  4. Generelles Problem keine updates möglich
update error
5 Beiträge 3 Kommentatoren 746 Aufrufe 2 Beobachtet
  • K Offline
    kkickingereder
    Hallo Gemeinde,
    kann keinen Adapter mehr updaten (z.Zt. 5 ausstehend), kommen alle mit gleicher Fehlermeldung
    |Node-Version:| 10.20.1 |
    |Nodejs-Version:| 10.20.1 |
    |NPM-Version:| 6.14.4 |
    NPM version: 6.14.4npm install iobroker.hue@3.2.9 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp gyp ERR! configure error gyp ERR! stack Error: gypfailed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.20.1gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.20.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install:node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-13T06_57_45_982Z-debug.log
    upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
    Update "system.adapter.hue.0"
    upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
    upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
    upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
    upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
    Adapter "hue" updated
    process exited with code 0
    Trotz Returncode 0 bleibt der Adapter bei alter Version.
    Danke für Eure Hilfe
    • ? Offline
      @kkickingereder sagte in Generelles Problem keine updates möglich:
      Dieser Adapter ist aber trotz dieser Fehlermeldung erfolgreich upgedatet worden.
      Da ist mal wieder Canvas das Problem und kommt glaube ich vom iot Adapter.
      Solltest Du erstmal ignorieren können.
      • Thomas BraunT Online
        Oder 'canvas' selber bauen.
        K 1 Antwort Letzte Antwort
          kkickingereder
          @Thomas-Braun
          wie geht das ?
          • K kkickingereder
            @Thomas-Braun
            wie geht das ?
            @kkickingereder
            Ungefähr so wie hier:
            https://forum.iobroker.net/topic/33189/gyp-fehler-bei-erstinstallation-und-adaptern-iot-alexa/27
