  4. Shelly 2.5 Error
Shelly 2.5 Error
error shelly
23 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • xxx_turbo_xxxX Offline
    xxx_turbo_xxx
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Raspbian
    Node-Version: ?
    Nodejs-Version: 12.6.3
    NPM-Version: 6.?
    Installationsart: ioBroker image
    Image genutzt: Ja
    ich bekomme ständig folgenden error...
    2020-05-18 18:08:19.995 - error: shelly.0 (3232) Error handling Shelly data: SyntaxError: Unexpected token P in JSON at position 1017 (res) for JSON {"blk":[{"I":0,"D":"Relay0"},{"I":1,"D":"Relay1"},{"I":2,"D":"Device"}],"sen":[{"I":112,"T":"S","D":"State","R":"0/1","L":0},{"I":122,"T":"S","D":"State","R":"0/1","L":1},{"I":111,"T":"P","D":"Power","R":"0/2300","L":0},{"I":121,"T":"P","D":"Power","R":"0/2300","L":1},{"I":118,"T":"S","D":"Input","R":"0(off)/1(on)/2(longpush)","L":0},{"I":128,"T":"S","D":"Input","R":"0(off)/1(on)/2(longpush)","L":1},{"I":115,"T":"T","D":"Temperature C","R":"-40/300","L":2},{"I":116,"T":"T","D":"Temperature F","R":"-40/300","L":2},{"I":117,"T":"S","D":"Overtemp","R":"0/1","L":2},{"I":211,"T":"S","D":"Energy counter 0 [W-min]","L":0},{"I":212,"T":"S","D":"Energy counter 1 [W-min]","L":0},{"I":213,"T":"S","D":"Energy counter 2 [W-min]","L":0},{"I":214,"T":"S","D":"Energy counter total [W-min]","L":0},{"I":221,"T":"S","D":"Energy counter 0 [W-min]","L":1},{"I":222,"T":"S","D":"Energy counter 1 [W-min]","L":1},{"I":223,"T":"S","D":"Energy counter 2 [W-min]","L":1},{"I":224,"T":"S","D":"Energy counter total [W-min]","L":1}]}PB��cits��	SHSW-25#BCDDC27766F0#1�C����{"G":[[0,112,1],[0,122,1],[0,111,97.810028],[0,121,1918.086670],[0,118,0],[0,128,0],[0,115,87.57],[0,116,189.62],[0,117,0],[0,211,94.965],[0,212,282.307],[0,213,656.066],[0,214,179854],[0,221,1924.700],[0,222,1903.324],[0,223,1872.539],[0,224,217548]]}
    Kann mir jemand sagen, woran das liegen könnte?
    Danke schonmal!
    • xxx_turbo_xxxX xxx_turbo_xxx
      Hardwaresystem: Pi4
      Node-Version: ?
      NPM-Version: 6.?
      Image genutzt: Ja
      Danke schonmal!
      haselchenH Offline
      haselchenH Offline
      haselchen
      @xxx_turbo_xxx
      Version Shelly Adapter?
      App Version?
      xxx_turbo_xxxX 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @xxx_turbo_xxx
        App Version?
        xxx_turbo_xxx
        @haselchen Shelly 2.5! App nutze ich nicht! Hab den Shelly per http konfiguriert und sonst steuere ich ihn per ioBroker
        harrymH haselchenH 2 Antworten Letzte Antwort
          harrymH Offline
          harrymH Offline
          harrym
          @xxx_turbo_xxx mach mal ein FW update bei dem 2.5er ;)
          ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
            haselchenH Offline
            haselchenH Offline
            haselchen
            @xxx_turbo_xxx
            Und ich hatte nach der Adapter Version gefragt, nicht nach der Shelly Version ;)
            harrymH 1 Antwort Letzte Antwort
              @xxx_turbo_xxx
              harrymH Offline
              harrymH Offline
              harrym
              @haselchen de FW is es Problem .... de "Fehler" beruhen auf ner alten FW Version beim shelly ;)
              J haselchenH 2 Antworten Letzte Antwort
              • harrymH harrym
                Jan1
                @harrym
                und die hat er darauf weil er das APP nicht nutzt ;-)
                • harrymH harrym
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @harrym
                  Welche FW hast Du auf den(m) Shelly(s)?
