  5. [gelöst] split is not a function
    6.0k
Geplant Angeheftet Gesperrt Verschoben Gelöst JavaScript
javascript
10 Beiträge 2 Kommentatoren 2.1k Aufrufe 1 Beobachtet
  • CKMartensC Offline
    CKMartensC Offline
    CKMartens
    schrieb am zuletzt editiert von CKMartens
    ich bin gerade dabei ein Script zu erstellen das mir den 3stündigen Trend für die Barometerdaten errechnet. Dazu habe lege ich alle 5 Minuten den Wert für den Unterschied zum vorherigen Wert in einem Datenpunkt als Liste ab
    -0.05,0.02,0.04,0.04,0,0.08,0.06,0,0.03,0.03,-0.02,-0.05,0.05,-0.05,0.06,0.02,-0.12,0.06,0.02,-0.04,0.07,0.04,-0.02,0.02,0.04,0.04,0.01,-0.02,0.06,0.04,-0.07,-0.11,0.11,-0.11,0,0.02,-0.02,0.05,0.02,0,0.03,0.01,0.04,-0.09,0.02,-0.04,0.03,0.06,0.1,-0.08,-0.04,0.05,0.03,0.01,0.02,0.01,0.05,0.03,0.1,0,0.01,-0.02,0.02,-0.01,-0.04,0.04,0.08,0.03,-0.05,-0.12,0.09,0.07
    Diese Liste lese ich mit ein und will sie mit split zum errechnen des Trends zerlegen
    function barotrend() {
      var tmpelements = getState(DP_BAROTREND_DATA).val.split(',');
      for (let i = 2; i <= ELEMENTS - 1; i++) {
        b_tmp = parseFloat(tmpelements[i]);
        A_BAROTRENDTEMPDATA.push(b_tmp);
        b_akt_diff = b_akt_diff + b_tmp;
      A_BAROTRENDTEMPDATA.push(b_diff);
      b_akt_diff = b_akt_diff + b_diff;  b_akt_diff = Math.round((b_akt_diff / ELEMENTS) * 100 ) / 100;
      setState(DP_BAROTREND_DATA, A_BAROTRENDTEMPDATA);
      setState(DP_BAROTREND_ALT, b);
      setState(DP_BAROTREND_TREND, b_akt_diff);
    schedule('*/'+CRON+' * * * *', function () {
      barotrend();
    Allerdings kommt spätestens nach dem zweiten Aufruf der Funktion barotrend() der Fehler
    javascript.1	2019-11-05 19:49:00.018	error	(2070) at Timer.processTimers (timers.js:223:10)
    javascript.1	2019-11-05 19:49:00.017	error	(2070) at listOnTimeout (timers.js:263:5)
    javascript.1	2019-11-05 19:49:00.017	error	(2070) at tryOnTimeout (timers.js:300:5)
    javascript.1	2019-11-05 19:49:00.017	error	(2070) at ontimeout (timers.js:436:11)
    javascript.1	2019-11-05 19:49:00.017	error	(2070) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.1	2019-11-05 19:49:00.016	error	(2070) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.1	2019-11-05 19:49:00.016	error	(2070) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.1	2019-11-05 19:49:00.016	error	(2070) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1279:34)
    javascript.1	2019-11-05 19:49:00.015	error	(2070) at Object.<anonymous> (script.js.Test.Weathercalc:417:3)
    javascript.1	2019-11-05 19:49:00.015	error	(2070) at barotrend (script.js.Test.Weathercalc:390:53)
    javascript.1	2019-11-05 19:49:00.014	error	(2070) Error in callback: TypeError: getState(...).val.split is not a function
    Node.js v10.17.0
    NPM 6.11.3
    js-controller: 2.0.39
    Kann mir einer sagen wo da der Fehler ist?
    • CKMartensC CKMartens
        barotrend();
      Node.js v10.17.0
      NPM 6.11.3
      @CKMartens sagte:
      Enthält der Datenpunkt schon ein Array ? Dann funktioniert .split(',') nicht und ist auch nicht erforderlich.
      CKMartensC 1 Antwort Letzte Antwort
        @CKMartens sagte:
        CKMartensC Offline
        CKMartensC Offline
        CKMartens
        @paul53 sagte in split is not a function:
        @CKMartens sagte:
        Wie muss ich dann vorgehen @paul53 ?
          @CKMartens sagte:
          @CKMartens sagte:
          Ohne split() einlesen.
            var tmpelements = getState(DP_BAROTREND_DATA).val;
          CKMartensC 2 Antworten Letzte Antwort
            @CKMartens sagte:
            CKMartensC Offline
            CKMartensC Offline
            CKMartens
            @paul53 Ah... Ok, versuche ich morgen. Danke schon einmal.
              @CKMartens sagte:
              CKMartensC Offline
              CKMartensC Offline
              CKMartens
              @CKMartens sagte:
              Hallo @paul53
              leider habe ich jetzt das Problem das jetzt die Variable tmpelements als Elemente jedes Zeichen enthält. Also aus dem Wert -0.3 werden die Elemente "-", "0", "." und "3" gemacht. Der Typ des Datenpunktes ist ein Array.
                @CKMartens sagte:
                Hallo @paul53
                @CKMartens sagte:
                Dann wurde das Array an anderer Stelle als String im Datenpunkt gespeichert. Das muss korrigiert werden.
                  @CKMartens sagte:
                  CKMartensC Offline
                  CKMartensC Offline
                  CKMartens
                  @CKMartens sagte:
                  Hmmm, eigentlich greift nur noch ein andres Script lesend auf den DP zu. Danke für den Tip, ich mach mich da mal geziehlt auf die Suche
                    @CKMartens sagte:
                    @CKMartens sagte:
                    Wenn in einem Skript ein String in einen Datenpunkt vom Typ "array" geschrieben wird, erfolgt eine Warnung "wrong type ...". Im Reiter "Log" findet man dazu den Skriptnamen und die Zeilennummer.
                      @CKMartens sagte:
                      CKMartensC Offline
                      CKMartensC Offline
                      CKMartens
                      @paul53 Habe es gefunden. Ein Testscript ist noch gelaufen obwohl es im eigentlich deaktiviert gewesen sein sollte.
                      Jetzt läuft es. Danke nochmals!
