knx.0 (1835) Could not check object existence of state knx.0.Zentral_und_Sicherheit.Wetterstation.Temperatur_Außen: Cannot check object existence of "knx.0.Zentral_und_Sicherheit.Wetterstation.Temperatur_Außen": Connection is closed.
    2021-03-27 16:13:10.691 - warn: knx.0 (1835) get state error: Connection is closed.
    2021-03-27 16:13:10.692 - warn: knx.0 (1835) get state error: Connection is closed.
    2021-03-27 16:13:13.361 - error: admin.0 (1385) Cannot check object existence of "admin.0.connected": Connection is closed.
    2021-03-27 16:13:13.363 - warn: admin.0 (1385) Could not check object existence of state admin.0.connected: Cannot check object existence of "admin.0.connected": Connection is closed.
    2021-03-27 16:13:13.365 - warn: admin.0 (1385) get state error: Connection is closed.
    2021-03-27 16:13:15.161 - error: knx.0 (1835) Cannot check object existence of "knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit": Connection is closed.
    2021-03-27 16:13:15.162 - warn: knx.0 (1835) Could not check object existence of state knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit: Cannot check object existence of "knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit": Connection is closed.
    2021-03-27 16:13:15.162 - warn: knx.0 (1835) get state error: Connection is closed.
    2021-03-27 16:13:20.498 - info: host.raspberrypi2 stopInstance system.adapter.admin.0 send kill signal
    2021-03-27 16:13:21.169 - error: knx.0 (1835) Cannot check object existence of "knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit": Connection is closed.
    2021-03-27 16:13:21.170 - warn: knx.0 (1835) Could not check object existence of state knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit: Cannot check object existence of "knx.0.Zentral_und_Sicherheit.Wetterstation.Windgeschwindigkeit": Connection is closed.
    2021-03-27 16:13:21.171 - warn: knx.0 (1835) get state error: Connection is closed.
    2021-03-27 16:13:20.505 - info: host.raspberrypi2 stopInstance system.adapter.discovery.0 send kill signal
    2021-03-27 16:13:20.506 - info: host.raspberrypi2 stopInstance system.adapter.info.0 send kill signal
    2021-03-27 16:13:20.507 - info: host.raspberrypi2 stopInstance system.adapter.web.0 send kill signal
    2021-03-27 16:13:20.507 - info: host.raspberrypi2 stopInstance system.adapter.knx.0 send kill signal
    2021-03-27 16:13:20.508 - info: host.raspberrypi2 stopInstance system.adapter.pushover.1 send kill signal
    2021-03-27 16:13:20.946 - error: host.raspberrypi2 Cannot find view "system" for search "adapter" : Connection is closed.
    2021-03-27 16:13:21.234 - warn: host.raspberrypi2 too delayed answer for raspberrypi1
    2021-03-27 16:13:23.368 - error: host.raspberrypi2 Cannot find view "system" for search "instance" : Connection is closed.
    2021-03-27 16:13:23.370 - info: host.raspberrypi2 stopInstance system.adapter.admin.0 killing pid 1385
    2021-03-27 16:13:23.371 - info: host.raspberrypi2 stopInstance system.adapter.discovery.0 killing pid 2766
    2021-03-27 16:13:23.372 - info: host.raspberrypi2 stopInstance system.adapter.info.0 killing pid 1415
    2021-03-27 16:13:23.373 - info: host.raspberrypi2 stopInstance system.adapter.web.0 killing pid 1434
    2021-03-27 16:13:23.375 - info: host.raspberrypi2 stopInstance system.adapter.knx.0 killing pid 1835
    2021-03-27 16:13:23.376 - info: host.raspberrypi2 stopInstance system.adapter.pushover.1 killing pid 1877
    2021-03-27 16:13:23.826 - info: host.raspberrypi2 instance system.adapter.influxdb.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-27 16:13:23.827 - info: host.raspberrypi2 All instances are stopped.
