  3. Entwicklung
  4. Emby 1.0.0, startet immer wieder neu...
    5.2k
embyneustart
57 Beiträge 7 Kommentatoren 8.9k Aufrufe 7 Beobachtet
    Schimi
    HI,
    wir mit @thewhobox im Chat besprochen.... hier der Log und nochmal eine kurze beschreibung:
    Die Version 0.1.2 des Adapters, funktioniert "einwandfrei"....
    Die 1.0.0 startet immer wieder neu....
    undefined2020-02-02 19:38:24.616  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" enabled
    2020-02-02 19:38:24.647  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 9452
    2020-02-02 19:38:25.536  - info: emby.0 (9452) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
    2020-02-02 19:38:25.583  - info: emby.0 (9452) connected with emby (192.168.178.21:8096)
    2020-02-02 19:39:19.147  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" disabled
    2020-02-02 19:39:19.147  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 (force=false, process=true)
    2020-02-02 19:39:19.147  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 send kill signal
    2020-02-02 19:39:19.162  - info: emby.0 (9452) Got terminate signal TERMINATE_YOURSELF
    2020-02-02 19:39:19.162  - info: emby.0 (9452) terminating
    2020-02-02 19:39:19.162  - info: emby.0 (9452) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-02-02 19:39:19.691  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
    2020-02-02 19:39:33.600  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" enabled
    2020-02-02 19:39:33.616  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 6840
    2020-02-02 19:39:34.413  - debug: emby.0 (6840) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-02-02 19:39:34.428  - debug: emby.0 (6840) Objects client ready ... initialize now
    2020-02-02 19:39:34.444  - debug: emby.0 (6840) Objects create System PubSub Client
    2020-02-02 19:39:34.444  - debug: emby.0 (6840) Objects create User PubSub Client
    2020-02-02 19:39:34.444  - debug: emby.0 (6840) Objects client initialize lua scripts
    2020-02-02 19:39:34.444  - debug: emby.0 (6840) Objects connected to redis: 127.0.0.1:9001
    2020-02-02 19:39:34.444  - debug: emby.0 (6840) objectDB connected
    2020-02-02 19:39:34.459  - debug: emby.0 (6840) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-02-02 19:39:34.459  - debug: emby.0 (6840) States create User PubSub Client
    2020-02-02 19:39:34.459  - debug: emby.0 (6840) States create System PubSub Client
    2020-02-02 19:39:34.459  - debug: emby.0 (6840) States connected to redis: 127.0.0.1:9000
    2020-02-02 19:39:34.459  - debug: emby.0 (6840) statesDB connected
    2020-02-02 19:39:34.506  - info: emby.0 (6840) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
    2020-02-02 19:39:34.522  - debug: emby.0 (6840) try to connect to: 192.168.178.21:8096
    2020-02-02 19:39:34.522  - debug: emby.0 (6840) 2
    2020-02-02 19:39:34.538  - info: emby.0 (6840) connected with emby (192.168.178.21:8096)
    2020-02-02 19:40:00.461  - debug: emby.0 (6840) system.adapter.admin.0: logging false
    2020-02-02 19:40:08.986  - error: emby.0 (6840) uncaught exception: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:40:08.986  - error: emby.0 (6840) TypeError: Cannot read property 'DeviceProfile' of undefined
        at W3CWebSocket.webMessage [as onmessage] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\main.js:340:31)
        at W3CWebSocket._dispatchEvent [as dispatchEvent] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\yaeti\lib\EventTarget.js:107:17)
        at W3CWebSocket.onMessage (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:234:14)
        at WebSocketConnection.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:205:19)
        at WebSocketConnection.emit (events.js:198:13)
        at WebSocketConnection.processFrame (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:554:26)
        at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:323:40
        at process._tickCallback (internal/process/next_tick.js:61:11)
    2020-02-02 19:40:09.001  - info: emby.0 (6840) terminating
    2020-02-02 19:40:09.001  - info: emby.0 (6840) Terminated (NO_ERROR): Without reason
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]: TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.webMessage [as onmessage] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\main.js:340:31)
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket._dispatchEvent [as dispatchEvent] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\yaeti\lib\EventTarget.js:107:17)
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.onMessage (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:234:14)
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:205:19)
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.emit (events.js:198:13)
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.processFrame (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:554:26)
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:323:40
    2020-02-02 19:40:09.548  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:61:11)
    2020-02-02 19:40:09.548  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 0 (NO_ERROR)
    2020-02-02 19:40:09.548  - info: host.SmartHome(SmartHome) Restart adapter system.adapter.emby.0 because enabled
    2020-02-02 19:40:39.564  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 10144
    2020-02-02 19:40:40.408  - debug: emby.0 (10144) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-02-02 19:40:40.423  - debug: emby.0 (10144) Objects client ready ... initialize now
    2020-02-02 19:40:40.423  - debug: emby.0 (10144) Objects create System PubSub Client
    2020-02-02 19:40:40.423  - debug: emby.0 (10144) Objects create User PubSub Client
    2020-02-02 19:40:40.423  - debug: emby.0 (10144) Objects client initialize lua scripts
    2020-02-02 19:40:40.439  - debug: emby.0 (10144) Objects connected to redis: 127.0.0.1:9001
    2020-02-02 19:40:40.439  - debug: emby.0 (10144) objectDB connected
    2020-02-02 19:40:40.439  - debug: emby.0 (10144) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-02-02 19:40:40.455  - debug: emby.0 (10144) States create User PubSub Client
    2020-02-02 19:40:40.455  - debug: emby.0 (10144) States create System PubSub Client
    2020-02-02 19:40:40.455  - debug: emby.0 (10144) States connected to redis: 127.0.0.1:9000
    2020-02-02 19:40:40.455  - debug: emby.0 (10144) statesDB connected
    2020-02-02 19:40:40.502  - info: emby.0 (10144) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
    2020-02-02 19:40:40.517  - debug: emby.0 (10144) try to connect to: 192.168.178.21:8096
    2020-02-02 19:40:40.517  - debug: emby.0 (10144) 2
    2020-02-02 19:40:40.533  - info: emby.0 (10144) connected with emby (192.168.178.21:8096)
    2020-02-02 19:41:10.555  - error: emby.0 (10144) uncaught exception: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:41:10.555  - error: emby.0 (10144) TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:41:10.571  - info: emby.0 (10144) terminating
    2020-02-02 19:41:10.571  - info: emby.0 (10144) Terminated (NO_ERROR): Without reason
    2020-02-02 19:41:11.102  - error: host.SmartHome(SmartHome) Caught by controller[0]: TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:41:11.102  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.webMessage [as onmessage] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\main.js:340:31)
    2020-02-02 19:41:11.102  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket._dispatchEvent [as dispatchEvent] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\yaeti\lib\EventTarget.js:107:17)
    2020-02-02 19:41:11.117  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.onMessage (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:234:14)
    2020-02-02 19:41:11.117  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:205:19)
    2020-02-02 19:41:11.117  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.emit (events.js:198:13)
    2020-02-02 19:41:11.117  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.processFrame (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:554:26)
    2020-02-02 19:41:11.117  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:323:40
    2020-02-02 19:41:11.117  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:61:11)
    2020-02-02 19:41:11.117  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 0 (NO_ERROR)
