  4. js controller upgrade geht nicht unter windows
windows 10js controller update
3 Beiträge 2 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • Z Offline
    Z Offline
    zombiee77
    habe ioBroker unter Windws am laufen.
    Als ich versucht habe ioBroker einem Update zu nterziehen assiert folgendes:
    C:\iobroker>iobroker update
    C:\iobroker>node node_modules/iobroker.js-controller/iobroker.js update
    (node:7416) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
        at handleError (C:\iobroker\node_modules\iobroker.js-controller\node_modules\redis-parser\lib\parser.js:190:15)
        at parseType (C:\iobroker\node_modules\iobroker.js-controller\node_modules\redis-parser\lib\parser.js:304:14)
    (node:7416) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:7416) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    (node:7416) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
    Used repository: default
    hash changed => force download of new sources
    update done
    Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
    Adapter    .....
    C:\iobroker>iobroker upgrade self
    C:\iobroker>node node_modules/iobroker.js-controller/iobroker.js upgrade self
    (node:5408) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
    (node:5408) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:5408) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    (node:5408) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
    Update js-controller from @2.1.0 to @2.1.1
    NPM version: 6.4.1
    npm install iobroker.js-controller@2.1.1 --unsafe-perm --loglevel error --prefix "C:/iobroker" (System call)
    npm ERR! path C:\iobroker\node_modules\iobroker.js-controller
    npm ERR! code EBUSY
    npm ERR! errno -4082
    npm ERR! syscall rename
    npm ERR! EBUSY: resource busy or locked, rename 'C:\iobroker\node_modules\iobroker.js-controller' -> 'C:\iobroker\node_modules\.iobroker.js-controller.DELETE'
    npm ERR!     C:\Users\oezzi\AppData\Roaming\npm-cache\_logs\2019-11-22T20_36_37_532Z-debug.log
    host.ASUS-Notebook Cannot install iobroker.js-controller@2.1.1: 4294963214
    Könnt Ihr mir sagen , was da schief läuft?
    Liebe Grüße
    StabilostickS 1 Antwort Letzte Antwort
    • Z zombiee77
      update done
      Adapter    .....
      NPM version: 6.4.1
      npm ERR! code EBUSY
      Liebe Grüße
      StabilostickS Offline
      Stabilostick
      schrieb am zuletzt editiert von Stabilostick
      @zombiee77
      Läuft vielleicht der ioBroker-Dienst noch? ioBroker muss vor dem Upgrade gestoppt werden. Welche Node.js-Version nutzt Du?
      Z 1 Antwort Letzte Antwort
      • StabilostickS Stabilostick
        @zombiee77
        Z Offline
        Z Offline
        zombiee77
        @Stabilostick sagte in js controller upgrade geht nicht unter windows:
        Hi Stabilostick,
        danke für die schnelle Antwort.
        Habe es nun geschafft indem ich mir node js für Windows von:
        https://nodejs.org/en/download/releases/
        heruntergeladen habe.
        Jetzt ging es.
        Danke.
        LG
        z
