  4. Node-Red
  5. Rechnen in Node Red
    6.5k
Rechnen in Node Red
4 Beiträge 2 Kommentatoren 4.8k Aufrufe 2 Beobachtet
  • H Offline
    Has3nb3inMH
    mache Gehversuche mit Node Red und würde gerne was Rechnen.
    Ich verstehe aber nicht warum da nur mist bei rum kommt :man-shrugging:
    Beste Grüße
    Daniel
            "id": "c05d6044.8035e",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": ""
            "id": "a31cc993.a28758",
            "type": "ioBroker get",
            "z": "c05d6044.8035e",
            "name": "Außenfühler Temperature",
            "topic": "zigbee.0.00158d0002ca05ad.temperature",
            "attrname": "Temperatur",
            "payloadType": "value",
            "x": 470,
            "y": 240,
            "wires": [
                    "8daf2546.310878"
            "id": "345fc725.3bd6d8",
            "name": "Außenfühler Humidity",
            "topic": "zigbee.0.00158d0002ca05ad.humidity",
            "attrname": "Luftfeuchte",
            "x": 520,
            "y": 380,
            "wires": [
                    "8daf2546.310878"
            "id": "5626f9b9.f054f8",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 420,
            "y": 160,
            "wires": [
                    "345fc725.3bd6d8",
                    "a31cc993.a28758"
            "id": "8daf2546.310878",
            "type": "function",
            "name": "Luftfeuchte",
            "func": "var Test = {};\nTest = Number(msg.Luftfeuchte) - Number(msg.Temperatur);\nmsg.payload = Test;\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "x": 810,
            "y": 340,
            "wires": [
                    "b9c676f0.b95a98"
            "id": "b9c676f0.b95a98",
            "type": "debug",
            "name": "Ausgabe",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 980,
            "y": 340,
            "wires": []
    Folgende Spukt der Debugger aus:
    2.8.2020, 11:12:40node: Ausgabe
    zigbee.0.00158d0002ca05ad.humidity : msg.payload : number
    NaN
    zigbee.0.00158d0002ca05ad.temperature : msg.payload : number
    NaN
    F 1 Antwort Letzte Antwort
    • H Has3nb3inMH
      Beste Grüße
      Daniel
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": ""
              "x": 470,
              "y": 240,
              "wires": [
                      "8daf2546.310878"
              "x": 520,
              "y": 380,
              "wires": [
                      "8daf2546.310878"
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "x": 420,
              "y": 160,
              "wires": [
                      "345fc725.3bd6d8",
                      "a31cc993.a28758"
              "type": "function",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "x": 810,
              "y": 340,
              "wires": [
                      "b9c676f0.b95a98"
              "type": "debug",
              "name": "Ausgabe",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 980,
              "y": 340,
              "wires": []
      NaN
      NaN
      frankyboy73
      @Has3nb3inMH
      Hi, als erstes musst du die Node in eine Reihe setzten, also hintereinander, dann werden beide Input Node durchlaufen und du bekommst eine Nachricht mit Temperatue und Feuchtigkeit. So wie du die Input Node (parallel) eingefügt hast bekommst du zwei Nachrichten zur Funktion Node, mit jeweils nur Temperatur und nur Feuchtigkeit und mit nur einem Wert kann das nicht berechnet werden. Zudem muss in der Funktion Node noch math für Mathematische Funktion rein.
              "id": "fd168a68.a54ce8",
              "z": "aa77b2e2.7ea12",
              "x": 470,
              "y": 360,
              "wires": [
                      "32adbecc.66add2"
              "id": "32adbecc.66add2",
              "x": 660,
              "y": 280,
              "wires": [
                      "b243e8ca.b1efb8"
              "id": "e5dc2454.e91218",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "x": 420,
              "y": 160,
              "wires": [
                      "fd168a68.a54ce8"
              "id": "b243e8ca.b1efb8",
              "type": "function",
              "func": "msg.payload = math = Number(msg.Luftfeuchte) - Number(msg.Temperatur);\nreturn msg;\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "x": 810,
              "y": 340,
              "wires": [
                      "a5cbebe5.024d48"
              "id": "a5cbebe5.024d48",
              "type": "debug",
              "name": "Ausgabe",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 980,
              "y": 340,
              "wires": []
      Schöne Grüße Frank
      H 1 Antwort Letzte Antwort
      • F frankyboy73
        @Has3nb3inMH
                "x": 470,
                "y": 360,
                "wires": [
                        "32adbecc.66add2"
                "x": 660,
                "y": 280,
                "wires": [
                        "b243e8ca.b1efb8"
                "type": "inject",
                "name": "",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "",
                "x": 420,
                "y": 160,
                "wires": [
                        "fd168a68.a54ce8"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "x": 810,
                "y": 340,
                "wires": [
                        "a5cbebe5.024d48"
                "type": "debug",
                "name": "Ausgabe",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 980,
                "y": 340,
                "wires": []
        Has3nb3inMH
        @frankyboy73 vielen Dank. Es hat genügt die Reihenfolge zu ändern.
        Das leben könnte so einfach sein. 😊
        • H Has3nb3inMH
          frankyboy73
          @Has3nb3inMH
          Ah, ok, ich dachte man müsste immer mit "math" arbeiten. Werde es mal ohne testen. Danke für die Rückmeldung. Schön das es jetzt bei dir funktioniert.
          Schöne Grüße Frank