    2020-02-02 19:41:11.117  - info: host.SmartHome(SmartHome) Restart adapter system.adapter.emby.0 because enabled
    2020-02-02 19:41:41.127  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 4348
    2020-02-02 19:41:41.923  - debug: emby.0 (4348) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-02-02 19:41:41.955  - debug: emby.0 (4348) Objects client ready ... initialize now
    2020-02-02 19:41:41.955  - debug: emby.0 (4348) Objects create System PubSub Client
    2020-02-02 19:41:41.955  - debug: emby.0 (4348) Objects create User PubSub Client
    2020-02-02 19:41:41.955  - debug: emby.0 (4348) Objects client initialize lua scripts
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) Objects connected to redis: 127.0.0.1:9001
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) objectDB connected
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) States create User PubSub Client
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) States create System PubSub Client
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) States connected to redis: 127.0.0.1:9000
    2020-02-02 19:41:41.970  - debug: emby.0 (4348) statesDB connected
    2020-02-02 19:41:42.017  - info: emby.0 (4348) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
    2020-02-02 19:41:42.033  - debug: emby.0 (4348) try to connect to: 192.168.178.21:8096
    2020-02-02 19:41:42.033  - debug: emby.0 (4348) 2
    2020-02-02 19:41:42.048  - info: emby.0 (4348) connected with emby (192.168.178.21:8096)
    2020-02-02 19:41:48.791  - info: javascript.0 (1664) Stop script script.js.common.Emby.LichtDimm
    2020-02-02 19:43:04.041  - info: javascript.0 (1664) Stop script script.js.common.Emby.LichtDimm
    2020-02-02 19:43:05.179  - info: javascript.0 (1664) Start javascript script.js.common.Emby.LichtDimm
    2020-02-02 19:43:05.195  - info: javascript.0 (1664) script.js.common.Emby.LichtDimm: registered 1 subscription and 0 schedules
    2020-02-02 19:43:07.744  - error: emby.0 (4348) uncaught exception: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:43:07.744  - error: emby.0 (4348) TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:43:07.760  - info: emby.0 (4348) terminating
    2020-02-02 19:43:07.760  - info: emby.0 (4348) Terminated (NO_ERROR): Without reason
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]: TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.webMessage [as onmessage] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\main.js:340:31)
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket._dispatchEvent [as dispatchEvent] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\yaeti\lib\EventTarget.js:107:17)
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.onMessage (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:234:14)
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:205:19)
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.emit (events.js:198:13)
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.processFrame (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:554:26)
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:323:40
    2020-02-02 19:43:08.275  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:61:11)
    2020-02-02 19:43:08.275  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 0 (NO_ERROR)
    2020-02-02 19:43:08.275  - info: host.SmartHome(SmartHome) Restart adapter system.adapter.emby.0 because enabled
    2020-02-02 19:43:38.297  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 8356
    2020-02-02 19:43:39.297  - debug: emby.0 (8356) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-02-02 19:43:39.312  - debug: emby.0 (8356) Objects client ready ... initialize now
    2020-02-02 19:43:39.312  - debug: emby.0 (8356) Objects create System PubSub Client
    2020-02-02 19:43:39.328  - debug: emby.0 (8356) Objects create User PubSub Client
    2020-02-02 19:43:39.328  - debug: emby.0 (8356) Objects client initialize lua scripts
    2020-02-02 19:43:39.328  - debug: emby.0 (8356) Objects connected to redis: 127.0.0.1:9001
    2020-02-02 19:43:39.343  - debug: emby.0 (8356) objectDB connected
    2020-02-02 19:43:39.343  - debug: emby.0 (8356) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-02-02 19:43:39.343  - debug: emby.0 (8356) States create User PubSub Client
    2020-02-02 19:43:39.343  - debug: emby.0 (8356) States create System PubSub Client
    2020-02-02 19:43:39.359  - debug: emby.0 (8356) States connected to redis: 127.0.0.1:9000
    2020-02-02 19:43:39.359  - debug: emby.0 (8356) statesDB connected
    2020-02-02 19:43:39.406  - info: emby.0 (8356) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
    2020-02-02 19:43:39.422  - debug: emby.0 (8356) try to connect to: 192.168.178.21:8096
    2020-02-02 19:43:39.422  - debug: emby.0 (8356) 2
    2020-02-02 19:43:39.453  - info: emby.0 (8356) connected with emby (192.168.178.21:8096)
    2020-02-02 19:43:41.312  - error: emby.0 (8356) uncaught exception: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:43:41.312  - error: emby.0 (8356) TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:43:41.312  - info: emby.0 (8356) terminating
    2020-02-02 19:43:41.312  - info: emby.0 (8356) Terminated (NO_ERROR): Without reason
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]: TypeError: Cannot read property 'DeviceProfile' of undefined
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.webMessage [as onmessage] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\main.js:340:31)
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket._dispatchEvent [as dispatchEvent] (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\yaeti\lib\EventTarget.js:107:17)
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at W3CWebSocket.onMessage (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:234:14)
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\W3CWebSocket.js:205:19)
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.emit (events.js:198:13)
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at WebSocketConnection.processFrame (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:554:26)
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at C:\Program Files\iobroker\SmartHome\node_modules\iobroker.emby\node_modules\websocket\lib\WebSocketConnection.js:323:40
    2020-02-02 19:43:41.843  - error: host.SmartHome(SmartHome) Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:61:11)
    2020-02-02 19:43:41.843  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 0 (NO_ERROR)
    2020-02-02 19:43:41.843  - info: host.SmartHome(SmartHome) Restart adapter system.adapter.emby.0 because enabled
    2020-02-02 19:43:49.062  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" disabled
    2020-02-02 19:44:12.740  - debug: emby.0 (7248) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-02-02 19:44:12.756  - debug: emby.0 (7248) Objects client ready ... initialize now
    2020-02-02 19:44:12.756  - debug: emby.0 (7248) Objects create System PubSub Client
    2020-02-02 19:44:12.756  - debug: emby.0 (7248) Objects create User PubSub Client
    2020-02-02 19:44:12.756  - debug: emby.0 (7248) Objects client initialize lua scripts
    2020-02-02 19:44:12.771  - debug: emby.0 (7248) Objects connected to redis: 127.0.0.1:9001
    2020-02-02 19:44:12.771  - debug: emby.0 (7248) objectDB connected
    2020-02-02 19:44:12.787  - debug: emby.0 (7248) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-02-02 19:44:12.787  - debug: emby.0 (7248) States create User PubSub Client
    2020-02-02 19:44:12.787  - debug: emby.0 (7248) States create System PubSub Client
    2020-02-02 19:44:12.787  - debug: emby.0 (7248) States connected to redis: 127.0.0.1:9000
    2020-02-02 19:44:12.787  - debug: emby.0 (7248) statesDB connected
    2020-02-02 19:44:12.834  - error: emby.0 (7248) adapter disabled
    2020-02-02 19:44:12.849  - warn: emby.0 (7248) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2020-02-02 19:44:13.381  - error: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2020-02-02 19:44:13.381  - info: host.SmartHome(SmartHome) Do not restart adapter system.adapter.emby.0 because disabled or deleted
    thewhoboxT 1 Antwort Letzte Antwort
    • S Schimi
      HI,
      thewhoboxT Offline
      thewhoboxT Offline
      thewhobox
      @Schimi Hey, vielen Dank für das Log.