    2021-03-27 16:13:25.926 - error: host.raspberrypi2 Cannot find view "system" for search "instance" : Connection is closed.
    2021-03-27 16:13:25.927 - error: host.raspberrypi2 Cannot find view "system" for search "instance" : Connection is closed.
    2021-03-27 16:13:25.928 - error: host.raspberrypi2 Cannot find view "system" for search "instance" : Connection is closed.
    2021-03-27 16:13:25.929 - error: host.raspberrypi2 Cannot find view "system" for search "instance" : Connection is closed.
    2021-03-27 16:13:25.930 - error: host.raspberrypi2 Cannot find view "system" for search "instance" : Connection is closed.
    2021-03-27 16:13:26.252 - warn: host.raspberrypi2 instance system.adapter.admin.0 terminated due to SIGTERM
    2021-03-27 16:13:26.253 - info: host.raspberrypi2 instance system.adapter.admin.0 terminated with code null ()
    2021-03-27 16:13:26.254 - info: host.raspberrypi2 All instances are stopped.
    2021-03-27 16:13:26.255 - warn: host.raspberrypi2 instance system.adapter.info.0 terminated due to SIGTERM
    2021-03-27 16:13:26.255 - info: host.raspberrypi2 instance system.adapter.info.0 terminated with code null ()
    2021-03-27 16:13:26.256 - info: host.raspberrypi2 All instances are stopped.
    2021-03-27 16:13:26.256 - info: host.raspberrypi2 instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-03-27 16:13:26.257 - info: host.raspberrypi2 instance system.adapter.knx.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-03-27 16:13:26.257 - info: host.raspberrypi2 All instances are stopped.
    2021-03-27 16:13:26.258 - info: host.raspberrypi2 instance system.adapter.pushover.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-03-27 16:13:26.258 - info: host.raspberrypi2 All instances are stopped.
    2021-03-27 16:13:26.259 - warn: host.raspberrypi2 instance system.adapter.discovery.0 terminated due to SIGTERM
    2021-03-27 16:13:26.259 - info: host.raspberrypi2 instance system.adapter.discovery.0 terminated with code null ()
    2021-03-27 16:13:26.260 - info: host.raspberrypi2 All instances are stopped.
    2021-03-27 16:13:35.347 - info: host.raspberrypi2 force terminating
    2021-03-27 16:14:00.342 - info: host.raspberrypi2 iobroker.js-controller version 3.2.16 js-controller starting
    2021-03-27 16:14:00.350 - info: host.raspberrypi2 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-03-27 16:14:00.351 - info: host.raspberrypi2 hostname: raspberrypi2, node: v12.21.0
    2021-03-27 16:14:00.352 - info: host.raspberrypi2 ip addresses: 192.168.178.44 2003:c1:6f42:7a00:c57f:3c9a:f359:c01f fe80::c2f4:bc84:aab1:f5dd
    2021-03-27 16:14:01.109 - info: host.raspberrypi2 connected to Objects and States
    2021-03-27 16:14:01.167 - info: host.raspberrypi2 added notifications configuration of host
    2021-03-27 16:14:02.034 - info: host.raspberrypi2 15 instances found
    2021-03-27 16:14:02.109 - info: host.raspberrypi2 starting 9 instances
    2021-03-27 16:14:02.262 - info: host.raspberrypi2 instance system.adapter.admin.0 started with pid 660
    2021-03-27 16:14:11.351 - warn: admin.0 (660) slow connection to objects DB. Still waiting ...
