  4. Alexa2 Adapter startet nicht / Cookie wird nicht gespeichert
alexa 2 adapter
7 Beiträge 2 Kommentatoren 571 Aufrufe 2 Beobachtet
  • Thomas BraunT Online
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry Pi 4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Raspbian Buster
    Node-Version: 14.0.0
    Nodejs-Version: 14.0.0
    NPM-Version: 6.14.4
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
      Wenn ich denn Adapter startet schmeißt er folgendes raus:
      2020-04-28 20:36:01.839  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 3114
      2020-04-28 20:36:03.591  - info: alexa2.0 (3114) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.0.0, js-controller: 3.0.20
      2020-04-28 20:36:03.697  - info: alexa2.0 (3114) Proxy IP not set, use first network interface (192.168.178.50) instead
      2020-04-28 20:36:04.006  - error: alexa2.0 (3114) Error:
      2020-04-28 20:36:04.006  - error: alexa2.0 (3114) Error: You can try to get the cookie manually by opening http://192.168.178.50:34705/ with your browser.
      2020-04-28 20:37:33.674  - info: info.0 (931) Popup news was read...
      2020-04-28 20:47:08.613  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
      2020-04-28 20:47:08.633  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
      2020-04-28 20:47:08.635  - info: alexa2.0 (3114) Got terminate signal TERMINATE_YOURSELF
      2020-04-28 20:47:08.640  - info: alexa2.0 (3114) terminating
      2020-04-28 20:47:08.646  - info: alexa2.0 (3114) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-04-28 20:47:09.176  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-04-28 20:47:11.732  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 3601
      2020-04-28 20:47:13.373  - info: alexa2.0 (3601) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.0.0, js-controller: 3.0.20
      2020-04-28 20:47:13.465  - info: alexa2.0 (3601) Proxy IP not set, use first network interface (192.168.178.50) instead
      2020-04-28 20:47:13.806  - error: alexa2.0 (3601) Error:
      2020-04-28 20:47:13.807  - error: alexa2.0 (3601) Error: You can try to get the cookie manually by opening http://192.168.178.50:43673/ with your browser.
      2020-04-28 20:47:41.094  - warn: alexa2.0 (3601) Exception: TypeError: Cannot read property 'end' of null
      2020-04-28 20:47:41.097  - error: alexa2.0 (3601) uncaught exception: Cannot read property 'end' of null
      2020-04-28 20:47:41.098  - error: alexa2.0 (3601) TypeError: Cannot read property 'end' of null
          at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36)
          at IncomingMessage.emit (events.js:327:22)
          at IncomingMessage.EventEmitter.emit (domain.js:485:12)
          at endReadableNT (_stream_readable.js:1218:12)
          at processTicksAndRejections (internal/process/task_queues.js:84:21)
      2020-04-28 20:47:41.129  - info: alexa2.0 (3601) terminating
      2020-04-28 20:47:41.131  - info: alexa2.0 (3601) Terminated (NO_ERROR): Without reason
      2020-04-28 20:47:41.404  - error: host.raspberrypi Caught by controller[0]: (node:3601) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
      2020-04-28 20:47:41.405  - error: host.raspberrypi Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
      2020-04-28 20:47:41.405  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read property 'end' of null
      2020-04-28 20:47:41.406  - error: host.raspberrypi Caught by controller[1]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36)
      2020-04-28 20:47:41.406  - error: host.raspberrypi Caught by controller[1]:     at IncomingMessage.emit (events.js:327:22)
      2020-04-28 20:47:41.406  - error: host.raspberrypi Caught by controller[1]:     at IncomingMessage.EventEmitter.emit (domain.js:485:12)
      2020-04-28 20:47:41.407  - error: host.raspberrypi Caught by controller[1]:     at endReadableNT (_stream_readable.js:1218:12)
      2020-04-28 20:47:41.407  - error: host.raspberrypi Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:84:21)
      2020-04-28 20:47:41.407  - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2020-04-28 20:47:41.408  - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
      Das cookie habe ich schon diverse Male neugeholt, das wird nicht gespeichert und der Adapter fragt immer wieder danach. Keine Ahnung was da schiefläuft.
        Na sowas blödes...
        Habe auf node12 umgestellt, jetzt läuft es wieder.
        Ich bin aber felsenfest davon überzeugt, dass es auch unter 14 schon mal lief...
        • apollon77A Offline
          Die 3.2.0 vom Adapter sollte auch unter Nodejs 14 laufen
          • apollon77A apollon77
            @apollon77 Komischerweise läuft die 3.1.2 bei mir gerade auch mit node14.
            3.2.0 ist noch nicht im latest drin.
            apollon77A 2 Antworten Letzte Antwort
              @Thomas-Braun Der Fehler mit nodejs 14 tritt nur auf wenn DU kein Cookie hast und dich daher anmelden musst ... Wenn Du also eins Hast und er das nur "refresht" ist alles ok gewesen :-)
                @Thomas-Braun sagte in Alexa2 Adapter startet nicht / Cookie wird nicht gespeichert:
                Jupp, > 2 Uhr :-)
