  4. Probleme nach Update node.js
node.js updateserialport@6.2.2
16 Beiträge 5 Kommentatoren 2.4k Aufrufe 5 Beobachtet
    Andy200877
    Ich habe versucht meinen IOBroker mal wieder auf den neusten Stand zu bekommen. Grundsätzlich läuft auch alles, jedoch bekomme ich nach dem Update von Node.js beim "npm rebuild" einen Error angezeigt...
    > serialport@6.2.2 install /opt/iobroker/node_modules/cul/node_modules/serialport
    > prebuild-install || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=12.18.0 runtime=node arch=x64 platform=linux)
    make: Entering directory '/opt/iobroker/node_modules/cul/node_modules/serialport/build'
      CXX(target) Release/obj.target/serialport/src/serialport.o
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
       v8::String::Utf8Value path(info[0]->ToString());
    In file included from /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:67:0,
                     from ../../../../nan/nan.h:54,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
    In file included from /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8-internal.h:14:0,
                     from /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                     Local<String> ToString(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
       v8::Local<v8::Object> options = info[1]->ToObject();
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
       V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                     Local<Object> ToObject(Isolate* isolate) const);
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6:0,
    ../../../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/v8.h:3499:22: note: declared here
                     bool Set(Local<Value> key, Local<Value> value));
    ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
       void init(v8::Handle<v8::Object> target) {
    ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
    In file included from ../../../../nan/nan.h:54:0,
    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
     NODE_MODULE(serialport, init);
    /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
    serialport.target.mk:114: recipe for target 'Release/obj.target/serialport/src/serialport.o' failed
    make: *** [Release/obj.target/serialport/src/serialport.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/cul/node_modules/serialport/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.0-0.bpo.6-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/cul/node_modules/serialport
    gyp ERR! node -v v12.18.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2020-06-13T08_37_54_943Z-debug.log
    Die Log-Datei habe ich hier auch mal angehangen....
    2020-06-13T08_20_24_683Z-debug.log
    Kann mir jemand sagen wie ich diesen Fehler beseitigen kann ?
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Intel(R) Core(TM) i3-4130
    Arbeitsspeicher: 16GB
    Festplattenart: SSD
    Betriebssystem: Debian
    Node-Version: v12.18.0
    Nodejs-Version: v12.18.0
    NPM-Version: 6.14.4
    Installationsart: Manuell
    Image genutzt: Nein
    https://github.com/Andy200877/intex_poollampe
    • A Andy200877
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      Festplattenart: SSD
      NPM-Version: 6.14.4
      Image genutzt: Nein
      @Andy200877
      node gerade im System?
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        Andy200877
        root@NAS:~# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v12.18.0
        /usr/bin/node
        v12.18.0
        /usr/bin/npm
        6.14.4
        nodejs:
          Installed: 12.18.0-1nodesource1
          Candidate: 12.18.0-1nodesource1
          Version table:
         *** 12.18.0-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                100 /var/lib/dpkg/status
             8.11.1~dfsg-2~bpo9+1 100
                100 http://httpredir.debian.org/debian stretch-backports/main amd64 Packages
             4.8.2~dfsg-1 500
                500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
        root@NAS:~#
        • A Andy200877
          /usr/bin/nodejs
          v12.18.0
          /usr/bin/node
          v12.18.0
          /usr/bin/npm
          6.14.4
          nodejs:
            Version table:
               4.8.2~dfsg-1 500
          root@NAS:~#
          @Andy200877
          Nicht als root rumhampeln.
          Als user:
          iobroker fix
          cd /opt/iobroker
          npm cache clean --force
          iobroker update
          iobroker upgrade
          iobroker rebuild
            Andy200877
            schrieb am zuletzt editiert von Andy200877
            Ich habe mir vorher einen neuen User angelegt, mit ssh und sudo rechten.
            iobroker fix, update, upgrade usw. läuft ohne Fehler durch.
            Bei "iobroker rebuild" bricht er mir relativ schnell ab :
            andreas@NAS:/opt/iobroker$ iobroker rebuild
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487
                        if (name.indexOf('@') !== -1) {
            TypeError: Cannot read property 'indexOf' of undefined
                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487:22)
                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2601:5)
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                at Module._compile (internal/modules/cjs/loader.js:1138:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                at Module.load (internal/modules/cjs/loader.js:986:32)
                at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                at internal/main/run_main_module.js:17:47
            • A Andy200877
              @Andy200877
              Da klemmt es irgendwo tiefer, scheint mir.
              Ich würde mal versuchen den js-controller neuzuinstallieren.
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                Andy200877
                js-controller als user neu installiert...
                andreas@NAS:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controlle                                                            r
                [sudo] password for andreas:
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/31                           42
                > iobroker.js-controller@3.1.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.14.4
                > iobroker.js-controller@3.1.5 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
                object system.certificates updated
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                + iobroker.js-controller@3.1.5
                updated 2 packages in 21.034s
                43 packages are looking for funding
                  run `npm fund` for details
                Danach aber der gleiche Fehler wie vorher...
                  Djpredator69
                  schrieb am zuletzt editiert von Djpredator69
                  hi habe auch probleme nach update mit dem serialport@6.2.2 unter
                  Windows server 2016
                  Node.js
                  v12.18.0
                  NPM
                  6.14.5
                  i hatte den WM-BUS installiert duch den fehler mit dem serial lässt der sich nicht mehr starten oder neu installieren!
                    Andy200877
                    Niemand eine Idee ? Oder muss ich wirklich das komplette System neu aufsetzen ?
                    G D 2 Antworten Letzte Antwort
                    • A Andy200877
                      gifftstaub
                      @Andy200877
                      link text
                      Vllt hilft der Link weiter
                      Lg
                      • A Andy200877
                        Djpredator69
                        @Andy200877
                        es scheint dass serialport@6.2.2 nur unter Node.js v10 läuft und nicht unter der v12
                        habe ein downdrade auf 10 gemacht da läuft alles
                        bei einem update auf 12 wieder ,taucht das problem wieder auf
                        finde keine lösung , der WM-bus adapter muss umgeschrieben werden damit er die neuste serialport
                        lib nutzt und nicht die 6.2.2, die ist leider veraltet
                        v522533V Thomas BraunT 2 Antworten Letzte Antwort
                        • D Djpredator69
                          @Andy200877
                          v522533V Offline
                          v522533V Offline
                          v522533
                          @Djpredator69
                          kann zwar bei dem problem nicht helfen, ich kann aber sagen dass bei mir alles unter node 12.x.x problemlos läuft. das kann also nicht das problem sein.
                          Gruß Chris
                          • D Djpredator69
                            @Andy200877
                            @Djpredator69 sagte in Probleme nach Update node.js:
                            @Andy200877
                            Mal den serialport gegen node12 neugebaut?
                            • v522533V v522533
                              @Djpredator69
                              Djpredator69
                              @v522533
                              hast du auch den WM-bus am laufen
                              denn ich habe nur mit diesem adapter probleme alles andere läuft auch bei mir super
                              v522533V 1 Antwort Letzte Antwort
                              • D Djpredator69
                                @v522533
                                v522533V Offline
                                v522533V Offline
                                v522533
                                @Djpredator69
                                ne den habe ich nicht am laufen
                                Gruß Chris
                                  Djpredator69
                                  habe es jetzt am laufen
                                  habe den adapter vom git installiert dann per hand die instanz installiert jetzt läuft es
                                  wenn ich aber das ganze über iobroker installiere kommen nur die oben genanten fehler
                                  ich teste den adapter jetzt ob er auch 100% läuft