      Hab den Fehler mal im Git beseitigt.
      Kannst du kurz von da installieren und mir dann bescheid geben ob es bei dir funktioniert?
      Meine Adapter: emby | discovery
        Schimi
        schrieb am zuletzt editiert von Schimi
        Der Fehler kommt jetzt nicht mehr...
        Aber die Playstates werden nicht mehr aktualisiert...
        bei jedem Gerät wird das "media" object nicht mehr ausgelesen, also die Ids stehen dort aber die werte sind alle leer...
        Debug ist unauffällig....
        undefined2020-02-03 19:06:49.846  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" enabled
        2020-02-03 19:06:49.877  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 4808
        2020-02-03 19:06:50.814  - info: emby.0 (4808) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
        2020-02-03 19:06:50.845  - info: emby.0 (4808) connected with emby (192.168.178.21:8096)
        2020-02-03 19:06:57.948  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" disabled
        2020-02-03 19:06:57.947  - info: emby.0 (4808) Got terminate signal TERMINATE_YOURSELF
        2020-02-03 19:06:57.947  - info: emby.0 (4808) terminating
        2020-02-03 19:06:57.947  - info: emby.0 (4808) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2020-02-03 19:06:57.948  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 (force=false, process=true)
        2020-02-03 19:06:57.948  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 send kill signal
        2020-02-03 19:06:58.495  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
        2020-02-03 19:07:30.496  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" enabled
        2020-02-03 19:07:30.512  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 8604
        2020-02-03 19:07:31.324  - debug: emby.0 (8604) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2020-02-03 19:07:31.340  - debug: emby.0 (8604) Objects client ready ... initialize now
        2020-02-03 19:07:31.340  - debug: emby.0 (8604) Objects create System PubSub Client
        2020-02-03 19:07:31.340  - debug: emby.0 (8604) Objects create User PubSub Client
        2020-02-03 19:07:31.340  - debug: emby.0 (8604) Objects client initialize lua scripts
        2020-02-03 19:07:31.355  - debug: emby.0 (8604) Objects connected to redis: 127.0.0.1:9001
        2020-02-03 19:07:31.355  - debug: emby.0 (8604) objectDB connected
        2020-02-03 19:07:31.371  - debug: emby.0 (8604) Redis States: Use Redis connection: 127.0.0.1:9000
        2020-02-03 19:07:31.371  - debug: emby.0 (8604) States create User PubSub Client
        2020-02-03 19:07:31.371  - debug: emby.0 (8604) States create System PubSub Client
        2020-02-03 19:07:31.371  - debug: emby.0 (8604) States connected to redis: 127.0.0.1:9000
        2020-02-03 19:07:31.371  - debug: emby.0 (8604) statesDB connected
        2020-02-03 19:07:31.418  - info: emby.0 (8604) starting. Version 1.0.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
        2020-02-03 19:07:31.434  - debug: emby.0 (8604) try to connect to: 192.168.178.21:8096
        2020-02-03 19:07:31.434  - debug: emby.0 (8604) 2
        2020-02-03 19:07:31.449  - info: emby.0 (8604) connected with emby (192.168.178.21:8096)
        2020-02-03 19:09:12.895  - debug: emby.0 (8604) system.adapter.admin.0: logging false
        2020-02-03 19:10:49.333  - debug: emby.0 (8604) system.adapter.admin.0: logging true
        • S Schimi
          thewhoboxT Offline
          thewhoboxT Offline
          thewhobox
          @Schimi Okay, dann ist da iwie die Infos die der Adapter von deinem Emby Server bekommt anders.
          Ich hab mal auf GitHub eingebaut, dass er die Daten ausgibt.
          Achtung! Das wird viele Daten produzieren, am besten direkt nach dem starten des Adapters auf Emby etwas abspielen und nach 20 Sekunden den Adapter wieder stoppen.
          Danach die komplette (nicht aus dem UI, da werden die Zeilen abgeschnitten) bitte hier im Thread anhängen.
            Schimi
            erledigt.... habe zweimal was abspielen lassen...
            Einmal mit der Android App auf meinem MiMix2s und einmal direkt im Browser:
            Mist, muss das als Datei hochladen... darf nicht mehr als 100.000 zeichen sein ;-)
            Ich hoffe du kommst damit klar :-)
            iobroker.2020-02-05.log
            • S Schimi
              thewhoboxT Offline
              thewhoboxT Offline
              thewhobox
              @Schimi Okay ich habs nochmal auf Github angepasst. Sollte jetzt funktionieren.
                Schimi
                HI,
                die werte werden nun richtig angezeigt.
