  4. Zigbee Problem , nur Gelb
zigbee gelb
3 Beiträge 2 Kommentatoren 257 Aufrufe 2 Beobachtet
    deta
    Ja System ist komplett aktuell. Zigbee Adapter vom Git.
    zigbee.0	2020-07-31 08:54:20.145	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-07-31 08:54:20.145	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:24:58)
    zigbee.0	2020-07-31 08:54:20.145	error	at Generator.next (<anonymous>)
    zigbee.0	2020-07-31 08:54:20.145	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:98:48)
    zigbee.0	2020-07-31 08:54:20.145	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
    zigbee.0	2020-07-31 08:54:20.145	error	at JSON.parse (<anonymous>)
    zigbee.0	2020-07-31 08:54:20.145	error	(14034) SyntaxError: Unexpected token in JSON at position 746
    zigbee.0	2020-07-31 08:54:20.111	error	(14034) Failed to start Zigbee
    zigbee.0	2020-07-31 08:54:19.822	info	(14034) Starting Zigbee...
    zigbee.0	2020-07-31 08:54:19.820	info	(14034) Try to reconnect. 1 attempts left
    zigbee.0	2020-07-31 08:54:09.816	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-07-31 08:54:09.816	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:24:58)
    zigbee.0	2020-07-31 08:54:09.816	error	at Generator.next (<anonymous>)
    zigbee.0	2020-07-31 08:54:09.816	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:98:48)
    zigbee.0	2020-07-31 08:54:09.816	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
    zigbee.0	2020-07-31 08:54:09.816	error	at JSON.parse (<anonymous>)
    zigbee.0	2020-07-31 08:54:09.816	error	(14034) SyntaxError: Unexpected token in JSON at position 746
    zigbee.0	2020-07-31 08:54:09.813	error	(14034) Failed to start Zigbee
    zigbee.0	2020-07-31 08:54:09.139	info	(14034) Starting Zigbee...
    zigbee.0	2020-07-31 08:54:09.075	info	(14034) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.1.6
    zigbee.0	2020-07-31 08:54:03.121	info	(13564) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2020-07-31 08:54:03.119	info	(13564) terminating
    zigbee.0	2020-07-31 08:54:03.117	error	at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:426:17))
    zigbee.0	2020-07-31 08:54:03.117	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-07-31 08:54:03.117	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:305:24)
    zigbee.0	2020-07-31 08:54:03.117	error	at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:318:30)
    zigbee.0	2020-07-31 08:54:03.117	error	at ZigbeeController.getDevice (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:211:30)
    zigbee.0	2020-07-31 08:54:03.117	error	at Controller.getDeviceByIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:242:31)
    zigbee.0	2020-07-31 08:54:03.117	error	at Function.byIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:16)
    zigbee.0	2020-07-31 08:54:03.117	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:213:55)
    zigbee.0	2020-07-31 08:54:03.117	error	(13564) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-07-31 08:54:03.108	info	(13564) cleaned everything up...
    zigbee.0	2020-07-31 08:54:03.105	info	(13564) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2020-07-31 08:53:58.777	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-07-31 08:53:58.777	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:24:58)
    zigbee.0	2020-07-31 08:53:58.777	error	at Generator.next (<anonymous>)
    zigbee.0	2020-07-31 08:53:58.777	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:98:48)
    zigbee.0	2020-07-31 08:53:58.777	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
    zigbee.0	2020-07-31 08:53:58.777	error	at JSON.parse (<anonymous>)
    zigbee.0	2020-07-31 08:53:58.777	error	(13564) SyntaxError: Unexpected token in JSON at position 746
    zigbee.0	2020-07-31 08:53:58.774	error	(13564) Failed to start Zigbee
    zigbee.0	2020-07-31 08:53:58.453	info	(13564) Starting Zigbee...
    zigbee.0	2020-07-31 08:53:58.451	info	(13564) Try to reconnect. 1 attempts left
    zigbee.0	2020-07-31 08:53:48.448	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-07-31 08:53:48.448	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:24:58)
    zigbee.0	2020-07-31 08:53:48.448	error	at Generator.next (<anonymous>)
    zigbee.0	2020-07-31 08:53:48.448	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:98:48)
    zigbee.0	2020-07-31 08:53:48.448	error	at Function.open (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/database.js:17:35)
    zigbee.0	2020-07-31 08:53:48.448	error	at JSON.parse (<anonymous>)
    zigbee.0	2020-07-31 08:53:48.448	error	(13564) SyntaxError: Unexpected token in JSON at position 746
    zigbee.0	2020-07-31 08:53:48.446	error	(13564) Failed to start Zigbee
    zigbee.0	2020-07-31 08:53:47.866	info	(13564) Starting Zigbee...
    zigbee.0	2020-07-31 08:53:47.802	info	(13564) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.1.6
    zigbee.0	2020-07-31 08:53:11.424	info	(3515) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2020-07-31 08:53:11.419	info	(3515) terminating
    zigbee.0	2020-07-31 08:53:11.415	error	at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:426:17))
    zigbee.0	2020-07-31 08:53:11.415	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-07-31 08:53:11.415	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:305:24)
    zigbee.0	2020-07-31 08:53:11.415	error	at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:318:30)
    zigbee.0	2020-07-31 08:53:11.415	error	at ZigbeeController.getDevice (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:211:30)
    zigbee.0	2020-07-31 08:53:11.415	error	at Controller.getDeviceByIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:242:31)
    zigbee.0	2020-07-31 08:53:11.415	error	at Function.byIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:16)
    zigbee.0	2020-07-31 08:53:11.415	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:213:55)
    zigbee.0	2020-07-31 08:53:11.415	error	(3515) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2020-07-31 08:53:11.392	info	(3515) cleaned everything up...
    zigbee.0	2020-07-31 08:53:11.387	info	(3515) Got terminate signal TERMINATE_YOURSELF
    Ich hatte es schon mal, weis aber nicht mehr wie ich das wieder hinbekommen habe.
    cu Deta
    H 1 Antwort Letzte Antwort
    • D deta
      cu Deta
      hesse
      @deta Schau mal hier:
      https://forum.iobroker.net/topic/34500/achtung-zigbee-adapter-problem-ab-17-06-2020
      Das könnte das Problem sein...
      • H hesse
        deta
        @hesse Hab das Backup von vor 2 Tagen eingespielt und siehe da. Geht wieder. Hat sich wohl eine Datei wieder zerlegt gehabt.