    2021-03-27 16:14:13.805 - warn: admin.0 (660) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:26.553 - info: host.raspberrypi2 instance system.adapter.discovery.0 started with pid 671
    2021-03-27 16:14:28.191 - info: host.raspberrypi2 instance system.adapter.info.0 started with pid 678
    2021-03-27 16:14:35.039 - info: host.raspberrypi2 instance system.adapter.web.0 started with pid 704
    2021-03-27 16:14:36.022 - warn: discovery.0 (671) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:39.744 - info: host.raspberrypi2 instance system.adapter.knx.0 started with pid 715
    2021-03-27 16:14:39.924 - warn: info.0 (678) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:42.946 - info: host.raspberrypi2 instance scheduled system.adapter.dwd.0 */5 * * * *
    2021-03-27 16:14:42.969 - info: host.raspberrypi2 instance system.adapter.dwd.0 started with pid 737
    2021-03-27 16:14:43.397 - warn: web.0 (704) slow connection to objects DB. Still waiting ...
    2021-03-27 16:14:45.686 - error: discovery.0 (671) discovery.0 already running
    2021-03-27 16:14:45.690 - warn: discovery.0 (671) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-03-27 16:14:46.032 - warn: web.0 (704) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:48.302 - warn: knx.0 (715) slow connection to objects DB. Still waiting ...
    2021-03-27 16:14:48.771 - warn: vis.0 (722) slow connection to objects DB. Still waiting ...
    2021-03-27 16:14:49.970 - error: info.0 (678) info.0 already running
    2021-03-27 16:14:49.974 - warn: info.0 (678) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-03-27 16:14:51.224 - warn: vis.0 (722) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:51.585 - warn: dwd.0 (737) slow connection to objects DB. Still waiting ...
    2021-03-27 16:14:52.804 - warn: knx.0 (715) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:53.943 - info: host.raspberrypi2 instance system.adapter.influxdb.0 started with pid 748
    2021-03-27 16:14:56.100 - warn: dwd.0 (737) slow connection to states DB. Still waiting ...
    2021-03-27 16:14:56.606 - error: web.0 (704) web.0 already running
    2021-03-27 16:14:56.610 - warn: web.0 (704) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-03-27 16:14:58.088 - info: host.raspberrypi2 instance system.adapter.pushover.1 started with pid 759
    2021-03-27 16:15:00.260 - warn: host.raspberrypi2 instance system.adapter.dwd.0 already running with pid 737
    2021-03-27 16:15:01.938 - error: host.raspberrypi2 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-03-27 16:15:01.940 - info: host.raspberrypi2 Restart adapter system.adapter.discovery.0 because enabled
    2021-03-27 16:15:02.680 - warn: influxdb.0 (748) slow connection to objects DB. Still waiting ...
    2021-03-27 16:15:04.500 - error: knx.0 (715) knx.0 already running
    2021-03-27 16:15:04.503 - warn: knx.0 (715) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-03-27 16:15:06.092 - warn: pushover.1 (759) slow connection to objects DB. Still waiting ...
    2021-03-27 16:15:06.532 - warn: influxdb.0 (748) slow connection to states DB. Still waiting ...
    2021-03-27 16:15:06.981 - error: host.raspberrypi2 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-03-27 16:15:06.990 - info: host.raspberrypi2 Restart adapter system.adapter.info.0 because enabled
    2021-03-27 16:15:09.233 - warn: pushover.1 (759) slow connection to states DB. Still waiting ...
    2021-03-27 16:15:14.265 - error: host.raspberrypi2 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-03-27 16:15:14.273 - info: host.raspberrypi2 Restart adapter system.adapter.web.0 because enabled
    2021-03-27 16:15:18.950 - error: influxdb.0 (748) influxdb.0 already running
    2021-03-27 16:15:18.954 - warn: influxdb.0 (748) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-03-27 16:15:21.865 - error: pushover.1 (759) pushover.1 already running
    2021-03-27 16:15:21.870 - warn: pushover.1 (759) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-03-27 16:15:22.717 - error: host.raspberrypi2 instance system.adapter.knx.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-03-27 16:15:22.726 - info: host.raspberrypi2 Restart adapter system.adapter.knx.0 because enabled
    2021-03-27 16:15:39.202 - error: host.raspberrypi2 instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-03-27 16:15:39.209 - info: host.raspberrypi2 Restart adapter system.adapter.influxdb.0 because enabled
    2021-03-27 16:15:42.644 - info: host.raspberrypi2 instance system.adapter.discovery.0 started with pid 770
    2021-03-27 16:15:42.646 - error: host.raspberrypi2 instance system.adapter.pushover.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-03-27 16:15:42.648 - info: host.raspberrypi2 Restart adapter system.adapter.pushover.1 because enabled
    2021-03-27 16:15:47.634 - info: host.raspberrypi2 instance system.adapter.info.0 started with pid 781
    2021-03-27 16:15:49.114 - info: vis.0 (722) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:15:50.800 - warn: discovery.0 (770) slow connection to objects DB. Still waiting ...
