  4. Fehlerschleife im Info-Adapter
info adapter
10 Beiträge 5 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • K Offline
    kaifu
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi 4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: 10.19.0
    Nodejs-Version: 10.19.0
    NPM-Version: 6.13.0
    Installationsart: Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    Aus dem nichts habe ich seit ca. 17 Uhr heute plötzlich folgenden Fehler:
    host.raspberrypi	2020-02-06 20:55:40.989	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.raspberrypi	2020-02-06 20:55:40.989	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:90593)
    host.raspberrypi	2020-02-06 20:55:40.989	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
    host.raspberrypi	2020-02-06 20:55:40.988	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
    host.raspberrypi	2020-02-06 20:55:40.988	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2020-02-06 20:55:40.988	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
    host.raspberrypi	2020-02-06 20:55:40.987	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2020-02-06 20:55:40.987	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
    host.raspberrypi	2020-02-06 20:55:40.987	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
    host.raspberrypi	2020-02-06 20:55:40.986	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
    host.raspberrypi	2020-02-06 20:55:40.985	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
    info.0	2020-02-06 20:55:40.866	error	(17985) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.i
    info.0	2020-02-06 20:55:40.862	error	(17985) uncaught exception: Cannot read property 'split' of undefined
    Könnte mir bitte jemand helfen???
    Danke!
    • K Offline
      kaifu
      Falls es noch jemandem hilft: Update des Admins auf 4.0 (nicht unter "default", sondern nur unter "latest" verfügbar!) hat schließlich geholfen.
      • juneesJ Offline
        juneesJ Offline
        junees
        schrieb am zuletzt editiert von junees
        Ich habe genau das gleiche Problem. Bei mir fing es gestern aus heiterem Himmel an.
        Da ich noch recht neu in dem Thema bin, was meinst du mit Update findet man unter "latest"? Kann das nicht wirklich finden. Danke schonmal!
        R 1 Antwort Letzte Antwort
        • juneesJ junees
          R Online
          R Online
          RalfEngelberth
          @junees sagte in Fehlerschleife im Info-Adapter:
          gehe mal ins System,
          da findest du folgende Verwahrungsorte
          Dann in "Aktiver Verwahrungsort" latest auswählen.
          Nach dem Update von Admin über latest ist der Fehler bei mir weg.
          Zur Info:
          https://www.iobroker.net/#de/documentation/admin/settings.md?verwahrungsorte
          juneesJ 1 Antwort Letzte Antwort
          • R RalfEngelberth
            Zur Info:
            juneesJ Offline
            juneesJ Offline
            junees
            @RalfEngelberth Super, vielen Dank! Muss gleich mal ein Backup ziehen und dann schauen, ob es das Problem bei mir auch behebt.
            • juneesJ Offline
              juneesJ Offline
              junees
              Seit update auf 4.0.1 ist der Fehler bei mir jetzt auch weg.
              • N Offline
                N Offline
                Newbie12
                schrieb am zuletzt editiert von Newbie12
                wollte den Fehler nach dieser Anleitung behegben. Allerdings erscheinen keine verfügbaren Versionen,
                wenn ich den aktuellen Aufbewahrungsort auf latest wechsle.
                Ich kann daher den admin-Adapter nicht auf 4... updaten.
                Das logfile sagt:
                host.raspberrypi 2020-06-11 15:41:24.955 warn warning: empty repo received!
                host.raspberrypi 2020-06-11 15:41:24.954 warn warning: Cannot read "http://download.iobroker.net/sources-dist-latest.json"
                Hat jemand eine Idee?
                Mfg
                Ferdi
                INFO:
                raspberrypi
                Betriebssystem
                linux
                Architektur
                arm
                CPUs
                Geschwindigkeit
                1500 MHz
                Modell
                ARMv7 Processor rev 3 (v7l)
                RAM
                1.89 GB
                System Betriebszeit
                06:20:17
                Node.js
                v12.18.0
                NPM
                6.14.4
                Festplatte Größe
                7.02 GB
                Festplatte frei
                4.6 GB
                Betriebszeit
                04:48:00
                Aktive Instanzen
                Hostname
                raspberrypi
                • N Newbie12
                  Das logfile sagt:
                  Mfg
                  Ferdi
                  INFO:
                  raspberrypi
                  Betriebssystem
                  linux
                  Architektur
                  arm
                  CPUs
                  Geschwindigkeit
                  1500 MHz
                  Modell
                  RAM
                  1.89 GB
                  System Betriebszeit
                  06:20:17
                  Node.js
                  v12.18.0
                  NPM
                  6.14.4
                  Festplatte Größe
                  7.02 GB
                  Festplatte frei
                  4.6 GB
                  Betriebszeit
                  04:48:00
                  Aktive Instanzen
                  Hostname
                  raspberrypi
                  @Newbie12
                  Füg mal als alternative Quelle für latest das ein
                  http://iobroker.live/repo/sources-dist-latest.json
                  Wobei in 'default' auch die Version 4.0.10 liegt. Du hast da wohl ein Problem mit der Verbindung zu den Verwahrorten.
                  Ich würde als alternative 'default' das mal versuchen und nicht auf 'latest' gehen.
                  http://iobroker.live/repo/sources-dist.json
                  N 1 Antwort Letzte Antwort
                    @Newbie12
                    N Offline
                    N Offline
                    Newbie12
                    @Thomas-Braun
                    Vielen Dank! Konnte den mit der alternativen Quelle auf 4.1.1 updaten.
                    Die Fehlerschleife taucht im log danach auch nicht mehr auf.
                    mfG
                    Ferdi
                    5afca979-e072-425b-b8b8-27548f667e92-grafik.png Admin-Adapter
                    • N Newbie12
                      @Thomas-Braun
                      mfG
                      Ferdi
                      @Newbie12
                      Dann würde ich jetzt wieder auf 'default' zurückstellen, ggf. auch auf die alternative URL.
                      Und dann alle anderen Adapter auf die jeweils aktuellste Verision in default bringen.