                Scheint also un wieder alles zu laufen... der "härtetest" kommt heute abend und am WE :-)
                Wenn ich bis Sonntag abend nicht schreibe, sollte alles gut gegangen sein :-)
                Danke!!
                • S Schimi
                  HI,
                  Danke!!
                  thewhoboxT Offline
                  thewhoboxT Offline
                  thewhobox
                  @Schimi okay super. Danke fürs testen.
                    Schimi
                    So,
                    bis her keine auffälligkeiten.... alles funktioniert wie erwartet.
                    <<Habe festgestellt, das wenn Emby aus gewesen ist und wieder gestartet wird... der Adapter auch einen Neustart braucht bis er wieder reagiert (Hatte Emby ausversehen für ne Std runtergefahren heute).>>
                    Ich Poste hier mal das blockly welches ich für das Dimmen (bzw. zum testen) benutze.
                    Es fragt ab ob das Licht an ist und die zeit nicht zwischen Sonnenaufgang und Sonnenuntergang ist.
                    Dann wird beim abspielen das Licht auf 40% gedimmt und bei pause oder aus auf 80 und 2sec später auf 100% gedimmt (damit es nicht auf einmal so hell ist)
                    Vielen Dank nochmal für den Adapter!! :-)
                      <block type="on" id="8!%J+Db:iL(ECLO_3}N;" x="263" y="-687">
                        <field name="OID">emby.0.b01228d08950e61b5b6091c7c232813b.media.state</field>
                        <statement name="STATEMENT">
                          <block type="controls_if" id="fT7{F@dBVLYc(;!Mh0+f">
                            <value name="IF0">
                              <block type="logic_operation" id="-bm)V`joJBzPL=BcBbQW" inline="false">
                                <field name="OP">AND</field>
                                <value name="A">
                                  <block type="time_compare_ex" id="gPO*rn$ijBYtFcL?;2=6">
                                    <mutation end_time="true" actual_time="true"></mutation>
                                    <field name="USE_ACTUAL_TIME">TRUE</field>
                                    <field name="OPTION">not between</field>
                                    <value name="START_TIME">
                                      <shadow type="text" id="y;L(}k!WqMdC*oW$g/b.">
                                        <field name="TEXT">12:00</field>
                                      </shadow>
                                      <block type="time_astro" id="]89,s;3mDw/-b_?Wv38v">
                                        <field name="TYPE">sunriseEnd</field>
                                        <field name="OFFSET">0</field>
                                      </block>
                                    </value>
                                    <value name="END_TIME">
                                      <shadow type="text" id="g[XZg($lxvI)p$K~GC+r">
                                        <field name="TEXT">18:00</field>
                                      </shadow>
                                      <block type="time_astro" id="X*90xNbJETZ~XV?z;K[8">
                                        <field name="TYPE">sunsetStart</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="logic_compare" id="/NsR:t+F)uFPvwwcV!C^">
                                    <field name="OP">EQ</field>
                                    <value name="A">
                                      <block type="get_value" id="_mqm=_8*aK$1U^=M[7)T">
                                        <field name="OID">shelly.0.SHSW-1#F3E48C#1.Relay0.Switch</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="logic_boolean" id=";N/{tO*,QQ0[bJ9u2.-(">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <statement name="DO0">
                              <block type="controls_if" id="`*#hdj^zO*MaNB2u79yd">
                                <value name="IF0">
                                  <block type="logic_compare" id="`@QR.nl/p?T*aD:WwEcD">
                                    <value name="A">
                                      <block type="on_source" id="Ist0!%xe)J*Wbt?E1Dgj">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="C??)}VrD8GG2+u)*efa1">
                                        <field name="TEXT">playing</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="control" id="N!r=dpL~W1wO8{=kmiB)">
                                    <field name="OID">milight.0.zone1.brightness</field>
                                    <value name="VALUE">
                                      <block type="math_number" id="3u*gH3pF^qTEF;S:L8z?">
                                        <field name="NUM">40</field>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <value name="IF1">
                                  <block type="logic_compare" id="I8iDNaQdem8d3$*PBXx/">
                                    <field name="OP">NEQ</field>
                                    <value name="A">
                                      <block type="on_source" id="w!j6G41RK|]9p{B=kTc$">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="(ojrcouYpgv`^{k(^3%I">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO1">
                                  <block type="control" id="ozi]n9HjW_#B9*yM-ozv">
                                      <block type="math_number" id="LiI6|sKSH7HEC$.`}n|d">
                                        <field name="NUM">80</field>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="control" id="MgSM~-!l=r7QO.{HY0AB">
                                        <mutation delay_input="true"></mutation>
                                        <field name="DELAY_MS">1500</field>
                                        <field name="UNIT">ms</field>
                                          <block type="math_number" id="A0KRZoZ@MOSK!-9-UyPD">
                                            <field name="NUM">100</field>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </xml>
                    • S Schimi
                      So,
                              <value name="IF0">
                                  <value name="A">
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                  <value name="IF0">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <value name="IF1">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                      <next>
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </xml>
                      thewhoboxT Offline
                      thewhoboxT Offline
                      thewhobox
                      @Schimi sagte in Emby 1.0.0, startet immer wieder neu...:
                      Eig sollte er dann alle Minute einen neuen Versuch aufbauen.
                      Kannst ja mal testen wenn du Zeit hast und dann ins Log schauen was er sagt.
                        Schimi
                        werde ich demnächst Probieren und bescheid geben!! :)
                        Habe gerade erstmal das Update auf 1.0.2 gemacht 👍 👍
                          Schimi
                          ok, das mit dem update scheint nicht zu klappen....
                          Habe den Adapter Deinstalliert und mir wurde im stable der 1.0.2 angeboten...
                          Der wird abgebrochen....
                          Habe dann GitHub genommen, dort wird der 1.0.1 installiert (funktioniert bis jetzt auch einwandfrei), das angbotene Update auf 1.0.2 geht aber nicht...
                          Habe mal das Log angehangen...
