  2. English
  3. Scripting / Logic
  5. Notification every X minutes
5 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
    sekino
    Hi, I'm strugling to setup notification sending every X minutes.
    For example I'm trying to send notification when my washingmachine finish, that means power consumption is between 10-1 watts, this state is for 15 minutes until washingmachine will turn automatically off. HomematicIP power socket is updating state every 30 seconds, so when I simply turn on notification for state between 10-1 watts I'm getting notifications every 30 seconds which is too many. How can I set up Blockly to send notification for example every 5 minutes during state between 10-1 watts ?
    • S sekino
      @sekino sagte:
      5 min = 10 * 30 sec.
      Try it with a counter:
        @sekino sagte:
        sekino
        @paul53 That'working OK. Thank you very much!
        However I found out, sometimes when there is same value measured on power socket, it will not send any update, so counter not working, for example if washingmachine is in stand-by mode it will take 0.05wats whole day, this info is broadcasted just once at the beginning and then it's not updated in iObroker until washingmachine is woke up from stand-by mode. So a counter based on counting time will be more accurate... if someone did that already and working please share. Thank you!
        • S sekino
          @sekino sagte:
           <variables>
             <variable type="interval" id="Intervall">Intervall</variable>
             <variable id="{A0`1jN@JIs8CP|SdIu$">value</variable>
           </variables>
           <block type="on_ext" id="gxtz;)Dk/LY#MZsB7D92" x="88" y="38">
             <value name="OID0">
               <shadow type="field_oid" id="}E495DOI+!xy@bYeSZop">
               </shadow>
             </value>
             <statement name="STATEMENT">
               <block type="controls_if" id="oD]^g)Q2+28vt_2^!c|d">
                 <value name="IF0">
                   <block type="logic_operation" id="J^LX}g.t-FadQgTQ1nm," inline="false">
                     <field name="OP">OR</field>
                     <value name="A">
                       <block type="logic_compare" id="qP@j+y#/;[:cpQ2)NIwK">
                         <field name="OP">LT</field>
                         <value name="A">
                           <block type="variables_get" id="9_{)s([hS-jDX0n`~2*P">
                             <field name="VAR" id="{A0`1jN@JIs8CP|SdIu$">value</field>
                           </block>
                         </value>
                         <value name="B">
                           <block type="math_number" id="ZFF*md,Ght6.0LQMc;bd">
                             <field name="NUM">1</field>
                           </block>
                         </value>
                       </block>
                     </value>
                     <value name="B">
                       <block type="logic_compare" id="LK}XT_nke4u?J,L.jiW@">
                         <field name="OP">GT</field>
                         <value name="A">
                           <block type="variables_get" id="d)y0R-2-;R:AyzG0,N8Q">
                           </block>
                         </value>
                         <value name="B">
                           <block type="math_number" id="Y^/Ok|-|KUN?YZ2Q!4M.">
                             <field name="NUM">10</field>
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </value>
                 <statement name="DO0">
                   <block type="timeouts_clearinterval" id="JUHJw}F8]N/s/(rul!C?">
                     <field name="NAME">Intervall</field>
                   </block>
                 </statement>
                 <value name="IF1">
                   <block type="logic_negate" id="8vT9u%pqocN)yB.svek_">
                     <value name="BOOL">
                       <block type="variables_get" id="M|Y.t_rF!)+wqse*Za(N">
                         <field name="VAR" id="Intervall" variabletype="interval">Intervall</field>
                       </block>
                     </value>
                   </block>
                 </value>
                 <statement name="DO1">
                   <block type="telegram" id="~Y{?b~^.XF9Spn.!BBF0">
                     <field name="LOG"></field>
                     <value name="MESSAGE">
                       <shadow type="text" id="DJx!ZENicIL;Fk[,6H^j">
                       </shadow>
                     </value>
                     <next>
                       <block type="timeouts_setinterval" id=";~E8uG]8Q+{%+:o8Zd1#">
                         <field name="INTERVAL">5</field>
                         <field name="UNIT">min</field>
                           <block type="telegram" id="`c0t$b?BxWF4Y6Ef`Vnz">
                               <shadow type="text" id="`$7UMl8.S5Xral.%/)D3">
                               </shadow>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
          </xml>
            @sekino sagte:
             <variables>
             </variables>
               <value name="OID0">
                 </shadow>
               </value>
                   <value name="IF0">
                       <value name="A">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                     </block>
                   </statement>
                   <value name="IF1">
                       <value name="BOOL">
                         </block>
                       </value>
                     </block>
                   </value>
                         </shadow>
                       </value>
                       <next>
                                 </shadow>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
            </xml>
            sekino
            @paul53 Thank you very much! Working great :)
