  2. English
  3. ioBroker general
  4. Installation on openSuse failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
opensuse
4 Beiträge 4 Kommentatoren 847 Aufrufe 3 Beobachtet
  • C Offline
    chiabgigi
    Hello to all
    I'm new to the forum and my name is Luigi.
    I have linux openSuse 64bit installed on vmware, and I'm trying to install ioBroken.
    I installed nodejs, but when I install iobroken I get these errors, even if it finally tells me that it has been installed successfully, but in the browser at http: // myIp: 8081 there is nothing.
    And also in the / opt / iobroker folder I have only one file (illegible): iob
    Here is the result of konsole:
        Welcome to the ioBroker installer!
        Installer version: 2019-07-21
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Il flag q è sconosciuto.
    Installed acl
    Installed sudo
    Installed libcap2-bin
    Installed build-essential
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed pkg-config
    Installed git
    Installed curl
    Installed unzip
    sudo: setcap: comando non trovato
        Creating ioBroker user and directory (2/4)
    usermod: group 'iobroker' does not exist
    Created /etc/sudoers.d/iobroker
    chown: gruppo non valido: "luigi:luigi"
    Directory /opt/iobroker created
    touch: impossibile fare touch di '/opt/iobroker/INSTALLER_INFO.txt': Permesso negato
    chmod: impossibile accedere a '/opt/iobroker/INSTALLER_INFO.txt': File o directory non esistente
    bash: riga 458: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
    bash: riga 459: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
    bash: riga 460: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
        Installing ioBroker (3/4)
    bash: riga 472: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
    /usr/bin/node10: error while loading shared libraries: libicui18n.so.suse64.2: cannot open shared object file: No such file or directory
        Finalizing installation (4/4)
    bash: riga 498: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
    bash: riga 569: /opt/iobroker/iobroker: Permesso negato
    chmod: impossibile accedere a '/opt/iobroker/iobroker': File o directory non esistente
    Enabling autostart...
    chown: impossibile accedere a '/lib/systemd/system/iobroker.service': File o directory non esistente
    chmod: impossibile accedere a '/lib/systemd/system/iobroker.service': File o directory non esistente
    Failed to enable unit: Unit file iobroker.service does not exist.
    Failed to start iobroker.service: Unit iobroker.service not found.
    Autostart enabled!
    bash: riga 717: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
    chown: gruppo non valido: "iobroker:iobroker"
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
    main: riga 601: /opt/iobroker/INSTALLER_INFO.txt: Permesso negato
        ioBroker was installed successfully
        Open http://192.168.116.133:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    luigi@localhost:~> iobroker stop
    If 'iobroker' is not a typo you can use command-not-found to lookup the package that contains it, like this:
        cnf iobroker
    luigi@localhost:~> sudo mkdir /home/iobroker
    [sudo] password di root:
    mkdir: impossibile creare la directory "/home/iobroker": File già esistente
    luigi@localhost:~> sudo chown iobroker /home/iobroker
    luigi@localhost:~> iobroken start
    If 'iobroken' is not a typo you can use command-not-found to lookup the package that contains it, like this:
        cnf iobroken
    luigi@localhost:~>
    tanks
    J 1 Antwort Letzte Antwort
    • C chiabgigi
      Hello to all
      Installed acl
      Installed sudo
      Installed git
      Installed curl
      Installed unzip
      Autostart enabled!
          cnf iobroker
          cnf iobroken
      luigi@localhost:~>
      tanks
      jrjong11
      schrieb am zuletzt editiert von jrjong11
      @chiabgigi said in Installation on openSuse failed:
      Hello to all
      I installed nodejs, but when https aka ms remoteconnect I install iobroken I get these errors, even if it finally tells me that it has been installed successfully, but in the browser at http: // myIp: 8081 there is nothing.
      Installed acl
      Installed sudo
      Installed git
      Installed curl
      Installed unzip
      Autostart enabled!
          cnf iobroker
      mkdir: impossibile [https aka ms remoteconnect](https://one2step.net/aka-ms-remoteconnect-minecraft/) creare la directory "/home/iobroker": File già esistente
          cnf iobroken
      luigi@localhost:~>
      tanks
      Any update on this OP? I'm having the same issue here.
      Thanks in advane
      Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
      • J jrjong11
        Hello to all
        Installed acl
        Installed sudo
        Installed git
        Installed curl
        Installed unzip
        Autostart enabled!
            cnf iobroker
            cnf iobroken
        luigi@localhost:~>
        tanks
        Thanks in advane
        @jrjong11
        Try installing in a debian based distribution.
        • J jrjong11
          Hello to all
          Installed acl
          Installed sudo
          Installed git
          Installed curl
          Installed unzip
          Autostart enabled!
              cnf iobroker
              cnf iobroken
          luigi@localhost:~>
          tanks
          Thanks in advane
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @jrjong11
          If I look at the generated errors (and assuming I translate them correctly) the Skript fails at 3 points:
          • setcap: either the command does not exist or it cannot be used with sudo
          Sudo: setcap: comando non trovato
          • creating the user iobroker and group iobroker seems to fail
          • creating the folder /opt/iobroker seems to fail due to lack of permissions.
          @Thomas-Braun mentioned the easy way out - use a Debian based Linux as basis.
          If you want to keep opensuse, you can try the following steps:
          • create a user and group iobroker (without password, the user does not need to log on
          • create a folder /opt/iobroker and „chown“ it to iobroker
          • ensure that the user iobroker is allowed to use sudo
          • Run the script again.
          A.