                          undefined2020-02-12 18:04:22.915  - info: host.SmartHome(SmartHome) iobroker add emby  --host SmartHome(SmartHome)
                          2020-02-12 18:04:25.353  - info: host.SmartHome(SmartHome) iobroker NPM version: 6.11.3
                          2020-02-12 18:04:25.353  - info: host.SmartHome(SmartHome) iobroker npm install iobroker.emby@1.0.2 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
                          2020-02-12 18:04:27.056  - info: host.SmartHome(SmartHome) iobroker npm
                          2020-02-12 18:04:27.056  - info: host.SmartHome(SmartHome) iobroker  ERR! code ETARGET
                          2020-02-12 18:04:27.056  - info: host.SmartHome(SmartHome) iobroker ERR! notarget No matching version found for iobroker.emby@1.0.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
                          2020-02-12 18:04:27.072  - info: host.SmartHome(SmartHome) iobroker
                          2020-02-12 18:04:27.072  - info: host.SmartHome(SmartHome) iobroker npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-02-12T17_04_27_055Z-debug.log
                          2020-02-12 18:04:27.087  - error: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) Cannot install iobroker.emby@1.0.2: 1
                          2020-02-12 18:04:28.119  - info: host.SmartHome(SmartHome) iobroker exit 25
                          2020-02-12 18:04:28.353  - info: host.SmartHome(SmartHome) iobroker exit 0
                          2020-02-12 18:04:40.777  - info: host.SmartHome(SmartHome) iobroker url "https://github.com/thewhobox/ioBroker.emby/tarball/master" emby
                          2020-02-12 18:04:47.840  - info: host.SmartHome(SmartHome) iobroker install https://github.com/thewhobox/ioBroker.emby/tarball/master
                          2020-02-12 18:04:48.871  - info: host.SmartHome(SmartHome) iobroker NPM version: 6.11.3
                          2020-02-12 18:04:48.871  - info: host.SmartHome(SmartHome) iobroker npm install https://github.com/thewhobox/ioBroker.emby/tarball/master --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
                          2020-02-12 18:05:23.435  - info: host.SmartHome(SmartHome) iobroker exit 0
                          2020-02-12 18:05:34.576  - info: host.SmartHome(SmartHome) iobroker upload [2] emby.admin C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby/admin/words.js words.js application/javascript
                          2020-02-12 18:05:34.670  - info: host.SmartHome(SmartHome) iobroker upload [1] emby.admin C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby/admin/index_m.html index_m.html text/html
                          2020-02-12 18:05:34.732  - info: host.SmartHome(SmartHome) iobroker upload [0] emby.admin C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby/admin/emby.png emby.png image/png
                          2020-02-12 18:05:35.826  - info: host.SmartHome(SmartHome) iobroker exit 0
                          2020-02-12 18:05:47.014  - info: host.SmartHome(SmartHome) iobroker add emby  --host SmartHome(SmartHome)
                          2020-02-12 18:05:48.405  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) create instance emby
                          2020-02-12 18:05:48.405  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.sigKill created
                          2020-02-12 18:05:48.452  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.eventLoopLag created
                          2020-02-12 18:05:48.483  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.outputCount created
                          2020-02-12 18:05:48.515  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.inputCount created
                          2020-02-12 18:05:48.546  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.uptime created
                          2020-02-12 18:05:48.577  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.memRss created
                          2020-02-12 18:05:48.609  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.memHeapTotal created
                          2020-02-12 18:05:48.640  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.memHeapUsed created
                          2020-02-12 18:05:48.671  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.cputime created
                          2020-02-12 18:05:48.702  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.cpu created
                          2020-02-12 18:05:48.734  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.compactMode created
                          2020-02-12 18:05:48.765  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.connected created
                          2020-02-12 18:05:48.796  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0.alive created
                          2020-02-12 18:05:48.827  - info: host.SmartHome(SmartHome) iobroker host.SmartHome(SmartHome) object system.adapter.emby.0 created
                          2020-02-12 18:05:49.858  - info: host.SmartHome(SmartHome) iobroker exit 0
                          2020-02-12 18:06:05.205  - info: host.SmartHome(SmartHome) "system.adapter.emby.0" enabled
                          2020-02-12 18:06:05.221  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 5428
                          2020-02-12 18:06:06.111  - debug: emby.0 (5428) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-02-12 18:06:06.143  - debug: emby.0 (5428) Objects client ready ... initialize now
                          2020-02-12 18:06:06.143  - debug: emby.0 (5428) Objects create System PubSub Client
                          2020-02-12 18:06:06.143  - debug: emby.0 (5428) Objects create User PubSub Client
                          2020-02-12 18:06:06.143  - debug: emby.0 (5428) Objects client initialize lua scripts
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) Objects connected to redis: 127.0.0.1:9001
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) objectDB connected
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) States create User PubSub Client
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) States create System PubSub Client
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) States connected to redis: 127.0.0.1:9000
                          2020-02-12 18:06:06.158  - debug: emby.0 (5428) statesDB connected
                          2020-02-12 18:06:06.205  - info: emby.0 (5428) starting. Version 1.0.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
                          2020-02-12 18:06:06.221  - debug: emby.0 (5428) try to connect to: 192.168.178.21:8096
                          2020-02-12 18:06:06.236  - info: emby.0 (5428) connected with emby (192.168.178.21:8096)
                          2020-02-12 18:06:13.691  - debug: emby.0 (5428) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b70d:a00:956c:f3f0:431a:708d","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-12T17:06:03.5805366Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:52724","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-12T17:05:56.1312882Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false}]}
                          2020-02-12 18:06:13.706  - debug: emby.0 (5428) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b70d:a00:956c:f3f0:431a:708d","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-12T17:06:03.5805366Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:52724","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-12T17:05:56.1312882Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false}]}
                          2020-02-12 18:06:14.675  - debug: emby.0 (5428) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b70d:a00:956c:f3f0:431a:708d","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-12T17:06:04.5660066Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:52724","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-12T17:05:56.1312882Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false}]}
                          2020-02-12 18:06:17.582  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 (force=false, process=true)
                          2020-02-12 18:06:17.597  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 send kill signal
                          2020-02-12 18:06:17.598  - info: emby.0 (5428) Got terminate signal TERMINATE_YOURSELF
