  4. Fehler Installation SQL Adapter
windows installationsql adapterfehlermeldung bei installation
2 Beiträge 1 Kommentatoren 298 Aufrufe 1 Beobachtet
    ttheoc
    Hallo!
    Die Installation des SQL-Adapters wird bei mir immer mit einem Fehler beendet.
    Kann mir evtl. jemand helfen? Danke schon mal!
    s=
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Narrow Box Ultra HD Compact V3
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Windows 10 Pro
    Nodejs-Version: v10.17.0
    NPM-Version: 6.11.3
    $ ./iobroker add sql  --host DESKTOP-J4TR74F(SmartHome)
    NPM version: 6.11.3
    npm install iobroker.sql@1.9.5 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
    gyp
    ERR! find VS gyp ERR! find VS msvs_version not set from command line or npm configgyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Promptgyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newergyp ERR! find VS looking for Visual Studio 2015gyp ERR! find VS - not foundgyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8gyp ERR! find VS gyp ERR! find VS **************************************************************gyp
    ERR! find VS You need to install the latest version of Visual Studiogyp ERR! find VS including the "Desktop development with C++" workload.gyp ERR! find VS
    For more information consult the documentation at:gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windowsgyp ERR! find VS **************************************************************gyp
    ERR! find VS
    gyp
    ERR! configure error gyp ERR! stack Error: Could not find any Visual Studio installation to usegyp ERR! stack     at VisualStudioFinder.fail (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)gyp ERR! stack     at findVisualStudio2013 (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16)gyp ERR!
    stack     at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:344:14)gyp ERR! stack     at findVisualStudio2015 (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14)gyp ERR! stack     at regSearchKeys (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:365:16)gyp ERR!
    stack     at regGetValue (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7)gyp ERR! stack     at C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16gyp ERR!
    stack     at ChildProcess.exithandler (child_process.js:301:5)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    gyp
    ERR! System Windows_NT 10.0.18362gyp ERR! command "C:\\Program Files\\iobroker\\SmartHome\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\SmartHome\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR!
    cwd C:\Program Files\iobroker\SmartHome\node_modules\iobroker.sql\node_modules\mmmagicgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3
    gyp ERR! not ok
    npm
    ERR! code ELIFECYCLEnpm ERR! errno 1
    npm
    ERR! mmmagic@0.5.3 install: `node-gyp rebuild`npm ERR! Exit status 1npm
    ERR!
    npm
    ERR! Failed at the mmmagic@0.5.3 install script.
    npm
    ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-03-20T19_50_34_676Z-debug.log
    ERROR: host.DESKTOP-J4TR74F(SmartHome) Cannot install iobroker.sql@1.9.5: 1
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
      ttheoc
      Hallo!
      Habe jetzt ioBroker auf Windows 10 als Linux Version installiert.
      Bin nach folgender Anleitung vorgegangen:
      Läuft bisher wunderbar!
