  5. Dimm Skript Error
    5.6k
Dimm Skript Error
4 Beiträge 2 Kommentatoren 508 Aufrufe 2 Beobachtet
  • marcusklM Offline
    marcusklM Offline
    marcuskl
    schrieb am zuletzt editiert von marcuskl
    ich möchte mit dem neuen Ikea Schalter/Dimmer dimmen, habe ein Blockly Skript gebastelt, aber diese lässt den Javascript Adapter abstürzen mit folgender Fehlermeldung:
    host.iobroker	2019-11-20 21:17:15.612	error	Caught by controller[9]: 12: 0x1c47e5adbe1d
    host.iobroker	2019-11-20 21:17:15.612	error	Caught by controller[9]: 11: 0x116d6de v8::internal::Runtime_AllocateInNewSpace(int, v8::internal::Object**, v8::internal::Isolate*) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.612	error	Caught by controller[8]: 10: 0xecd554 v8::internal::Factory::NewFillerObject(int, bool, v8::internal::AllocationSpace) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.612	error	Caught by controller[7]: 9: 0xf040d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.612	error	Caught by controller[6]: 8: 0xf01464 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.611	error	Caught by controller[5]: 7: 0xf00b32 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.611	error	Caught by controller[5]: 6: 0xef4a58 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.611	error	Caught by controller[5]: 5: 0xef4952 [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.611	error	Caught by controller[4]: 4: 0xb00444 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.611	error	Caught by controller[3]: 3: 0xb0020e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.610	error	Caught by controller[2]: 2: 0x8fa09c [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.610	error	Caught by controller[1]: 1: 0x8fa050 node::Abort() [io.javascript.0]
    host.iobroker	2019-11-20 21:17:15.609	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    Jemand ein Tipp ?
    Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
    Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
    • marcusklM marcuskl
      Jemand ein Tipp ?
      @marcuskl sagte:
      Jemand ein Tipp ?
      Nicht "wiederhole" verwenden, sondern "Ausführen Intervall". Außerdem bei >= 100 bzw. <= 0 abbrechen (stop Ausführen Intervall).
        Jemand ein Tipp ?
        @marcuskl Vorschlag:
        marcusklM 1 Antwort Letzte Antwort
          marcusklM Offline
          marcusklM Offline
          marcuskl
          @paul53 Vielen Dank dafür, funktioniert perfekt 👍 😊 😊