                          2020-02-12 18:06:17.613  - info: emby.0 (5428) terminating
                          2020-02-12 18:06:17.613  - info: emby.0 (5428) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2020-02-12 18:06:18.144  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                          2020-02-12 18:06:20.120  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 7920
                          2020-02-12 18:06:20.949  - debug: emby.0 (7920) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-02-12 18:06:20.964  - debug: emby.0 (7920) Objects client ready ... initialize now
                          2020-02-12 18:06:20.964  - debug: emby.0 (7920) Objects create System PubSub Client
                          2020-02-12 18:06:20.964  - debug: emby.0 (7920) Objects create User PubSub Client
                          2020-02-12 18:06:20.964  - debug: emby.0 (7920) Objects client initialize lua scripts
                          2020-02-12 18:06:20.980  - debug: emby.0 (7920) Objects connected to redis: 127.0.0.1:9001
                          2020-02-12 18:06:20.980  - debug: emby.0 (7920) objectDB connected
                          2020-02-12 18:06:20.980  - debug: emby.0 (7920) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-02-12 18:06:20.995  - debug: emby.0 (7920) States create User PubSub Client
                          2020-02-12 18:06:20.995  - debug: emby.0 (7920) States create System PubSub Client
                          2020-02-12 18:06:20.995  - debug: emby.0 (7920) States connected to redis: 127.0.0.1:9000
                          2020-02-12 18:06:20.995  - debug: emby.0 (7920) statesDB connected
                          2020-02-12 18:06:21.042  - info: emby.0 (7920) starting. Version 1.0.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
                          2020-02-12 18:06:21.042  - debug: emby.0 (7920) try to connect to: 192.168.178.21:8096
                          2020-02-12 18:06:21.074  - info: emby.0 (7920) connected with emby (192.168.178.21:8096)
                          2020-02-12 18:06:26.450  - info: host.SmartHome(SmartHome) Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                          2020-02-12 18:06:28.591  - info: host.SmartHome(SmartHome) iobroker upgrade emby
                          2020-02-12 18:06:30.060  - info: host.SmartHome(SmartHome) iobroker Update emby from @1.0.1 to @1.0.2
                          2020-02-12 18:06:30.935  - info: host.SmartHome(SmartHome) iobroker NPM version: 6.11.3
                          2020-02-12 18:06:30.935  - info: host.SmartHome(SmartHome) iobroker npm install iobroker.emby@1.0.2 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker npm
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker  ERR! code ETARGET
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker npm ERR! notarget
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker  No matching version found for iobroker.emby@1.0.2.npm
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker notarget
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker  In most cases you or one of your dependencies are requesting
                          2020-02-12 18:06:32.638  - info: host.SmartHome(SmartHome) iobroker  a package version that doesn't exist.
                          2020-02-12 18:06:32.653  - info: host.SmartHome(SmartHome) iobroker
                          2020-02-12 18:06:32.653  - info: host.SmartHome(SmartHome) iobroker npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-02-12T17_06_32_638Z-debug.log
                          2020-02-12 18:06:32.685  - info: host.SmartHome(SmartHome) iobroker upload [2] emby.admin C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby/admin/words.js words.js application/javascript
                          2020-02-12 18:06:32.700  - info: host.SmartHome(SmartHome) iobroker Update "system.adapter.emby.0"
                          2020-02-12 18:06:32.700  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 (force=false, process=true)
                          2020-02-12 18:06:32.700  - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 send kill signal
                          2020-02-12 18:06:32.700  - info: emby.0 (7920) Got terminate signal TERMINATE_YOURSELF
                          2020-02-12 18:06:32.700  - info: emby.0 (7920) terminating
                          2020-02-12 18:06:32.700  - info: emby.0 (7920) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2020-02-12 18:06:32.778  - info: host.SmartHome(SmartHome) iobroker upload [1] emby.admin C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby/admin/index_m.html index_m.html text/html
                          2020-02-12 18:06:32.841  - info: host.SmartHome(SmartHome) iobroker upload [0] emby.admin C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby/admin/emby.png emby.png image/png
                          2020-02-12 18:06:32.903  - info: host.SmartHome(SmartHome) iobroker Adapter "emby" updated
                          2020-02-12 18:06:33.216  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                          2020-02-12 18:06:33.935  - info: host.SmartHome(SmartHome) iobroker exit 0
                          2020-02-12 18:06:35.216  - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 5860
                          2020-02-12 18:06:36.013  - debug: emby.0 (5860) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-02-12 18:06:36.044  - debug: emby.0 (5860) Objects client ready ... initialize now
                          2020-02-12 18:06:36.044  - debug: emby.0 (5860) Objects create System PubSub Client
                          2020-02-12 18:06:36.044  - debug: emby.0 (5860) Objects create User PubSub Client
                          2020-02-12 18:06:36.044  - debug: emby.0 (5860) Objects client initialize lua scripts
                          2020-02-12 18:06:36.059  - debug: emby.0 (5860) Objects connected to redis: 127.0.0.1:9001
                          2020-02-12 18:06:36.059  - debug: emby.0 (5860) objectDB connected
                          2020-02-12 18:06:36.059  - debug: emby.0 (5860) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-02-12 18:06:36.059  - debug: emby.0 (5860) States create User PubSub Client
                          2020-02-12 18:06:36.059  - debug: emby.0 (5860) States create System PubSub Client
                          2020-02-12 18:06:36.075  - debug: emby.0 (5860) States connected to redis: 127.0.0.1:9000
                          2020-02-12 18:06:36.075  - debug: emby.0 (5860) statesDB connected
                          2020-02-12 18:06:36.122  - info: emby.0 (5860) starting. Version 1.0.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
                          2020-02-12 18:06:36.122  - debug: emby.0 (5860) try to connect to: 192.168.178.21:8096
                          2020-02-12 18:06:36.153  - info: emby.0 (5860) connected with emby (192.168.178.21:8096)
                          • S Schimi
                            thewhoboxT Offline
                            thewhoboxT Offline
                            thewhobox
                            @Schimi ja ich hab das gestern ins Stable genommen. Kam aber noch nicht dazu die Version auch auf NPM zu pushen.
                            Werde das nachher oder morgen machen.
                            Wenn du aber von gut installierst ist es die neueste hat halt nur noch die alte Nummer.
                              Schimi
                              Ah ok... Bin da noch nicht so "bewandert" in dem Thema... Mach das mit iobroker erst ca. 3 Wochen 😉😉
                              Hauptsache ich habe nichts falsch gemacht 👍
                              Ich sage die Tage noch wegen dem reconnect bescheid
                              Danke!!👍
                              • S Schimi
                                Danke!!👍
                                thewhoboxT Offline
                                thewhoboxT Offline
                                thewhobox
                                @Schimi Hab das Package 1.0.2 nun veröffentlicht im latest.
                                Hehe nein hast nix falsch gemacht. Dachte nur ich schaff das schneller bevor es jemand ausprobiert^^
                                  Schimi
                                  HI,
                                  heute habe ich den Emby Server für 10min runtergefahren.....
