  4. [gelöst] Telegram produziert Fehler
    6.8k
telegrameconnrefusedfritzboxfritzos 7.20
24 Beiträge 5 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • RöstkartoffelR Offline
    Röstkartoffel
    schrieb am zuletzt editiert von Röstkartoffel
    Ich habe auf meiner Fritzbox die 07.12, die 07.20 wird noch nicht angeboten und trotzdem erhalte ich seit zwei Tagen immer zur gleichen Uhrzeit folgende Fehlermeldung im Log:
    2020-08-28 03:35:08.297 - warn: telegram.0 (30221) polling_error:EFATAL, EFATAL: Error: read ECONNRESET
    2020-08-28 03:35:08.326 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-08-28 03:35:08.327 - error: telegram.0 (30221) unhandled promise rejection: EFATAL: Error: read ECONNRESET
    2020-08-28 03:35:08.327 - error: telegram.0 (30221) RequestError: Error: read ECONNRESET
    at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
    at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
    at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (events.js:198:13)
    at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
    at ClientRequest.emit (events.js:198:13)
    at TLSSocket.socketErrorListener (_http_client.js:401:9)
    at TLSSocket.emit (events.js:198:13)
    at emitErrorNT (internal/streams/destroy.js:91:8)
    at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
    at process._tickCallback (internal/process/next_tick.js:63:19)
    2020-08-28 03:35:08.830 - info: telegram.0 (30221) terminating
    2020-08-28 03:35:08.831 - info: telegram.0 (30221) Terminated (NO_ERROR): Without reason
    2020-08-28 03:35:09.343 - info: host.ioBroker instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
    2020-08-28 03:35:09.344 - info: host.ioBroker Restart adapter system.adapter.telegram.0 because enabled
    Es wurden keinerlei Updates kurz vor dem erstmalilgen Auftritt der Fehlermeldung durchgeführt.
    Das gesamte System läuft störungsfrei, alle Adapter default up to date, iot Adapter ist nicht installiert.
    Hat jemand einen Tip, was da los ist?
    NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
    • RöstkartoffelR Röstkartoffel
      haselchenH Offline
      haselchenH Offline
      haselchen
      @Röstkartoffel
      Im Log der Fritzbox mal geguckt, ob zu der Uhrzeit etwas passiert ist?
      Zwangstrennung oder dergleichen?
      RöstkartoffelR 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @Röstkartoffel
        Röstkartoffel
        @haselchen
        Hast recht, zu dem Zeitpunkt findet die Zwangstrennung statt.
        Aber dieser Fehler ist früher nie aufgetreten, vorgestern zum ersten Male, und die Zwangstrennung ist schon seit Jahren so eingestellt.
          @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          @Röstkartoffel
          Diese Fehlerzeilen habe ich auch, wenn was mit dem Internet im Argen ist.
          War auch für mich neu.
          Vielleicht kann ein Entwickler dazu was sagen.