    2021-03-27 16:15:51.977 - info: vis.0 (722) vis license is OK.
    2021-03-27 16:15:56.725 - info: host.raspberrypi2 instance system.adapter.web.0 started with pid 804
    2021-03-27 16:15:57.243 - warn: info.0 (781) slow connection to objects DB. Still waiting ...
    2021-03-27 16:15:57.654 - warn: discovery.0 (770) slow connection to states DB. Still waiting ...
    2021-03-27 16:16:04.042 - warn: info.0 (781) slow connection to states DB. Still waiting ...
    2021-03-27 16:16:04.499 - info: host.raspberrypi2 instance system.adapter.knx.0 started with pid 815
    2021-03-27 16:16:05.045 - warn: web.0 (804) slow connection to objects DB. Still waiting ...
    2021-03-27 16:16:12.432 - warn: web.0 (804) slow connection to states DB. Still waiting ...
    2021-03-27 16:16:12.944 - warn: knx.0 (815) slow connection to objects DB. Still waiting ...
    2021-03-27 16:16:20.179 - info: vis.0 (722) Terminated (NO_ERROR): Without reason
    2021-03-27 16:16:22.533 - info: host.raspberrypi2 instance system.adapter.influxdb.0 started with pid 826
    2021-03-27 16:16:23.300 - warn: knx.0 (815) slow connection to states DB. Still waiting ...
    2021-03-27 16:16:25.691 - info: host.raspberrypi2 instance system.adapter.pushover.1 started with pid 837
    2021-03-27 16:16:31.225 - warn: influxdb.0 (826) slow connection to objects DB. Still waiting ...
    2021-03-27 16:16:31.855 - info: host.raspberrypi2 instance system.adapter.vis.0 terminated while should be started once
    2021-03-27 16:16:32.525 - info: knx.0 (815) starting. Version 1.0.39 in /opt/iobroker/node_modules/iobroker.knx, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:32.638 - warn: knx.0 (815) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
    2021-03-27 16:16:32.894 - info: admin.0 (660) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:33.113 - info: admin.0 (660) requesting all states
    2021-03-27 16:16:33.115 - info: admin.0 (660) requesting all objects
    2021-03-27 16:16:33.431 - info: knx.0 (815) knx license is OK.
    2021-03-27 16:16:33.436 - info: knx.0 (815) Connecting to knx GW: 192.168.178.23:3671 with phy. Adr: 1.1.0
    2021-03-27 16:16:34.185 - info: dwd.0 (737) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:34.202 - info: discovery.0 (770) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:34.217 - info: influxdb.0 (826) starting. Version 1.9.4 in /opt/iobroker/node_modules/iobroker.influxdb, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:34.217 - info: web.0 (804) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:34.446 - info: pushover.1 (837) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.pushover, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:34.498 - info: admin.0 (660) received all objects
    2021-03-27 16:16:34.354 - info: influxdb.0 (826) No stored data from last exit found
    2021-03-27 16:16:34.368 - info: influxdb.0 (826) Connecting http://192.168.178.44:8086 ...
    2021-03-27 16:16:34.670 - info: influxdb.0 (826) Connected!