                                  Bin aber erst ca. 2 Std nachdem er wieder Online war dazu gekommen die "iobroker Verbindung" zu testen.....
                                  Ich musste auch dieses mal den Adapter neu starten, vorher wurde kein wert aktualisiert....
                                  ach dem Neustart, keine Probleme
                                  • S Schimi
                                    HI,
                                    thewhoboxT Offline
                                    thewhoboxT Offline
                                    thewhobox
                                    @Schimi und was stand im Log während der Emby Server nicht erreichbar war?
                                      Schimi
                                      so, habe embe runtergefahren... nach ein paar min wieder gestartet... einmal das webinterface aufgerufen, bischen rumgeklickt, ein video gestartet und dann den adapter neu gestartet....
                                      undefined2020-02-14 11:32:47.862 - debug: emby.0 (924) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:32:42.0468663Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60146","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:32:30.5706235Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.30","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"4fe51f8011f344b1daa3264b7a422d07","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T05:36:56.1652647Z","DeviceName":"Mi A1","DeviceId":"40ec2ff7b6bec336","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.24","PlayableMediaTypes":["Video","Audio"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"b01228d08950e61b5b6091c7c232813b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"AndroidTv","LastActivityDate":"2020-02-13T21:29:52.5198906Z","DeviceName":"SHIELD","DeviceId":"339112f46519bd48","ApplicationVersion":"1.7.78g","AppIconUrl":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","SupportedCommands":["DisplayContent","Mute","Unmute","ToggleMute","DisplayMessage","PlayMediaSource"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:32:47.895 - debug: emby.0 (924) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:32:42.0468663Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60146","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:32:30.5706235Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.30","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"4fe51f8011f344b1daa3264b7a422d07","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T05:36:56.1652647Z","DeviceName":"Mi A1","DeviceId":"40ec2ff7b6bec336","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.24","PlayableMediaTypes":["Video","Audio"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"b01228d08950e61b5b6091c7c232813b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"AndroidTv","LastActivityDate":"2020-02-13T21:29:52.5198906Z","DeviceName":"SHIELD","DeviceId":"339112f46519bd48","ApplicationVersion":"1.7.78g","AppIconUrl":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","SupportedCommands":["DisplayContent","Mute","Unmute","ToggleMute","DisplayMessage","PlayMediaSource"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:32:48.605 - debug: emby.0 (924) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:32:42.7879686Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60146","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:32:30.5706235Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.30","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"4fe51f8011f344b1daa3264b7a422d07","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T05:36:56.1652647Z","DeviceName":"Mi A1","DeviceId":"40ec2ff7b6bec336","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.24","PlayableMediaTypes":["Video","Audio"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"b01228d08950e61b5b6091c7c232813b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"AndroidTv","LastActivityDate":"2020-02-13T21:29:52.5198906Z","DeviceName":"SHIELD","DeviceId":"339112f46519bd48","ApplicationVersion":"1.7.78g","AppIconUrl":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","SupportedCommands":["DisplayContent","Mute","Unmute","ToggleMute","DisplayMessage","PlayMediaSource"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:32:54.176 - debug: emby.0 (924) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60146","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:32:30.5706235Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.30","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"4fe51f8011f344b1daa3264b7a422d07","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T05:36:56.1652647Z","DeviceName":"Mi A1","DeviceId":"40ec2ff7b6bec336","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.24","PlayableMediaTypes":["Video","Audio"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"b01228d08950e61b5b6091c7c232813b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"AndroidTv","LastActivityDate":"2020-02-13T21:29:52.5198906Z","DeviceName":"SHIELD","DeviceId":"339112f46519bd48","ApplicationVersion":"1.7.78g","AppIconUrl":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","SupportedCommands":["DisplayContent","Mute","Unmute","ToggleMute","DisplayMessage","PlayMediaSource"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:33:07.663 - debug: emby.0 (924) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:33:01.8480031Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60146","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:32:30.5706235Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.30","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"4fe51f8011f344b1daa3264b7a422d07","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T05:36:56.1652647Z","DeviceName":"Mi A1","DeviceId":"40ec2ff7b6bec336","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.24","PlayableMediaTypes":["Video","Audio"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"b01228d08950e61b5b6091c7c232813b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"AndroidTv","LastActivityDate":"2020-02-13T21:29:52.5198906Z","DeviceName":"SHIELD","DeviceId":"339112f46519bd48","ApplicationVersion":"1.7.78g","AppIconUrl":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","SupportedCommands":["DisplayContent","Mute","Unmute","ToggleMute","DisplayMessage","PlayMediaSource"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:33:08.188 - debug: emby.0 (924) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:33:02.3817641Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60146","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:32:30.5706235Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.30","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"4fe51f8011f344b1daa3264b7a422d07","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T05:36:56.1652647Z","DeviceName":"Mi A1","DeviceId":"40ec2ff7b6bec336","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.24","PlayableMediaTypes":["Video","Audio"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"b01228d08950e61b5b6091c7c232813b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"AndroidTv","LastActivityDate":"2020-02-13T21:29:52.5198906Z","DeviceName":"SHIELD","DeviceId":"339112f46519bd48","ApplicationVersion":"1.7.78g","AppIconUrl":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","SupportedCommands":["DisplayContent","Mute","Unmute","ToggleMute","DisplayMessage","PlayMediaSource"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:33:16.652 - debug: emby.0 (924) {"MessageType":"ServerShuttingDown","MessageId":"14741b9d06034f0c8f9867ea094a1672","Data":""}
                                      2020-02-14 11:39:18.006 - debug: emby.0 (924) system.adapter.admin.0: logging false
                                      2020-02-14 11:39:30.616 - debug: emby.0 (924) system.adapter.admin.0: logging true
