  4. Sending messages to iobroker instance
2 Beiträge 1 Kommentatoren 797 Aufrufe
  • I Offline
    I Offline
    iobroker-6043
    Hello community
    I have my NodeMCU sketch up and running. In the serial monitor it looks ok, but the controller (iobroker with mysensors instance)
    does not receive any messages. I can read the temperature, but then the sketch runs into an exception and does a stack trace.
    ?? Best regards and any help is appreciated.
    connected with ho….., channel 1
    dhcp client start...
    chg_B1:-40
    .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
    .IP: 192.168.1.103
    –------------------------------------------>Temperature for the device 1 (index 0) is: 24.00
    Fatal exception 9(LoadStoreAlignmentCause):
    epc1=0x402026c0, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000002f, depc=0x00000000
    Exception (9):
    epc1=0x402026c0 epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
    ctx: cont
    sp: 3ffef410 end: 3ffef680 offset: 01a0
    stack>>>
    3ffef5b0: 3ffef600 3ffee638 00000008 40205ca0
    3ffef5c0: 3ffe8750 00000000 000000ff 40207270
    3ffef5d0: ffffffff 00000080 3ffee638 00000004
    3ffef5e0: 000000e7 3ffef990 3ffef6f8 3ffee650
    3ffef5f0: 3fffdad0 3ffef70f 3ffef6f8 402039c8
    3ffef600: 3ffef710 00000000 3ffef6cc 40204095
    3ffef610: 3fffdad0 00000000 00000006 40202336
    3ffef620: 3ffe892c 3ffee61c 3fff0d6c 3ffee650
    3ffef630: 3fffdad0 00000000 00000005 40204365
    3ffef640: 3fffdad0 00000000 3ffee5f0 402044f5
    3ffef650: 00000000 00000000 3ffee5f0 40204720
    3ffef660: 3fffdad0 00000000 3ffee5f0 4020474c
    3ffef670: feefeffe feefeffe 3ffee660 40100114
    <<<stack<<<< r=""></stack<<<<>
    • I Offline
      I Offline
      iobroker-6043
      unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
      OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
      DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
      float lastTemperature[MAX_ATTACHED_DS18B20];
      int numSensors=0;
      bool receivedConfig = false;
      bool metric = true;
      // Initialize temperature message
      MyMessage msg(0,V_TEMP);
      ! void setup()
      // Startup up the OneWire library
      sensors.begin();
      // requestTemperatures() will not block current thread
      sensors.setWaitForConversion(false);
      ! void presentation() {
      // Send the sketch version information to the gateway and Controller
      // sendSketchInfo("Temperature Sensor", "1.1");
      // Fetch the number of attached temperature sensors
      numSensors = sensors.getDeviceCount();
      // Present all sensors to controller
      present(0, S_TEMP);
      ! void loop()
      // Fetch temperatures from Dallas sensors
      sensors.requestTemperatures();
      Serial.print("-------------------------------------------->Temperature for the device 1 (index 0) is: ");
      Serial.println(sensors.getTempCByIndex(0));
