  4. npm error bei allen Adaptern
    1.0k
    6.1k
npm error
25 Beiträge 5 Kommentatoren 8.1k Aufrufe 4 Beobachtet
  • B Bielefelder81
    @apollon77 Als verfügbare Version wir mir immer noch nur 1.4.10 angezeigt. Wechsel von 1.4.6 auf 1.4.10
    @Bielefelder81 Andere Frage: Welcher js-controller?
    B 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Bielefelder81
      @apollon77 2.2.9
      Ich hatte bereits versucht auch dort upzudaten, aber auch ohne Erfolg.
      • B Bielefelder81
        @apollon77 2.2.9
        Bielefelder81
        schrieb am zuletzt editiert von Bielefelder81
        Update js-controller from @2.2.9 to @3.0.19
        NPM version: 6.14.4
        npm install iobroker.js-controller@3.0.19 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
        Package pixman-1 was not found in the pkg-config search path.
        Perhaps you should add the directory containing `pixman-1.pc'
        to the PKG_CONFIG_PATH environment variable
        No package 'pixman-1' found
        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp ERR! configure error
        gyp ERR! stack Error: `gyp` failed with exit code: 1
        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.19.97-v7+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v10.20.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        node-pre-gyp ERR! System Linux 4.19.97-v7+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v10.20.1
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2020-04-27T06_42_53_525Z-debug.log
        Starting node restart.js
        Jetzt steht verfügbar 3.0.19 und vorhanden auch...
        Trotzdem steht ne 1 in iobroker unter Hosts...
        Teste jetzt mal die Adapter installationen.
        • B Bielefelder81
          NPM version: 6.14.4
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @Bielefelder81 sagte in npm error bei allen Adaptern:
          Ja das geht erst weg, wenn du die Admin-Seite komplett neu lädst.
          https://github.com/ioBroker/ioBroker.admin/issues/499
          • AlCalzoneA AlCalzone
            Bielefelder81
            Hat leider alles nichts geholfen.
            Trotzdem vielen Dank an alle für die Hilfe.