                                      2020-02-14 11:39:54.651 - debug: emby.0 (924) system.adapter.admin.0: logging false
                                      2020-02-14 11:41:05.486 - debug: emby.0 (924) system.adapter.admin.0: logging true
                                      2020-02-14 11:41:26.766 - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 (force=false, process=true)
                                      2020-02-14 11:41:26.780 - info: emby.0 (924) Got terminate signal TERMINATE_YOURSELF
                                      2020-02-14 11:41:26.766 - info: host.SmartHome(SmartHome) stopInstance system.adapter.emby.0 send kill signal
                                      2020-02-14 11:41:26.780 - info: emby.0 (924) terminating
                                      2020-02-14 11:41:26.780 - info: emby.0 (924) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      2020-02-14 11:41:27.343 - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                                      2020-02-14 11:41:29.293 - info: host.SmartHome(SmartHome) instance system.adapter.emby.0 started with pid 3768
                                      2020-02-14 11:41:30.089 - debug: emby.0 (3768) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2020-02-14 11:41:30.105 - debug: emby.0 (3768) Objects client ready ... initialize now
                                      2020-02-14 11:41:30.120 - debug: emby.0 (3768) Objects create System PubSub Client
                                      2020-02-14 11:41:30.120 - debug: emby.0 (3768) Objects create User PubSub Client
                                      2020-02-14 11:41:30.120 - debug: emby.0 (3768) Objects client initialize lua scripts
                                      2020-02-14 11:41:30.120 - debug: emby.0 (3768) Objects connected to redis: 127.0.0.1:9001
                                      2020-02-14 11:41:30.120 - debug: emby.0 (3768) objectDB connected
                                      2020-02-14 11:41:30.136 - debug: emby.0 (3768) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2020-02-14 11:41:30.136 - debug: emby.0 (3768) States create User PubSub Client
                                      2020-02-14 11:41:30.136 - debug: emby.0 (3768) States create System PubSub Client
                                      2020-02-14 11:41:30.136 - debug: emby.0 (3768) States connected to redis: 127.0.0.1:9000
                                      2020-02-14 11:41:30.136 - debug: emby.0 (3768) statesDB connected
                                      2020-02-14 11:41:30.183 - info: emby.0 (3768) starting. Version 1.0.2 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.emby, node: v10.17.0
                                      2020-02-14 11:41:30.199 - debug: emby.0 (3768) try to connect to: 192.168.178.21:8096
                                      2020-02-14 11:41:30.214 - info: emby.0 (3768) connected with emby (192.168.178.21:8096)
                                      2020-02-14 11:41:33.460 - debug: emby.0 (3768) system.adapter.admin.0: logging false
                                      2020-02-14 11:41:36.570 - debug: emby.0 (3768) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60950","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:41:24.4043904Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.26","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":109,"Id":"18744282c252cd1d4f9a1f8a1e8c379e","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T10:40:55.9683743Z","DeviceName":"Mi MIX 2S","DeviceId":"380445ffae4cac89","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:41:38.471 - debug: emby.0 (3768) system.adapter.admin.0: logging true
                                      2020-02-14 11:41:44.580 - debug: emby.0 (3768) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:41:38.7765152Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60950","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:41:24.4043904Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.26","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":109,"Id":"18744282c252cd1d4f9a1f8a1e8c379e","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T10:40:55.9683743Z","DeviceName":"Mi MIX 2S","DeviceId":"380445ffae4cac89","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true}]}
                                      2020-02-14 11:41:45.377 - debug: emby.0 (3768) {"MessageType":"Sessions","Data":[{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"2003:c5:b71c:6a00:e9a0:60ff:f2a1:695e","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":0,"Id":"573f4e5e5f7444cb73e89b3fc7ab0271","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby Web","LastActivityDate":"2020-02-14T10:41:39.5649330Z","DeviceName":"Chrome","DeviceId":"TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzgwLjAuMzk4Ny4xNiBTYWZhcmkvNTM3LjM2IEVkZy84MC4wLjM2MS45fDE1NzcxMTIxNTE2MzY1","ApplicationVersion":"4.3.1.0","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"[::ffff:192.168.178.51]:60950","PlayableMediaTypes":[],"PlaylistIndex":0,"PlaylistLength":0,"Id":"6cbff36bd6a8dcaf01267a249757375b","ServerId":"1f75b24842294abbae3ba21dc3d811d1","Client":"ioBroker","LastActivityDate":"2020-02-14T10:41:24.4043904Z","DeviceName":"Emby-MediaServer","DeviceId":"00001","ApplicationVersion":"4.3.1.0","SupportedCommands":[],"SupportsRemoteControl":false},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"AdditionalUsers":[],"RemoteEndPoint":"192.168.178.26","PlayableMediaTypes":["Audio","Video"],"PlaylistIndex":0,"PlaylistLength":109,"Id":"18744282c252cd1d4f9a1f8a1e8c379e","ServerId":"1f75b24842294abbae3ba21dc3d811d1","UserId":"a6c7ef63cf1c4231823ead5e4ecf12b1","UserName":"schimikeks","UserPrimaryImageTag":"2f61366e24fd650854003be17ff0e880","Client":"Emby for Android Mobile","LastActivityDate":"2020-02-14T10:40:55.9683743Z","DeviceName":"Mi MIX 2S","DeviceId":"380445ffae4cac89","ApplicationVersion":"3.0.97","AppIconUrl":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/android.png","SupportedCommands":["MoveUp","MoveDown","MoveLeft","MoveRight","PageUp","PageDown","PreviousLetter","NextLetter","ToggleOsd","ToggleContextMenu","Select","Back","SendKey","SendString","GoHome","GoToSettings","VolumeUp","VolumeDown","Mute","Unmute","ToggleMute","SetVolume","SetAudioStreamIndex","SetSubtitleStreamIndex","DisplayContent","GoToSearch","DisplayMessage","SetRepeatMode","ChannelUp","ChannelDown","PlayMediaSource","PlayTrailers"],"SupportsRemoteControl":true}]}
                                        Schimi
                                        heute nachmittag wurden Win10 Updates aufgespielt so das der Hyper-V Server neu gestartet hat und alle VMs auch.
                                        Durch mein "rumgeteste" stand die Emby-VM nicht auf automatisch starten.
                                        Dabei habe ich eben gesehen das der iobroker im Log
                                        "(1212) WebSocket Error. Try Reconnect in 60s" geworfen hat (ca. alle 80sec). Danach hat er sich mit dem emby Server, wie du oben geschrieben hast, verbunden und alles sofort richtig angezeigt.
                                        Komisch ist echt das ich die VMs beim testen natürlich auch zwischendurch neu gestartet habe.... und da kam die Meldung nie...
                                        ... also, entweder Zufall das es jetzt geht oder Zufall das es bisher nicht ging...
                                        ich hoffe das bringt dich irgendwie weiter 👍
                                          Schimi
                                          nochmal ich :-)
                                          Der Adapter hat es wieder nicht bemerkt als ich Emby neu gestartet habe (Updates eines Plugins)... erst nach einem Neustart des Adapters funktionierte alles....
                                          thewhoboxT 1 Antwort Letzte Antwort