    2021-03-27 16:16:34.729 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.EG.RTR-Küce_Ist-Temp_, Alias=false, 1 points now activated
    2021-03-27 16:16:34.734 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.EG.RTR_G-Bad_Ist-Temp_, Alias=false, 2 points now activated
    2021-03-27 16:16:34.737 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.EG.RTR-Zoé_Ist-Temp_, Alias=false, 3 points now activated
    2021-03-27 16:16:34.744 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.EG.RTR-Flur_Status_Akt___Sollwert, Alias=false, 4 points now activated
    2021-03-27 16:16:34.752 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.EG.RTR-WZ_Ist-Temp_, Alias=false, 5 points now activated
    2021-03-27 16:16:34.757 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.OG.RTR-Bad_Ist-Temp_, Alias=false, 6 points now activated
    2021-03-27 16:16:34.761 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.OG.RTR-Bad_Status_Akt___Sollwert, Alias=false, 7 points now activated
    2021-03-27 16:16:34.765 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.OG.RTR-Schlaf_Ist-Temp_, Alias=false, 8 points now activated
    2021-03-27 16:16:34.767 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.OG.RTR-Flur_Ist-Temp_, Alias=false, 9 points now activated
    2021-03-27 16:16:34.771 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.OG.RTR-Jayson_WZ_Ist-Temp_, Alias=false, 10 points now activated
    2021-03-27 16:16:34.775 - info: influxdb.0 (826) enabled logging of knx.0.Heizung_Klima_Wasser.OG.RTR-Jayson_SZ_Ist-Temp_, Alias=false, 11 points now activated
    2021-03-27 16:16:34.777 - info: influxdb.0 (826) enabled logging of smartmeter.0.1-0:1_8_1__255.value, Alias=false, 12 points now activated
    2021-03-27 16:16:34.780 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:1_8_0__255.value, Alias=false, 13 points now activated
    2021-03-27 16:16:34.787 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:1_8_1__255.value, Alias=false, 14 points now activated
    2021-03-27 16:16:34.793 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:1_8_2__255.value, Alias=false, 15 points now activated
    2021-03-27 16:16:34.800 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:16_7_0__255.value, Alias=false, 16 points now activated
    2021-03-27 16:16:34.806 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:36_7_0__255.value, Alias=false, 17 points now activated
    2021-03-27 16:16:34.808 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:56_7_0__255.value, Alias=false, 18 points now activated
    2021-03-27 16:16:34.810 - info: influxdb.0 (826) enabled logging of smartmeter.1.1-0:76_7_0__255.value, Alias=false, 19 points now activated
    2021-03-27 16:16:35.034 - info: admin.0 (660) http server listening on port 8081
    2021-03-27 16:16:35.231 - info: web.0 (804) socket.io server listening on port 8082
    2021-03-27 16:16:35.243 - info: web.0 (804) http server listening on port 8082
    2021-03-27 16:16:35.036 - info: admin.0 (660) Use link "http://localhost:8081" to configure.
