  4. GELÖST: Nach Update javascript ROT
    6.3k
javascriptupdate
4 Beiträge 4 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • C Offline
    ChrisXY
    schrieb am zuletzt editiert von ChrisXY
    Edit:
    Problem behoben mit:
    cd /opt/iobroker/node_modules/iobroker.javascript
    npm install --production
    heute morgen iobroker selbst geupdatet. Danach auch der FIX... aber javascript bleibt rot
    host.iobroker	2020-06-14 06:47:16.442	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: ^
    host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: throw err;
    host.iobroker	2020-06-14 06:47:16.438	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
    SoundyS 1 Antwort Letzte Antwort
    • C ChrisXY
      Edit:
      SoundyS Offline
      SoundyS Offline
      Soundy
      @chrisxy
      nach Updates von ioBroker hatte ich selbiges Problem und konnte mit diesem Tipp das Problem lösen. Jetzt habe ich im Protokoll nurmehr diese Warnung:
      javascript.0 2022-07-15 16:28:39.092	error	WARN config production Use `--omit=dev` instead.
      javascript.0 2022-07-15 16:28:39.090	error	npm
      Ich lass es aber mal lieber, bevor ich mir irgendwas verballere. :-) Eigentlich könnte ich
      npm install --omit=dev
      machen, aber dafür habe ich zu viel Angst, dass ich mir ioBroker zerknalle. Momentan fehlt mir auch die Zeit, dass ich mich ggf. mit einer langwierigen Fehlersuche oder sogar eine Neuinstallation beschäftige. ;)
      Danke und Lg, Jürgen
      • SoundyS Soundy
        @chrisxy
        @soundy sagte in GELÖST: Nach Update javascript ROT:
        javascript.0 2022-07-15 16:28:39.092	error	WARN config production Use --omit=dev instead.
        Das ist nur ein (zu kurzer) Ausschnitt des Logs. Ich vermute, die Meldungen kommen im Zusammenhang mit zusätzlich im javascript-Adapter eingetragenen Modules und npm>6.
        Sind dann harmlos und können überlesen werden.
        • SoundyS Soundy
          @chrisxy
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          bezieht sich das auch hierzu , in einem neuen Thread !?
          https://forum.iobroker.net/topic/56426/fehler-file-tab-html-not-found-bei-menüpunkt-skripte