                  @Jan1
                  Alle üblichen Verdächtigen wieder vereint :)
                  • J Jan1
                    @harrym
                    harrymH Offline
                    harrymH Offline
                    harrym
                    @Jan1 was hat de APP mit der GUI zu tun????
                    J 1 Antwort Letzte Antwort
                    • harrymH harrym
                      Jan1
                      @harrym
                      Die FW des Shelly wird doch wohl über die APP aktualisiert, oder wie läuft das bei den Dingern und original FW?
                        @harrym
                        @Jan1
                        harrymH Offline
                        harrymH Offline
                        harrym
                        @haselchen 1.6
                        • J Jan1
                          @harrym
                          harrymH Offline
                          harrymH Offline
                          harrym
                          @Jan1 nö. kannste auch über die GUI aktualisieren ..... einfach den shelly via browser mit der ip aufrufen. shelly funzt auch ohne cloud und app ;)
                          • harrymH harrym
                            Jan1
                            @harrym
                            Ja das weiß ich dass das auch ohne geht, war der Annahme, dass die APP das regelt. War wohl falsch, die Annahme :-)
                            • J Jan1
                              @harrym
                              harrymH Offline
                              harrymH Offline
                              harrym
                              @Jan1 alles gut ;)
                              • harrymH harrym
                                @Jan1 alles gut ;)
                                Jan1
                                @harrym
                                Ich hab zwar jede Menge der Dinger, aber die laufen bei mir alle mit Tasmota, weil ich alles in einem Adapter haben möchte und ich bin da von den Sonoff ausgegangen, weil die das eben über die APP machen, wieder schlauer 😎
                                Dann sollte er mal ein Update fahren, ist mir eh immer ein Rätsel warum User mit alten Ständen nicht einfach mal updaten und dann schaue ob der Fehler überhaupt noch da ist 😜
                                • harrymH Offline
                                  harrymH Offline
                                  harrym
                                  man kann die shelly auch via RestAPI lokal via OTA mit neuer FW versorgen .....DAS ist aber noch nicht im shelly adapter implementiert.
                                  • J Jan1
                                    @harrym
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    @Jan1 wie bist du mit tasmota auf de shelly zufrieden? ich hab bis dato eigentlich noch keinen grund gesehen, dass ich da vom coap/mqtt und der originalen FW auf tasmota wechsel ..... welche vorteile hast du da?
                                    • harrymH harrym
                                      Jan1
                                      @harrym
                                      Hab ich ja schon geschrieben, alles in einem Adapter und deshalb etwas übersichtlicher. Dann habe ich Quickview im Einsatz das mir alle Tasmota Geräte auf einer HTML Seite listet, was eben einfacher ist wenn man mal direkt steuern will. Dann habe ich die meisten als Shutter im Einsatz und da gefällt mir Tasmota ein Tick besser, ansonsten ist es eher Geschmackssache ob original oder Tasmota.
                                      Da gibts ausnahmsweise mal nicht die Vor- oder Nachteile, die original ist schon gut durchdacht.
                                      • J Jan1
                                        @harrym
                                        harrymH Offline
                                        harrymH Offline
                                        harrym
                                        schrieb am zuletzt editiert von harrym
                                        @Jan1 tasmoadmin ? g
                                        und alles in einem adapter .... kannste dir ja abseits vom broker nen master aufsetzten .... und den dann via broker als client abfragen .....ok .... der sonoff adapter unterstützt das noch nicht.
                                        • harrymH harrym
                                          Jan1
                                          @harrym
                                          von TasmotaAdmin halte ich nicht viel, da ich viele verschiedene Tasmota Devices habe und damit nicht wirklich ein Vorteil. Ich passe jedes bin dem Device an und der Admin erlaubt nur ein bin für alle zum updaten z.B.
                                          Machen kann man viel, wobei ich da so wenig wie möglich als HW bevorzuge.