    2021-03-27 16:16:36.493 - info: info.0 (781) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:16:36.596 - info: dwd.0 (737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-27 16:16:37.274 - info: host.raspberrypi2 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-27 16:18:09.529 - info: host.raspberrypi2 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2021-03-27 16:18:15.453 - info: host.raspberrypi2 iobroker install easee
    2021-03-27 16:18:19.553 - info: host.raspberrypi2 iobroker NPM version: 6.14.11
    2021-03-27 16:18:19.578 - info: host.raspberrypi2 iobroker npm install iobroker.easee@0.1.2 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-03-27 16:18:31.224 - info: host.raspberrypi2 iobroker npm ERR! code ETARGETnpm ERR! notarget No matching version found for iobroker.easee@0.1.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-03-27T15_18_31_205Z-debug.log
    2021-03-27 16:18:31.487 - error: host.raspberrypi2 iobroker host.raspberrypi2 Cannot install iobroker.easee@0.1.2: 1
    2021-03-27 16:18:32.067 - info: host.raspberrypi2 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2021-03-27 16:18:33.000 - info: host.raspberrypi2 iobroker exit 25
    2021-03-27 16:20:00.143 - info: host.raspberrypi2 instance system.adapter.dwd.0 started with pid 1360
    2021-03-27 16:20:02.994 - info: dwd.0 (1360) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:20:14.301 - info: dwd.0 (1360) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-27 16:20:14.847 - info: host.raspberrypi2 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-27 16:22:29.060 - info: host.raspberrypi2 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2021-03-27 16:22:33.716 - info: host.raspberrypi2 iobroker install easee
    2021-03-27 16:22:37.608 - info: host.raspberrypi2 iobroker NPM version: 6.14.11
    2021-03-27 16:22:37.611 - info: host.raspberrypi2 iobroker npm install iobroker.easee@0.1.2 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-03-27 16:22:45.978 - info: host.raspberrypi2 iobroker npm ERR! code ETARGET
    2021-03-27 16:22:46.013 - info: host.raspberrypi2 iobroker npm ERR! notarget No matching version found for iobroker.easee@0.1.2.
    2021-03-27 16:22:46.020 - info: host.raspberrypi2 iobroker npm ERR! notarget In most cases you or one of your dependencies are requesting
    2021-03-27 16:22:46.025 - info: host.raspberrypi2 iobroker npm ERR! notarget a package version that doesn't exist.
    2021-03-27 16:22:46.048 - info: host.raspberrypi2 iobroker
    2021-03-27 16:22:46.051 - info: host.raspberrypi2 iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-03-27T15_22_46_032Z-debug.log
    2021-03-27 16:22:46.076 - error: host.raspberrypi2 iobroker host.raspberrypi2 Cannot install iobroker.easee@0.1.2: 1
    2021-03-27 16:22:47.145 - info: host.raspberrypi2 iobroker exit 25
    2021-03-27 16:25:00.123 - info: host.raspberrypi2 instance system.adapter.dwd.0 started with pid 1406
    2021-03-27 16:25:02.992 - info: dwd.0 (1406) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:25:13.280 - info: dwd.0 (1406) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-27 16:25:13.825 - info: host.raspberrypi2 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-27 16:30:00.105 - info: host.raspberrypi2 instance system.adapter.dwd.0 started with pid 1454
    2021-03-27 16:30:02.964 - info: dwd.0 (1454) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.21.0, js-controller: 3.2.16
    2021-03-27 16:30:14.763 - info: dwd.0 (1454) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-27 16:30:15.303 - info: host.raspberrypi2 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-27 16:32:21.822 - info: host.raspberrypi2 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2021-03-27 16:33:09.700 - info: host.raspberrypi2 iobroker install easee
    2021-03-27 16:33:13.578 - info: host.raspberrypi2 iobroker NPM version: 6.14.11
    2021-03-27 16:33:13.581 - info: host.raspberrypi2 iobroker npm install iobroker.easee@0.1.2 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-03-27 16:33:21.940 - info: host.raspberrypi2 iobroker npm ERR! code ETARGET
    2021-03-27 16:33:21.972 - info: host.raspberrypi2 iobroker npm ERR! notarget No matching version found for iobroker.easee@0.1.2.
    2021-03-27 16:33:21.974 - info: host.raspberrypi2 iobroker npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    2021-03-27 16:33:21.994 - info: host.raspberrypi2 iobroker
    2021-03-27 16:33:21.997 - info: host.raspberrypi2 iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-03-27T15_33_21_982Z-debug.log
    2021-03-27 16:33:22.025 - error: host.raspberrypi2 iobroker host.raspberrypi2 Cannot install iobroker.easee@0.1.2: 1
    2021-03-27 16:33:23.079 - info: host.raspberrypi2 iobroker exit 25
    #81
    @marcel-drzal sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
    warum hier noch einmal?
    Hast du doch schon woanders gepostet
