  4. Fehlermeldung bei Adapterupdate
    6.8k
fehlermeldung adapterupdate
3 Beiträge 2 Kommentatoren 227 Aufrufe 2 Beobachtet
    Beowolf
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Linux
    Nodejs-Version: 14.5.0
    NPM-Version: 6.14.5
    Installationsart: Skript
    Image genutzt: Nein
    ich habe immer diese Meldungen bevor der Adapter den ich updaten möchte.
    z.B. dieser:
    $ ./iobroker upgrade luftdaten
    Update luftdaten from @0.0.15 to @0.0.17
    NPM version: 6.14.5
    npm install iobroker.luftdaten@0.0.17 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp
    ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v14.5.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)node-pre-gyp
     ERR! stack     at maybeClose (internal/child_process.js:1051:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)node-pre-gyp
    ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v14.5.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    upload [4] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/words.js words.js application/javascript
    Update "system.adapter.luftdaten.0"
    upload [3] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/style.css style.css text/css
    upload [2] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/luftdaten.png luftdaten.png image/png
    upload [1] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/index_m.html index_m.html text/html
    upload [0] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/admin.d.ts admin.d.ts video/mp2t
    Adapter "luftdaten" updated
    process exited with code 0
    Ich habe keine Ahnung wo bzw. was ich da machen soll.
    Grüße
    Manfred
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
    • B Beowolf
      Hardwaresystem: Pi4
      Festplattenart: SSD
      NPM-Version: 6.14.5
      Image genutzt: Nein
      z.B. dieser:
      NPM version: 6.14.5
      gyp
      node-pre-gyp
       ERR! build error
      Grüße
      Manfred
      @Beowolf canvas von Hand installieren. Steht mehrfach hier im Forum, wie das geht.
      Und an deiner Stelle würde ich auch nicht node14, sondern node12 einsetzen.
        Beowolf
        Danke, läuft wieder alles.
